Не запускается сервер: служба PostgreSQL ... была запущена и затем остановлена
Лог такой: 2014-11-07 11:47:39 MSK LOG: database system was shut down at 2014-11-07 11:25:25 MSK 2014-11-07 11:47:39 MSK LOG: invalid magic number 0000 in log file 8, segment 205, offset 0 2014-11-07 11:47:39 MSK LOG: invalid primary checkpoint record 2014-11-07 11:47:39 MSK LOG: invalid secondary checkpoint record 2014-11-07 11:47:39 MSK PANIC: could not locate a valid checkpoint record This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information. 2014-11-07 11:47:39 MSK LOG: startup process (PID 5228) exited with exit code 3 2014-11-07 11:47:39 MSK LOG: aborting startup due to startup process failure Можно ли что-нибудь сделать? ... |
| 07.11.2014, 11:20:46 |
start [/forum/topic.php?desktop=1&fid=53&tid=1998371]: |
201ms |
29ms |
| others: | 237ms |
| total: | 509ms |
