Переключение master - slave с WAL репликами, отваливается после переключения бывший м
есть postgresql 9.4 Master - Slave , включена WAL async репликация и в общем каталоге archive logs делаю fast -m у master None - Slave делаю promote для slave None - Master и включаю бывший master как slave Slave - Master Но периодически, не всегда, а иногда, бывший master не хочет становится slave, и пишет вот такое в логи: < 2015-07-03 12:32:05.632 MSK >DEBUG: write 0/D0002B0 flush 0/D0002B0 apply 0/D0002B0 < 2015-07-03 12:32:06.223 MSK >DEBUG: forked new backend, pid=42899 socket=10 < 2015-07-03 12:32:06.228 MSK >LOG: statement: select pg_is_in_recovery() < 2015-07-03 12:32:06.231 MSK >DEBUG: server process (PID 42899) exited with exit code 0 < 2015-07-03 12:32:06.299 MSK >DEBUG: forked new backend, pid=42920 socket=10 < 2015-07-03 12:32:06.303 MSK >LOG: statement: select application_name,upper(state),upper(sync_state) from pg_stat_replication < 2015-07-03 12:32:06.307 MSK >DEBUG: server process (PID 42920) exited with exit code 0 < 2015-07-03 12:32:07.350 MSK >DEBUG: hot standby feedback xmin 2002 epoch 0 < 2015-07-03 12:32:07.653 MSK >DEBUG: write 0/D0002B0 flush 0/D0002B0 apply 0/D0002B0 < 2015-07-03 12:32:09.370 MSK >DEBUG: hot standby feedback xmin 2002 epoch 0 < 2015-07-03 12:32:09.673 MSK >DEBUG: write 0/D0002B0 flush 0/D0002B0 apply 0/D0002B0 < 2015-07-03 12:32:11.129 MSK >DEBUG: forked new backend, pid=43319 socket=10 < 2015-07-03 12:32:11.134 MSK >LOG: statement: select pg_is_in_recovery() < 2015-07-03 12:32:11.137 MSK >DEBUG: forked new backend, pid=43321 socket=10 < 2015-07-03 12:32:11.138 MSK >DEBUG: server process (PID 43319) exited with exit code 0 < 2015-07-03 12:32:11.139 MSK >LOG: incomplete startup packet < 2015-07-03 12:32:11.140 MSK >DEBUG: server process (PID 43321) exited with exit code 0 < 2015-07-03 12:32:11.149 MSK >DEBUG: forked new backend, pid=43325 socket=10 < 2015-07-03 12:32:11.154 MSK >LOG: statement: select pg_is_in_recovery() < 2015-07-03 12:32:11.157 MSK >DEBUG: server process (PID 43325) exited with exit code 0 < 2015-07-03 12:32:11.235 MSK >DEBUG: postmaster received signal 2 < 2015-07-03 12:32:11.235 MSK >LOG: received fast shutdown request < 2015-07-03 12:32:11.235 MSK >LOG: aborting any active transactions < 2015-07-03 12:32:11.235 MSK >LOG: autovacuum launcher shutting down < 2015-07-03 12:32:11.238 MSK >LOG: shutting down < 2015-07-03 12:32:11.332 MSK >DEBUG: performing replication slot checkpoint < 2015-07-03 12:32:11.374 MSK >DEBUG: creating and filling new WAL file < 2015-07-03 12:32:11.463 MSK >DEBUG: archived transaction log file "00000002000000000000000D" < 2015-07-03 12:32:11.498 MSK >DEBUG: done creating and filling new WAL file < 2015-07-03 12:32:11.501 MSK >DEBUG: attempting to remove WAL segments older than log file 000000000000000000000000 < 2015-07-03 12:32:11.501 MSK >DEBUG: SlruScanDirectory invoking callback on pg_subtrans/0000 < 2015-07-03 12:32:11.502 MSK >DEBUG: SlruScanDirectory invoking callback on pg_multixact/offsets/0000 < 2015-07-03 12:32:11.502 MSK >DEBUG: SlruScanDirectory invoking callback on pg_multixact/members/0000 < 2015-07-03 12:32:11.503 MSK >DEBUG: SlruScanDirectory invoking callback on pg_multixact/offsets/0000 < 2015-07-03 12:32:11.503 MSK >LOG: database system is shut down < 2015-07-03 12:32:11.508 MSK >DEBUG: writing stats file "pg_stat/global.stat" < 2015-07-03 12:32:11.509 MSK >DEBUG: writing stats file "pg_stat/db_1.stat" < 2015-07-03 12:32:11.517 MSK >DEBUG: removing temporary stats file "pg_stat_tmp/db_1.stat" < 2015-07-03 12:32:11.517 MSK >DEBUG: writing stats file "pg_stat/db_13003.stat" < 2015-07-03 12:32:11.519 MSK >DEBUG: removing temporary stats file "pg_stat_tmp/db_13003.stat" < 2015-07-03 12:32:11.520 MSK >DEBUG: writing stats file "pg_stat/db_0.stat" < 2015-07-03 12:32:11.523 MSK >DEBUG: removing temporary stats file "pg_stat_tmp/db_0.stat" < 2015-07-03 12:32:39.702 MSK >DEBUG: sending replication keepalive < 2015-07-03 12:33:09.703 MSK >LOG: terminating walsender process due to replication timeout < 2015-07-03 12:33:09.704 MSK >DEBUG: server process (PID 32697) exited with exit code 0 < 2015-07-03 12:33:09.705 MSK >DEBUG: cleaning up dynamic shared memory control segment with ID 1681692777 < 2015-07-03 12:33:09.735 MSK >DEBUG: logger shutting down < 2015-07-03 12:34:10.446 MSK >DEBUG: forked new backend, pid=49259 socket=10 < 2015-07-03 12:34:10.446 MSK >FATAL: the database system is starting up < 2015-07-03 12:34:10.447 MSK >LOG: database system was shut down at 2015-07-03 12:32:11 MSK < 2015-07-03 12:34:10.449 MSK >DEBUG: server process (PID 49259) exited with exit code 1 < 2015-07-03 12:34:10.450 MSK >DEBUG: standby_mode = 'on' < 2015-07-03 12:34:10.450 MSK >DEBUG: primary_conninfo = 'host=192.168.111.101 port=5433 user=replication application_name=my_server_name keepalives_idle=60 keepalives_interval=5 keepalives_count=5' < 2015-07-03 12:34:10.450 MSK >DEBUG: restore_command = 'cp /shared_storage/archive_log/%f %p' < 2015-07-03 12:34:10.450 MSK >DEBUG: recovery_target_timeline = latest < 2015-07-03 12:34:10.458 MSK >LOG: restored log file "00000003.history" from archive cp: cannot stat `shared_storage/archive_log/00000004.history': No such file or directory < 2015-07-03 12:34:10.461 MSK >DEBUG: could not restore file "00000004.history" from archive: child process exited with exit code 1 < 2015-07-03 12:34:10.461 MSK >LOG: entering standby mode < 2015-07-03 12:34:10.467 MSK >LOG: restored log file "00000003.history" from archive cp: cannot stat `/shared_storage/archive_log/00000003000000000000000E': No such file or directory < 2015-07-03 12:34:10.473 MSK >DEBUG: could not restore file "00000003000000000000000E" from archive: child process exited with exit code 1 cp: cannot stat `/shared_storage/archive_log/00000002000000000000000E': No such file or directory < 2015-07-03 12:34:10.475 MSK >DEBUG: could not restore file "00000002000000000000000E" from archive: child process exited with exit code 1 < 2015-07-03 12:34:10.478 MSK >DEBUG: checkpoint record is at 0/E000028 < 2015-07-03 12:34:10.478 MSK >FATAL: requested timeline 3 is not a child of this server's history < 2015-07-03 12:34:10.478 MSK >DETAIL: Latest checkpoint is at 0/E000028 on timeline 2, but in the history of the requested timeline, the server forked off from that timeline at 0/E000000. < 2015-07-03 12:34:10.479 MSK >LOG: startup process (PID 49258) exited with exit code 1 < 2015-07-03 12:34:10.479 MSK >LOG: aborting startup due to startup process failure < 2015-07-03 12:34:10.479 MSK >DEBUG: cleaning up dynamic shared memory control segment with ID 1681692777 < 2015-07-03 12:34:10.518 MSK >DEBUG: logger shutting down почему может появляться рассинхрон ? подскажите пожалуйста, в какую сторону смотреть? ... |
| 03.07.2015, 12:52 |
ОлегН, По большому счету такой метод смены master и slave официально НЕ поддерживается (именно потому что не всегда работает). Рекомендуемый метод - перезаливать старый мастер как реплику заново (через rsync это достаточно быстро). Конкретно в вашем случае проблема в < 2015-07-03 12:33:09.703 MSK >LOG: terminating walsender process due to replication timeout то ли репликация оборвалась под конец по сетевым причинам то ли вы promote сделали не дождавшись полного стопа у мастера. В итоге бывший мастер у вас оказался впереди реплики чуток и естественно заново его как реплику подцепить уже не получилось. -- Maxim Boguk www.postgresql-consulting.ru ... |
| 03.07.2015, 13:59 |
Максим, как вы считаете pg_rewind поможет в этом варианте? интересно в 9.5 уже можно будет так переключаться? ... |
| 03.07.2015, 14:39 |
ОлегНМаксим, как вы считаете pg_rewind поможет в этом варианте? интересно в 9.5 уже можно будет так переключаться? Не думаю что pg_rewind поможет. Про 9.5 не знаю, впрочем о поддержке прозрачного switchover я в нем не слышал так что скорее нет. -- Maxim Boguk www.postgresql-consulting.ru ... |
| 03.07.2015, 14:45 |
| 03.07.2015, 15:25 |
http://www.postgresql.org/docs/9.5/static/app-pgrewind.html " A typical scenario is to bring an old master server back online after failover, as a standby that follows the new master. " опасно ... |
| 03.07.2015, 15:29 |
start [/forum/topic.php?desktop=1&fid=53&tid=1997903]: |
166ms |
29ms |
| others: | 213ms |
| total: | 438ms |
