SA "Nagano"
Скоро выходит новая версия SA, началась подписка на бетатестирование. Просьба, как кому что прийдет, написать что там нового, т.к. в рассылке очень кратко о нововведениях. ... |
| 11.10.2012, 11:15 |
SA "Nagano"
какой номер версии планируется - 13 или 15 ? ... |
| 11.10.2012, 16:16 |
SA "Nagano"
хз,этой инфы пока нет. Но на родном форуме как-то поднимался этот вопрос и Глен Паули подтвердил, что точно не 13я версия будет. ... |
| 11.10.2012, 17:09 |
SA "Nagano"
смотрим сюда: сайт : http://www.sybase.com/naganobeta форум: http://sqlanywhere-forum.sybase.com/naganobet доки (не работают пока): http://dcx-pubs.sybase.com/index.html#sa1600/en/sachanges/sa-16-nagano.html нововведения кратко 1. Roles and Privileges A complete set of system privileges and roles have been added to increase security by providing you precision over the capabilities you want your users to have. For every privileged operation that can be performed in the system, a system privilege has been created. Roles combine privileges into logical groups. SAP Sybase SQL Anywhere provides you with many predefined roles, but you can also create your own roles. 2. ARRAY and ROW Data Types An ARRAY type is a homogeneous, multi-dimensional collection that can be passed in whole or in part as an argument to SQL stored procedures or functions. An ARRAY type can consist of up to 6.4 million elements. An ARRAY is initialized to an ARRAY of the declared type, where each element is NULL. ARRAY types can handle two levels of page size structures of 8 bytes each and one level of 16 byte structures. A ROW type is described by a row type descriptor, which consists of the field descriptor of each field in the ROW type. ROW types can handle two levels of page size structures of 8 bytes each, and one level of 16-byte structures. ROW types are restricted to 45000 fields, which is the same limit as the number of columns in a table. Additional information and examples featuring ARRAY and ROW data types: . OData Support OData (Open Data Protocol) enables data services over RESTful HTTP. It allows you to perform operations through URIs (Universal Resource Identifiers) to access and modify information. SAP Sybase SQL Anywhere now includes an OData Server that allows web clients to communicate with a SQL Anywhere database server. Web clients can send OData requests to a configurable OData Producer hosted in an HTTP server, which converts OData concepts into relational database operation 4. LDAP User Authentication Lightweight Directory Access Protocol (LDAP) is an industry standard for accessing directory services. LDAP user authentication allows client applications to send user ID and password information to the database server for authentication by an LDAP server instead of using the catalog. Authentication using an LDAP server allows organization-wide password management. 5. Database Mirroring and Read-Only Scale-Out Enhancements • Events can run on the mirror or a copy node • New MIRROR remote data access server class • Dynamically start a mirroring or read-only scale-out database on a running server 6. MobiLink Profiler The MobiLink Profiler is a MobiLink administration tool that provides you with detailed information about the performance of your synchronizations. Synchronization data from your profiling session is saved in a profiling database file. ... |
| 11.10.2012, 18:39 |
SA "Nagano"
автор2. ARRAY and ROW Data Types Вот ораклистам то радость будет :) ... |
| 11.10.2012, 20:27 |
SA "Nagano"
Сайт с докой до сих пор недоступен. Но если это все изменения, то становится очень грустно. ... |
| 14.10.2012, 15:37 |
SA "Nagano"
бета-программа началась. дока тут: http://dcx.sybase.com/index.html#sa16naganobeta/en/sqlanywhere_en16/help_top_index.htm ... |
| 13.11.2012, 21:18 |
SA "Nagano"
мда.. заметные изменения только в безопасности произошли. Но кому нужна навороченная безопасность в СУБД, которая в основном используется во всяких эмбеддедах? :( ... |
| 14.11.2012, 13:04 |
SA "Nagano"
Новая версия теперь называется SAP Sybase SQL Anywhere 16. Почему SAP вроде бы понятно - если не ошибаюсь, то SAP купил Sybase. Но почему 16 ? Ладно еще они 13 пропустили, типа суеверные. Но ведь есть еще 14 и 15 ... ... |
| 16.11.2012, 16:09 |
SA "Nagano"
думаю, что-бы нумерацию с ase выровнять. ... |
| 16.11.2012, 16:40 |
SA "Nagano"
авторесли не ошибаюсь, то SAP купил Sybase. Да ... |
| 16.11.2012, 17:26 |
start [/forum/topic.php?desktop=1&fid=55&tid=2010044]: |
59ms |
48ms |
| others: | 215ms |
| total: | 361ms |
