PostgreeSQL -> Hibernate обратный маппинг
Есть БазаДанных в Postgree, требуеться из таблиц получить маппинг hibernate-компонентов. У кого-нибудь есть соображ. как это сделать? Заранее сенкс, Владимир. ... |
| 31.08.2006, 14:01 |
hibernate referenceThe Hibernate Tools currently include plugins for the Eclipse IDE as well as Ant tasks for reverse engineering of existing databases: ... • Development Wizards: Several wizards are provided with the Hibernate Eclipse tools; you can use a wizard to quickly generate Hibernate configuration (cfg.xml) files, or you may even completely reverse engineer an existing database schema into POJO source files and Hibernate mapping files. The reverse engineering wizard supports customizable templates. Please refer to the Hibernate Tools package and it's documentation for more information. ... |
| 31.08.2006, 14:41 |
start [/forum/topic.php?desktop=1&fid=53&tid=2006122]: |
76ms |
49ms |
| others: | 245ms |
| total: | 420ms |
