PRAGMA auto_vacuum - как установить параметр?
как ни кручу в приложении - команда віполняется, но запрос после нее возвращает 0 Код: plaintext 1. 2. 3. 4. этот работает без проблем: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. ... |
| 25.11.2010, 15:34:32 |
http://www.sqlite.org/pragma.html#pragma_auto_vacuum Auto-vacuuming is only possible if the database stores some additional information that allows each database page to be traced backwards to its referrer. Therefore, auto-vacuuming must be turned on before any tables are created. It is not possible to enable or disable auto-vacuum after a table has been created. ... |
| 25.11.2010, 16:34:50 |
Dmitry Arefiev http://www.sqlite.org/pragma.html#pragma_auto_vacuum Auto-vacuuming is only possible if the database stores some additional information that allows each database page to be traced backwards to its referrer. Therefore, auto-vacuuming must be turned on before any tables are created. It is not possible to enable or disable auto-vacuum after a table has been created. ясно, спасибо ... |
| 25.11.2010, 17:21:35 |
start [/forum/topic.php?desktop=1&fid=54&tid=2009265]: |
88ms |
47ms |
| others: | 239ms |
| total: | 424ms |
