как сделать инсерт в линкнутый сервер PG
в MSSQL Добавил линкнутый сервер postgresql 8.2. такой селект не работает: select * from PGDBC.m.public.anchors; такой работает: select * from openquery(PGDBC,'select * from anchors;'); Такой insert не рабоатет: insert into PGDBC.m.[public].anchors(anchor_stamp) values(0); ---------------- Msg 7399, Level 16, State 1, Line 1 The OLE DB provider "MSDASQL" for linked server "PGDBC" reported an error. The provider did not give any information about the error. Msg 7343, Level 16, State 2, Line 1 The OLE DB provider "MSDASQL" for linked server "PGDBC" could not INSERT INTO table "[PGDBC].[m].[public].[anchors]". Unknown provider error. ... |
| 19.08.2007, 17:36 |
Код: plaintext ... |
| 19.08.2007, 18:14 |
drunk2 Код: plaintext вы пробовали такой синтаксис? так выбирает: select * from openquery(PGDBC,'select anchor_stamp,anchor_stamp_2 from anchors;') так не вставляет: insert openquery(PGDBC,'select anchor_stamp,anchor_stamp_2 from anchors;') values(0,1) Msg 7399, Level 16, State 1, Line 1 The OLE DB provider "MSDASQL" for linked server "PGDBC" reported an error. The provider did not give any information about the error. Msg 7343, Level 16, State 2, Line 1 The OLE DB provider "MSDASQL" for linked server "PGDBC" could not INSERT INTO table "[MSDASQL]". Unknown provider error. ... |
| 19.08.2007, 18:28 |
start [/forum/topic.php?desktop=1&fid=53&tid=2005142]: |
41ms |
52ms |
| others: | 209ms |
| total: | 347ms |
