FATAL: connection limit exceeded for non-superusers
Как лечить сабж? ... |
| 29.05.2006, 11:54 |
Значение параметра в файле postgresql.conf: max_connections (integer) Determines the maximum number of concurrent connections to the database server. The default is typically 100, but may be less if your kernel settings will not support it (as determined during initdb). This parameter can only be set at server start. ... |
| 29.05.2006, 12:24 |
start [/forum/topic.php?desktop=1&fid=53&tid=2006349]: |
48ms |
27ms |
| others: | 224ms |
| total: | 329ms |
