Resin+jsp+PostgreSQL тест не идет ...
Всем доброго времени сутак!!! Решил попробывать тест автор<%@ page contentType="text/html; charset=windows-1251" %> <%@ page import ="java.net.*" %> <%@ page import ="java.sql.*" %> <HTML> <HEAD> <TITLE> Доступные БД </TITLE> </HEAD> <BODY> <h3>Доступные БД</h3> <% //Загружаем драйвер Class.forName("org.postgresql.Driverr").newInstance(); //Подключаемся к бд Connection conn = DriverManager.getConnection("jdbc:postgresql://localhost:5432/","postgres",""); // Statement stmt = null; ResultSet rs = null; stmt = conn.createStatement(); //Запрос на имеющиеся БД rs = stmt.executeQuery("SHOW DATABASES"); boolean more = rs.next (); while (more) { // Получае значение первой колонки out.print(rs.getString(1)); out.print("<br>"); // Передвигаемся на следующую строку набора данных more = rs.next (); } %> </BODY> </HTML> а мене в ответ автор500 Servlet Exception org.postgresql.util.PSQLException: Connection refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections. at org.postgresql.jdbc1.AbstractJdbc1Connection.openConnection(AbstractJdbc1Connection.java:204) at org.postgresql.Driver.connect(Driver.java:139) at java.sql.DriverManager.getConnection(DriverManager.java:525) at java.sql.DriverManager.getConnection(DriverManager.java:171) at _jsp._test__jsp._jspService(test.jsp:16) at com.caucho.jsp.JavaPage.service(JavaPage.java:60) at com.caucho.jsp.Page.pageservice(Page.java:570) at com.caucho.server.dispatch.PageFilterChain.doFilter(PageFilterChain.java:159) at com.caucho.server.webapp.WebAppFilterChain.doFilter(WebAppFilterChain.java:178) at com.caucho.server.dispatch.ServletInvocation.service(ServletInvocation.java:229) at com.caucho.server.http.HttpRequest.handleRequest(HttpRequest.java:268) at com.caucho.server.port.TcpConnection.run(TcpConnection.java:389) at com.caucho.util.ThreadPool.runTasks(ThreadPool.java:492) at com.caucho.util.ThreadPool.run(ThreadPool.java:425) at java.lang.Thread.run(Thread.java:595) Ничегог, как видите, не вышло. С прортом и доступам экспериментировал 0 ничего Подскажите где рыть!!! Спасибо всем ... |
| 18.05.2006, 23:18 |
1. newInstance() в данном случае писать не обязательно. 2. Попробуй в строку соединения написать jdbc:postgresql://localhost:5432/ template1 3. Пароля на БД точно нет? ====================== - Я подхожу к клетке с медведем панда... Видите, какие у него черные круги под глазами?! Медведь панда как бы всем своим видом говорит нам: "Не бухайте!" ====================== ... |
| 19.05.2006, 09:13 |
Оноже тебе четко написало: org.postgresql.util.PSQLException: Connection refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections. Проверяй Хост, порт, юзер, пасворд, дб. Проверь pg_hba.conf. У тебя слокального хоста вообще скажем PgAdmin-ом конектится??? ... |
| 19.05.2006, 10:42 |
Еще обрати внимание на строку из своего кода Class.forName("org.postgresql.Driverr").newInstance(); слово Driver пишется с 1-й r ... |
| 19.05.2006, 10:44 |
Gold FishЕще обрати внимание на строку из своего кода Class.forName("org.postgresql.Driverr").newInstance(); слово Driver пишется с 1-й r 1. Это очепятка. В оригинале все О.К. 2. С самого сервера вхожу под юзерам postgre (предварительно su - postgre ) без проблем. ------------------------ В pg_hba.conf: host all all 127.0.0.1 255.255.255.255 trust host all all 192.126.0.1/10 255.255.255.255 trust Вроде все кака нуна ?????????? ... |
| 21.05.2006, 09:44 |
С самого сервера проверь вот так: psql -U postgres -h IPАдресМоегоСервера template1 -h - вынуждает терминал использовать не Unix-domain sockets а TCP/IP sockets.... И не помешет перепроверить правила файрвола. P.S su делать нафиг не нужно. Неплохо бы глянуть еще раз в postgresql.conf.... ты указал там какой интерфейс слушает postmaster? По умолчанию соединения TCP/IP во всех версиях постгреса отключены. ... |
| 21.05.2006, 18:45 |
start [/forum/topic.php?desktop=1&fid=53&tid=2006373]: |
46ms |
| others: | 218ms |
| total: | 319ms |
