Ошибка pg_restore
Создал бэкап бд на сервере 8.1 командой Код: plaintext 1. Код: plaintext авторpg_restore: [archiver (db)] error returned by PQputline: server closed the connection unexpectedly This probably means the server terminated abnormally before or while processing the request. в логах автор2008-12-17 09:48:27 MSK LOG: checkpoint record is at 0/5C4D27BC 2008-12-17 09:48:27 MSK LOG: redo record is at 0/5C4D27BC; undo record is at 0/0; shutdown TRUE 2008-12-17 09:48:27 MSK LOG: next transaction ID: 269002; next OID: 10518561 2008-12-17 09:48:27 MSK LOG: next MultiXactId: 1; next MultiXactOffset: 0 2008-12-17 09:48:27 MSK LOG: database system was not properly shut down; automatic recovery in progress 2008-12-17 09:48:28 MSK LOG: redo starts at 0/5C4D2800 2008-12-17 09:48:29 MSK LOG: record with zero length at 0/5FFB5A28 2008-12-17 09:48:29 MSK LOG: redo done at 0/5FFB5688 2008-12-17 09:48:44 MSK LOG: database system is ready 2008-12-17 09:48:44 MSK LOG: transaction ID wrap limit is 2147484146, limited by database "template1" Подскажите что нужно сделать, чтобы восстановился дамп? ... |
| 17.12.2008, 09:56 |
start [/forum/topic.php?desktop=1&fid=53&tid=2003782]: |
41ms |
| others: | 235ms |
| total: | 328ms |
