Постоянно валится база
Расскажите пожалуйста, почему постоянно возникают такие проблемы и как с ними бороться: в один прекрасный момент теряется соединение с бд и больше к ней не присоединиться. Сообщения следующие: Jul 14 19:56:43 delta postgres[31135]: [76667-1] LOG: 00000: connection received: host=192.168.1.100 port=45531 Jul 14 19:56:43 delta postgres[31135]: [76667-2] LOCATION: BackendFork, postmaster.c:2474 Jul 14 19:56:43 delta postgres[31135]: [76669-1] LOG: 00000: connection authorized: user=kv_oeso database=okik Jul 14 19:56:43 delta postgres[31135]: [76669-2] LOCATION: BackendFork, postmaster.c:2536 Jul 14 19:56:43 delta postgres[31135]: [76677-1] FATAL: XX000: could not open relation "pg_group_name_index" Jul 14 19:56:43 delta postgres[31135]: [76677-2] LOCATION: relation_openr, heapam.c:603 Пару дней назад было аналогичное, только could not open relation "pg_conversion". Еще было, что сервис postgresql вообще не стартовал Jul 12 18:11:38 delta postgres[2866]: [31-1] LOG: XX000: could not create IPv6 socket: Address family not supported by protocol Jul 12 18:11:38 delta postgres[2866]: [31-2] LOCATION: StreamServerPort, pqcomm.c:311 Jul 12 18:11:38 delta postgres[2866]: [34-1] LOG: XX000: disabling statistics collector for lack of working socket Jul 12 18:11:38 delta postgres[2866]: [34-2] LOCATION: pgstat_init, pgstat.c:282 Jul 12 18:11:38 delta postgres[2871]: [35-1] LOG: 00000: database system was interrupted while in recovery at 2004-07-12 18:09:18 MSD Jul 12 18:11:38 delta postgres[2871]: [35-2] HINT: This probably means that some data is corrupted and you will have to use the last backup for recovery. Jul 12 18:11:38 delta postgres[2871]: [35-3] LOCATION: StartupXLOG, xlog.c:2608 Jul 12 18:11:38 delta postgres[2871]: [36-1] LOG: 00000: checkpoint record is at 4/855D0050 Jul 12 18:11:38 delta postgres[2871]: [36-2] LOCATION: StartupXLOG, xlog.c:2630 Jul 12 18:11:38 delta postgres[2871]: [37-1] LOG: 00000: redo record is at 4/855A9628; undo record is at 0/0; shutdown FALSE Jul 12 18:11:38 delta postgres[2871]: [37-2] LOCATION: StartupXLOG, xlog.c:2655 Jul 12 18:11:38 delta postgres[2871]: [38-1] LOG: 00000: next transaction ID: 9977074; next OID: 4608038 Jul 12 18:11:38 delta postgres[2871]: [38-2] LOCATION: StartupXLOG, xlog.c:2658 Jul 12 18:11:38 delta postgres[2871]: [39-1] LOG: 00000: database system was not properly shut down; automatic recovery in progress Jul 12 18:11:38 delta postgres[2871]: [39-2] LOCATION: StartupXLOG, xlog.c:2707 Jul 12 18:11:38 delta postgres[2871]: [40-1] LOG: 00000: redo starts at 4/855A9628 Jul 12 18:11:38 delta postgres[2871]: [40-2] LOCATION: StartupXLOG, xlog.c:2735 Jul 12 18:11:38 delta postgres[2871]: [41-1] PANIC: XX000: _bt_restore_page: can't add item to page Jul 12 18:11:38 delta postgres[2871]: [41-2] LOCATION: _bt_restore_page, nbtxlog.c:104 Что происходит и что с этим делать? Помогите, пожалуйста! Восстанавливаться из дампов уже устали. ... |
| 15.07.2004, 12:01:04 |
| 15.07.2004, 12:02:07 |
fschk пускали? ... |
| 15.07.2004, 13:25:15 |
Коль скоро валится на индексе (судя по названию :) ) то пробовали ли REINDEX? есть некая вероятность, что в дампе уже поврежденный индекс лежит, поэтому сколько не восстанавливайся... А вообще г-н Vis совершенно точно про fschk вспомнил. Это какгрицца завсегда надо :) ... |
| 15.07.2004, 13:32:19 |
Реиндексация и вакуумирование делается автоматически с периодичностью примерно 20 мин и по логам там все нормально отработало примерно мин. за 3 до потери соединения с БД. У нас 3 инстанса на этом сервере, с одной БД все в порядке, а вот 2 других с вот этой вот одной и той же ошибкой отказались работать. ... |
| 15.07.2004, 13:46:04 |
Стоп, торможу. pg_* - это же системные индексы. Вакуум из-под суперюзверя идет? И кстати: если не секрет, что за зверский проект с реиндексацией каждые 20 минут? ... |
| 15.07.2004, 14:07:58 |
Tany.Что происходит и что с этим делать? Помогите, пожалуйста! Восстанавливаться из дампов уже устали. железо проверьте. диски и память Эриданесть некая вероятность, что в дампе уже поврежденный индекс лежит, поэтому сколько не восстанавливайся... хорошая трава... :) ты никогда для общего развития в дампы заглядывать не пробовал? ... |
| 15.07.2004, 14:13:41 |
есть некая вероятность, что в дампе уже поврежденный индекс лежит, поэтому сколько не восстанавливайся... хорошая трава... :) ты никогда для общего развития в дампы заглядывать не пробовал? :) :) :) Факт - трава супер! Чего-то меня на оракл перекосило :( ... |
| 15.07.2004, 14:51:08 |
Ну вот опять FATAL: could not open relation "pg_shadow_usesysid_index" ... |
| 15.07.2004, 18:59:23 |
Ещё раз: проблемы либо с железом, либо ещё может быть с ОС. Базу стоит поднять на другой машине, а эту как следует протестировать... ... |
| 15.07.2004, 22:54:56 |
Ну на работу хоть не приходи!!! теперь pg_amop_opr_opc_index. Будем перетаскивать все на другую машину( А вообще кто-нибудь с такой ситуацией сталкивался? ... |
| 16.07.2004, 11:03:41 |
на битом железе такое вылазит, что в пору бить заячьей лапкой по шаманскому бубну погоняйте тестами машину... ... |
| 16.07.2004, 19:06:01 |
Ну и вопросик. А как насчет OS? И select version()??? Вообще-то в протоколе вроде ясно написали: LOG: XX000: could not create IPv6 socket: Address family not supported by protocol А вот почему PG пытаелся создавать не IPv4 ? Почему-то у меня стойкое ощущение что это winsock32 заморочки. Чего-то вроде WSAEAFNOSUPPORT. Никогда не надеялся на стабильность этого сакса. Ну а после 2-5 падений на взлете можно уже и не открыть некоторые системные таблички.... Смотри как настроены сетевые интефейсы в твоей ОС. Постгрес полностью полагается на то что ему в этом смысле предлагают. ... |
| 18.07.2004, 17:38:57 |
start [/forum/topic.php?desktop=1&fid=53&tid=2007773]: |
157ms |
38ms |
| others: | 219ms |
| total: | 443ms |
