Активность триггера
Добрый день! Как узнать программно включен или выключен триггер на таблице? ASE 12.5 ... |
| 13.11.2014, 16:46:55 |
Активность триггера
Как говориться, google в помощь http://www.dbforums.com/showthread.php?1669812-How-to-know-if-a-trigger-is-enable Hi, Got the following information from another website. These values are not documented (at least i could not find ) trigger status (enabled/disabled) based on sysstat2 column values for table sysstat2 & 1048576 (0x100000) != 0 => insert trigger disabled sysstat2 & 2097152 (0x200000) != 0 => delete trigger disabled sysstat2 & 4194304 (0x400000) != 0 => update trigger disabled ... |
| 13.11.2014, 17:16:01 |
start [/forum/topic.php?desktop=1&fid=55&tid=2009802]: |
80ms |
44ms |
| others: | 185ms |
| total: | 354ms |
