postgresql7.4 и FreeBSD6 проблемы
(jail)[root] /usr/local/pgsql > su -l pgsql -c "initdb -D /usr/local/pgsql/data" The files belonging to this database system will be owned by user "pgsql". This user must also own the server process. The database cluster will be initialized with locale C. creating directory /usr/local/pgsql/data... ok creating directory /usr/local/pgsql/data/base... ok creating directory /usr/local/pgsql/data/global... ok creating directory /usr/local/pgsql/data/pg_xlog... ok creating directory /usr/local/pgsql/data/pg_clog... ok selecting default max_connections... 10 selecting default shared_buffers... 50 creating configuration files... ok creating template1 database in /usr/local/pgsql/data/base/1... FATAL: could not create shared memory segment: Function not implemented DETAIL: Failed system call was shmget(key=1, size=1081344, 03600). initdb: failed initdb: removing data directory "/usr/local/pgsql/data" почему ??????????????????????????????????????????????????????? [root] /home/joker > cat /usr/src/sys/i386/conf/web6 | grep SYSVSHM options SYSVSHM # SYSV-style shared memory [root] /home/joker > cat /usr/src/sys/i386/conf/web6 | grep SYSVMSG options SYSVMSG # SYSV-style message queues [root] /home/joker > cat /usr/src/sys/i386/conf/web6 | grep SYSVSEM options SYSVSEM # SYSV-style semaphores (jail)[root] /home/joker > uname -a FreeBSD www.hardart.local 6.0-RELEASE-p3 FreeBSD 6.0-RELEASE-p3 #0: Wed Jan 18 17:28:11 MSK 2006 joker@bsdguru.hardart.local:/usr/obj/usr/src/sys/web6 i386 (jail)[root] /home/joker > pkg_info | grep postgr postgresql-client-7.4.11 PostgreSQL database (client) postgresql-server-7.4.11 The most advanced open-source database available anywhere ... |
| 24.01.2006, 10:52 |
вопрос снят спасибО! ... |
| 24.01.2006, 11:10 |
start [/forum/topic.php?desktop=1&fid=53&tid=2005400]: |
81ms |
42ms |
| others: | 251ms |
| total: | 425ms |
