I'm new in sqlite3: plz help me
CREATE TABLE ceos (name string unique, salary integer, politics string); ... sqlite> select * from ceos; name salary politics ---------- ---------- ---------- Jack Welch 1000000 Republican Carly Fior 5000000 Republican Erik Schmi 400000 Democrat Lee Iacocc 3 Democrat Kim Polese 600000 Republican CREATE TABLE recorded_salary_changes (id integer primary key autoincrement, content text, time_of datetime, change_by string); CREATE TRIGGER record_salary_changes update on ceos begin insert into recorded_salary_changes(id, content, time_of, changе_by) values(null, "name: " || old.name ||", old salary: " || old.salary || ", new salary: " || new.salary, datetime('now'), "Flunkie"); end; sqlite> update ceos set salary=999 where name="Lee Iacoca"; Error: table main.recorded_salary_changes has no column named changе_by What the problem?, i have column names change_by, is it bug???. ... |
| 09.07.2010, 19:35 |
zackushka, there is no mistakes in first column, they was just truncate. ... |
| 09.07.2010, 21:29 |
zackushka, help ... |
| 09.07.2010, 21:30 |
Check the spelling of field. Beware that some Cyrillic symbols looks exactly like Latin ones. If you hate Russian so much, you should learn English better. ... |
| 09.07.2010, 21:41 |
White OwlCheck the spelling of field. Beware that some Cyrillic symbols looks exactly like Latin ones. If you hate Russian so much, you should learn English better. Как умею, так и пишу на английском. Спасибо. Модератор: желтая карточка: пишите на русском, так как вам это доступно ... |
| 09.07.2010, 22:00 |
start [/forum/topic.php?desktop=1&fid=54&tid=2009318]: |
154ms |
26ms |
| others: | 207ms |
| total: | 416ms |
