Проблем с JDBC
Выполнял запрос SELECT tb_inv_header.pos_id, tb_inv_detail.invd_amount as fld_INVD_AMOUNT, tb_article.art_name as fld_ART_NAME, tb_articlegroup.grpname as fld_GRPNAME, tb_pricemodificator.prm_name as fld_PRM_NAME, tb_article.art_id as fld_ART_ID, tb_inv_detail.invd_price_per as fld_INVD_PRICE_PER, tb_inv_detail.invd_price_complete as fld_INVD_PRICE_COMPLETE FROM tb_inv_header Inner Join tb_inv_detail ON tb_inv_header.invh_id = tb_inv_detail.invh_id Inner Join tb_article ON tb_inv_detail.id = tb_article.id Inner Join tb_articlegroup ON tb_article.grpid = tb_articlegroup.grpid left Join tb_pricemodificator ON tb_inv_detail.prm_id = tb_pricemodificator.prm_id v pgAdmin III работает когда выполняю из Java, проблем: ERROR: relation "tb_inv_header" does not exist at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:1512) at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1297) at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:188) at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:437) at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:339) at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:238) .... код создания таблиц: CREATE TABLE tb_inv_detail ( invd_id int8 NOT NULL, invd_ordernr int8, invh_id int8, id int4, invd_price_per float8, invd_price_complete float8, prm_id int4, invd_amount int4, invd_comment varchar(256), CONSTRAINT tb_inv_detail_pkey PRIMARY KEY (invd_id), CONSTRAINT fk_invdet_art FOREIGN KEY (id) REFERENCES tb_article (id) MATCH SIMPLE ON UPDATE NO ACTION ON DELETE NO ACTION, CONSTRAINT fk_invdet_invh FOREIGN KEY (invh_id) REFERENCES tb_inv_header (invh_id) MATCH SIMPLE ON UPDATE NO ACTION ON DELETE NO ACTION, CONSTRAINT fk_invdet_pm FOREIGN KEY (prm_id) REFERENCES tb_pricemodificator (prm_id) MATCH SIMPLE ON UPDATE NO ACTION ON DELETE NO ACTION ) WITHOUT OIDS; ALTER TABLE tb_inv_detail OWNER TO dimo; CREATE TABLE tb_inv_header ( invh_id int8 NOT NULL, invh_number varchar(25), invh_crea_date timestamp, pos_id int4 NOT NULL, usrid int4 NOT NULL, cus_id int4, invh_state float8, invh_pay_type int4, CONSTRAINT tb_inv_header_pkey PRIMARY KEY (invh_id), CONSTRAINT fk5b51152c211c062a FOREIGN KEY (cus_id) REFERENCES tb_customer (cus_id) MATCH SIMPLE ON UPDATE NO ACTION ON DELETE NO ACTION, CONSTRAINT fk_invh_pos FOREIGN KEY (pos_id) REFERENCES tb_pos (pos_id) MATCH SIMPLE ON UPDATE NO ACTION ON DELETE NO ACTION, CONSTRAINT fk_invh_usr FOREIGN KEY (usrid) REFERENCES tb_user (usrid) MATCH SIMPLE ON UPDATE NO ACTION ON DELETE NO ACTION, CONSTRAINT tb_inv_header_invh_number_key UNIQUE (invh_number) ) WITHOUT OIDS; ALTER TABLE tb_inv_header OWNER TO dimo; ... |
| 07.11.2006, 22:32 |
Проблем с JDBC
ето похоже глюк. (предполагаю в JDBC драйвере) Postgres 8.1 для Windows ... |
| 08.11.2006, 13:34 |
Проблем с JDBC
connection parameters для пгадмина и для jdbc одинаковые? ... |
| 08.11.2006, 13:46 |
Проблем с JDBC
подключение к одной и той же БД ... |
| 08.11.2006, 14:42 |
start [/forum/topic.php?desktop=1&fid=53&tid=2005973]: |
43ms |
56ms |
| others: | 274ms |
| total: | 427ms |
