Можно ли сдампить ТОЛЬКО функции из БД?
Привет. Вот описание pd_dump: General options: -f, --file=FILENAME output file name -F, --format=c|t|p output file format (custom, tar, plain text) -i, --ignore-version proceed even when server version mismatches pg_dump version -v, --verbose verbose mode -Z, --compress=0-9 compression level for compressed formats --help show this help, then exit --version output version information, then exit Options controlling the output content: -a, --data-only dump only the data, not the schema -c, --clean clean (drop) schema prior to create -C, --create include commands to create database in dump -d, --inserts dump data as INSERT, rather than COPY, commands -D, --column-inserts dump data as INSERT commands with column names -E, --encoding=ENCODING dump the data in encoding ENCODING -n, --schema=SCHEMA dump the named schema only -o, --oids include OIDs in dump -O, --no-owner skip restoration of object ownership in plain text format -s, --schema-only dump only the schema, no data -S, --superuser=NAME specify the superuser user name to use in plain text format -t, --table=TABLE dump the named table only -x, --no-privileges do not dump privileges (grant/revoke) -X disable-dollar-quoting, --disable-dollar-quoting disable dollar quoting, use SQL standard quoting -X disable-triggers, --disable-triggers disable triggers during data-only restore -X use-set-session-authorization, --use-set-session-authorization use SESSION AUTHORIZATION commands instead of OWNER TO commands Connection options: -h, --host=HOSTNAME database server host or socket directory -p, --port=PORT database server port number -U, --username=NAME connect as specified database user -W, --password force password prompt (should happen automatically) Может я не увидел. Но не нашел как указать Постгресу сдампить ТОЛЬКО функции. Таблицы и пр. дампить не надо. Можно это сделать? ... |
| 08.12.2006, 10:07 |
Это бессмысленное занятие. Естественно, что таких ключей в pg_dump нет. ... |
| 08.12.2006, 10:42 |
PostgreSQL начинающийЭто бессмысленное занятие. Естественно, что таких ключей в pg_dump нет. Спасибо. Успокоил. А я думал, что бессымсленное занятие - это выбирать из дамп-файла размером 210 Мб отдельно дамп функций. ... |
| 08.12.2006, 11:01 |
сделай дамп схемы без данных, и выреж оттуда функции ... |
| 08.12.2006, 11:03 |
st_sergсделай дамп схемы без данных, и выреж оттуда функции Согласен это самый прямой способ. Хотелось как-то лучше, но видимо никак :/ ... |
| 08.12.2006, 11:22 |
> А я думал Ошибался. Не переживай, бывает. Определение функций как правило бессмысленно без определения других объектов базы данных. Поэтому незачем включать ненужную опцию в дамп. ... |
| 08.12.2006, 11:29 |
Я фунуции извлекал EMS PostgreSQL Manager.. Там такое можно. ... |
| 08.12.2006, 13:04 |
посмотри в сторону dbwrench делает реверс БД включая функции ... |
| 08.12.2006, 17:05 |
start [/forum/topic.php?desktop=1&fid=53&tid=2005869]: |
42ms |
| others: | 252ms |
| total: | 355ms |
