Что-то не пойму c SQL в PG 8.2.1
Пишу Код: plaintext получаю 40 (без distinct 36 записей по 40). Пишу Код: plaintext получаю 36 записей айдишников (правильно). Уточняю запрос Код: plaintext получаю 36 записей по 1. а собственно COUNT должен записи считать вроде. В чем я не прав? ... |
| 10.01.2007, 12:38 |
Все дело в GROUP BY Дока GROUP BY will condense into a single row all selected rows that share the same values for the grouped expressions. expression can be an input column name, or the name or ordinal number of an output column (SELECT list item), or an arbitrary expression formed from input-column values. In case of ambiguity, a GROUP BY name will be interpreted as an input-column name rather than an output column name. Aggregate functions, if any are used, are computed across all rows making up each group, producing a separate value for each group (whereas without GROUP BY, an aggregate produces a single value computed across all the selected rows). When GROUP BY is present, it is not valid for the SELECT list expressions to refer to ungrouped columns except within aggregate functions, since there would be more than one possible value to return for an ungrouped column. т.е. Агрегационные функции работают отдельно для каждой группы. ... |
| 10.01.2007, 12:56 |
start [/forum/topic.php?desktop=1&fid=53&tid=2005814]: |
34ms |
25ms |
| others: | 242ms |
| total: | 333ms |
