PostgreSQL и Radius сервер
Господа, не приходилось ли кому сталкиваться с совместной работой RADIUS сервера freeradius-0.9.3. и PostgreSQL 7.3.4. Возникает следующая проблемка при старте RADIUS-а который складывает в базу свои данные в логфайле вижу: Tue Feb 17 17:08:29 2004 : Info: rlm_sql (sql): Driver rlm_sql_postgresql (modul e rlm_sql_postgresql) loaded and linked Tue Feb 17 17:08:29 2004 : Info: rlm_sql (sql): Attempting to connect to user @localhost:/radiusb На этом процес зависает и я получаю вот такую ерунду: 9776 ? 00:00:00 radiusd <defunct> В логе PostrgeSQL вижу: Feb 17 17:08:29 hostname postgres[9770]: [1] LOG: connection received: host=127.0.0.1 port=35009 Feb 17 17:08:29 hostname postgres[9770]: [2] LOG: connection authorized: user=user database=radiusb Feb 17 17:08:29 hostname postgres[9770]: [3] LOG: запрос: begin; select getdatabaseencoding(); commit Feb 17 17:08:29 hostname postgres[9770]: [4] LOG: duration: 0.001009 sec Feb 17 17:08:29 hostname postgres[9771]: [1] LOG: connection received: host=127.0.0.1 port=35010 Feb 17 17:08:29 hostname postgres[9771]: [2] LOG: connection authorized: user=user database=radiusb Feb 17 17:08:29 hostname postgres[9771]: [3] LOG: запрос: begin; select getdatabaseencoding(); commit Feb 17 17:08:29 hostname postgres[9771]: [4] LOG: duration: 0.000989 sec Feb 17 17:08:29 hostname postgres[9772]: [1] LOG: connection received: host=127.0.0.1 port=35011 Feb 17 17:08:29 hostname postgres[9772]: [2] LOG: connection authorized: user=user database=radiusb Feb 17 17:08:29 hostname postgres[9772]: [3] LOG: запрос: begin; select getdatabaseencoding(); commit Feb 17 17:08:29 hostname postgres[9772]: [4] LOG: duration: 0.000992 sec Feb 17 17:08:29 hostname postgres[9773]: [1] LOG: connection received: host=127.0.0.1 port=35012 Feb 17 17:08:29 hostname postgres[9773]: [2] LOG: connection authorized: user=user database=radiusb Feb 17 17:08:29 hostname postgres[9773]: [3] LOG: запрос: begin; select getdatabaseencoding(); commit Feb 17 17:08:29 hostname postgres[9773]: [4] LOG: duration: 0.001002 sec Feb 17 17:08:29 hostname postgres[9775]: [1] LOG: connection received: host=127.0.0.1 port=35013 Feb 17 17:08:29 hostname postgres[9775]: [2] LOG: connection authorized: user=user database=radiusb Feb 17 17:08:29 hostname postgres[9775]: [3] LOG: запрос: begin; select getdatabaseencoding(); commit Feb 17 17:08:29 hostname postgres[9775]: [4] LOG: duration: 0.001161 secFeb 17 17:08:29 skytc postgres[9775]: [4] LOG: duration: 0.001161 sec И вот не пойму куда копать, то ли проблема в PostgreSQL то ли в RADIUS-е. Буду благодарен за любые идеи о том где копать...[quot автор][/quot] ... |
| 17.02.2004, 17:36:52 |
start [/forum/topic.php?desktop=1&fid=53&tid=2007916]: |
75ms |
26ms |
| others: | 219ms |
| total: | 351ms |
