Почему рухнула база
База называется rabota. Остановился сервис. Сервис postgresql удалось запустить только плосле создания пустых файлов (342675). В чём была причина их отсутствия? Помогите разобраться господа профи. В логах следущее: 2008-03-06 22:46:36 LOG: autovacuum: processing database "rabota" 2008-03-06 22:46:37 FATAL: database "test" does not exist 2008-03-06 22:46:38 FATAL: database "basa" does not exist 2008-03-06 22:46:39 FATAL: database "nev" does not exist 2008-03-06 22:46:40 FATAL: database "aaa41" does not exist 2008-03-06 22:46:42 FATAL: database "avtoservis" does not exist 2008-03-06 22:46:43 FATAL: database "16" does not exist 2008-03-06 22:47:43 LOG: autovacuum: processing database "231207" 2008-03-06 22:47:44 FATAL: database "test" does not exist 2008-03-06 22:47:45 FATAL: database "basa" does not exist 2008-03-06 22:47:46 FATAL: database "nev" does not exist 2008-03-06 22:47:48 FATAL: database "aaa41" does not exist 2008-03-06 22:47:48 FATAL: could not access status of transaction 68343756 2008-03-06 22:47:48 DETAIL: could not open file "pg_clog/0041": Invalid argument 2008-03-06 22:47:49 LOG: server process (PID 2748) was terminated by signal 1 2008-03-06 22:47:49 LOG: terminating any other active server processes 2008-03-06 22:47:49 WARNING: terminating connection because of crash of another server process 2008-03-06 22:47:49 DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory. 2008-03-06 22:47:49 HINT: In a moment you should be able to reconnect to the database and repeat your command. 2008-03-06 22:47:49 LOG: all server processes terminated; reinitializing 2008-03-06 22:47:49 LOG: database system was interrupted at 2008-03-06 22:34:05 Московское время (зима) 2008-03-06 22:47:49 LOG: checkpoint record is at 5/A52A6D70 2008-03-06 22:47:49 LOG: redo record is at 5/A52A6D70; undo record is at 0/0; shutdown FALSE 2008-03-06 22:47:49 LOG: next transaction ID: 69194372; next OID: 350646 2008-03-06 22:47:49 LOG: next MultiXactId: 1; next MultiXactOffset: 0 2008-03-06 22:47:49 LOG: database system was not properly shut down; automatic recovery in progress 2008-03-06 22:47:49 LOG: redo starts at 5/A52A6DB8 2008-03-06 22:47:49 PANIC: could not open relation 1663/16403/342675: No such file or directory abnormal program termination 2008-03-06 22:47:49 LOG: startup process (PID 2132) was terminated by signal 3 2008-03-06 22:47:49 LOG: aborting startup due to startup process failure 2008-03-06 22:47:49 LOG: logger shutting down ... |
| 07.03.2008, 13:08 |
Почему рухнула база
жесткие диски иногда ломаются, в файловые системы вкрадываются ошибки. Может у вас серв выключился в нештатном режиме, может винт "сыпется" etc. ... |
| 07.03.2008, 16:52 |
Почему рухнула база
santaboy: у вас 1С? ... |
| 07.03.2008, 22:43 |
Почему рухнула база
У Вас Виндовс наверное лицензионный? В этом то и беда. ... |
| 07.03.2008, 23:35 |
Почему рухнула база
стоит 1с, виндовс лицензионный сервер 2000 ... |
| 31.03.2008, 14:24 |
Почему рухнула база
недавно опять остановилась служба, в логах следующее: 2008-03-28 23:09:53 LOG: could not receive data from client: Подключение не установлено, т.к. конечный компьютер отверг запрос на подключение. 2008-03-28 23:09:53 LOG: unexpected EOF on client connection 2008-03-28 23:09:53 FATAL: could not access status of transaction 92662097 2008-03-28 23:09:53 DETAIL: could not open file "pg_clog/0058": Invalid argument 2008-03-28 23:09:53 FATAL: could not access status of transaction 92757501 2008-03-28 23:09:53 DETAIL: could not open file "pg_clog/0058": Invalid argument 2008-03-28 23:09:53 FATAL: could not access status of transaction 92714249 2008-03-28 23:09:53 DETAIL: could not open file "pg_clog/0058": Invalid argument 2008-03-28 23:09:53 FATAL: could not access status of transaction 92783642 2008-03-28 23:09:53 DETAIL: could not open file "pg_clog/0058": Invalid argument 2008-03-28 23:09:53 FATAL: could not access status of transaction 92599971 2008-03-28 23:09:53 DETAIL: could not open file "pg_clog/0058": Invalid argument 2008-03-28 23:09:53 LOG: server process (PID 2588) was terminated by signal 1 2008-03-28 23:09:53 LOG: terminating any other active server processes 2008-03-28 23:09:53 WARNING: terminating connection because of crash of another server process 2008-03-28 23:09:53 DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory. 2008-03-28 23:09:53 HINT: In a moment you should be able to reconnect to the database and repeat your command. 2008-03-28 23:09:53 LOG: all server processes terminated; reinitializing 2008-03-28 23:09:53 LOG: database system was interrupted at 2008-03-28 23:08:18 Московское время (зима) 2008-03-28 23:09:53 LOG: checkpoint record is at 8/1C42ADC8 2008-03-28 23:09:53 LOG: redo record is at 8/1C42ADC8; undo record is at 0/0; shutdown FALSE 2008-03-28 23:09:53 LOG: next transaction ID: 92814171; next OID: 434061 2008-03-28 23:09:53 LOG: next MultiXactId: 1; next MultiXactOffset: 0 2008-03-28 23:09:53 LOG: database system was not properly shut down; automatic recovery in progress 2008-03-28 23:09:53 LOG: redo starts at 8/1C42AE10 2008-03-28 23:09:53 LOG: record with zero length at 8/1C462500 2008-03-28 23:09:53 LOG: redo done at 8/1C462320 2008-03-28 23:09:54 LOG: database system is ready 2008-03-28 23:09:54 LOG: transaction ID wrap limit is 2147484148, limited by database "postgres" На сервере запущена ещё бд DB2, может они конфликтуюут или борютс я за память раз в неделю? ... |
| 31.03.2008, 14:31 |
Почему рухнула база
santaboyНа сервере запущена ещё бд DB2, может они конфликтуюут или борютс я за память раз в неделю?может быть память кончается... может быть у Вас в жёстком диске блин от шпинделя отвалился, а Вы не заметили... %) может быть у Вас антивирус "умный" установлен который блокирует доступ серверу баз данных к его файлам... ... |
| 01.04.2008, 01:31 |
Почему рухнула база
в свойствах папки С:\program f...\postgresql на разрешениях для пользователя postgres стоял запрет на запись, хотя я никаких ограничений ему не ставил ... |
| 08.04.2008, 17:35 |
start [/forum/topic.php?desktop=1&fid=53&tid=2004449]: |
55ms |
25ms |
| others: | 247ms |
| total: | 356ms |
