Объясните поведение планировщика
PostgreSQL 9.4.1 on x86_64-pc-linux-gnu psql Table "statistics.company_statistic_pages_by_months_15_03" Column | Type | Modifiers | Storage | Stats target | Description ------------+------------------------+-------------------------------------------------------------------------------------------+----------+--------------+------------- id | bigint | not null default nextval('statistics.company_statistic_pages_by_months_id_seq'::regclass) | plain | | company_id | integer | | plain | | date | date | not null | plain | | page | character varying(200) | not null | extended | | pages | integer | not null default 0 | plain | | Indexes: "s_c_stat_pages_by_months_15_03_company_id_date_idx" btree (company_id, date) Check constraints: "company_statistic_pages_by_months_15_03_date_check" CHECK (date >= '2015-03-01 00:00:00'::timestamp without time zone AND date < '2015-04-01 00:00:00'::timestamp without time zone) Inherits: statistics.company_statistic_pages_by_months psqEXPLAIN ANALYZE SELECT company_id, date, sum(pages) FROM statistics.company_statistic_pages_by_months_15_03 WHERE (date >= '2015-03-01') AND company_id = (99256128) GROUP BY company_id, date; HashAggregate (cost=3798.63..3798.64 rows=1 width=12) (actual time=4.283..4.284 rows=1 loops=1) -> Bitmap Heap Scan on company_statistic_pages_by_months_15_03 (cost=22.43..3791.31 rows=975 width=12) (actual time=0.319..3.024 rows=2404 loops=1) Recheck Cond: ((company_id = 99256128) AND (date >= '2015-03-01'::date)) -> Bitmap Index Scan on s_c_stat_pages_by_months_15_03_company_id_date_idx (cost=0.00..22.19 rows=975 width=0) (actual time=0.319..0.319 rows=2404 loops=1) Index Cond: ((company_id = 99256128) AND (date >= '2015-03-01'::date)) Total runtime: 4.292 ms (6 rows) VS psqEXPLAIN ANALYZE SELECT company_id, date, sum(pages) FROM statistics.company_statistic_pages_by_months_15_03 WHERE (date = '2015-03-01') AND company_id = (99256128) GROUP BY company_id, date; GroupAggregate (cost=22.43..3798.64 rows=1 width=12) (actual time=5.818..5.819 rows=1 loops=1) -> Bitmap Heap Scan on company_statistic_pages_by_months_15_03 (cost=22.43..3791.31 rows=975 width=12) (actual time=0.908..4.612 rows=2404 loops=1) Recheck Cond: ((company_id = 99256128) AND (date = '2015-03-01'::date)) -> Bitmap Index Scan on s_c_stat_pages_by_months_15_03_company_id_date_idx (cost=0.00..22.19 rows=975 width=0) (actual time=0.430..0.430 rows=2404 loops=1) Index Cond: ((company_id = 99256128) AND (date = '2015-03-01'::date)) Total runtime: 5.827 ms (6 rows) Я не понимаю в чем разница для оптимизатора и в реальной стоимости. Почему оптимизатор имея чек не оптимизирует условие ? И это не только не верная стоимость в плане, первый запрос выполняется сильно дольше. Это упрощенный запрос, тут одна партиция, в реальности их много и запрос по диапазону, а по факту по нескольким фикс. датам. Простая оптимизация date >= date1 and date <= date2 -> date in (date1, date2) дает хороший рост перфоманса. почему если есть чек ? Изменение чеков, типов, приведение типов, не помогает. Второй вопрос, почему при сканировании каждой партиции Pg не переписывает условие с учетом наличия чека. Первого или второго было бы достаточно. ... |
| 04.08.2015, 22:11 |
Artemiy, дядя, расскажи на пальцах, чего ты не понимаешь. т.е. какого алгоритма вычислений ты ждёшь, и не можешь добиться. ... |
| 05.08.2015, 00:13 |
Предположу, что речь про неупомянутый/незнатый constraint_exclusion. Хотя по дефолту на упомянутые партиции он включен. ... |
| 05.08.2015, 00:49 |
про constraint_exclusion, он работает. вопрос почему при наличии чек констрейта на таблице date = '2015-01-01'::date, при запросе есть разница в плане и в реальной стоимости и времени выполнения между date = '2015-01-01'::date и date >= '2015-01-01'6::date ? когда у оптимизатора есть все что бы переписать, изменить условие или просто ничего не делать лишнего? чем реальная работа отличается в первом и втором случае? версию кстати не правильно указал PostgreSQL 9.3.5 on x86_64-pc-linux-gnu на 9.4.1 так же. ... |
| 05.08.2015, 06:26 |
Artemiyпро constraint_exclusion, он работает. вопрос почему при наличии чек констрейта на таблице date = '2015-01-01'::date, при запросе есть разница в плане и в реальной стоимости и времени выполнения между date = '2015-01-01'::date и date >= '2015-01-01'6::date ? когда у оптимизатора есть все что бы переписать, изменить условие или просто ничего не делать лишнего? чем реальная работа отличается в первом и втором случае? версию кстати не правильно указал PostgreSQL 9.3.5 on x86_64-pc-linux-gnu на 9.4.1 так же. Наличие check ограничений никак не влияет на оценки селективности в планах запросов, а учитывается только для оценки использовать эту партицию в запросе или нет. Т.е. если решено рассматривать эту таблицу в запросе дальше check ограничения на план никак не влияют (а только условия запроса и гистограммы распределений). В вашем случае более того нет смысла вносить дополнительное условие (вы наверное хотите увидеть date < '2015-04-01 00:00:00') в запрос так как под него заведомо все строки попадают. Если же вы хотите нормальный развернутый анализ ситуации то и приводите реальные примеры так как из вашего примера ничего полезного извлечь кроме вышеприведенных данных нельзя. -- Maxim Boguk www.postgresql-consulting.ru ... |
| 05.08.2015, 06:37 |
Artemiyпро constraint_exclusion, он работает. вопрос почему при наличии чек констрейта на таблице date = '2015-01-01'::date, смешались в кучу кони люди чек то вам чем помешал ? ещё раз -- как оптимизатор должен использовать этот чек, если вы и так уже обратились к партиции, а не ко всему семейству ? Artemiyпри запросе есть разница в плане и в реальной стоимости и времени выполнения между date = '2015-01-01'::date и date >= '2015-01-01'6::date ? когда у оптимизатора есть все что бы переписать, изменить условие или просто ничего не делать лишнего? чем реальная работа отличается в первом и втором случае? <> т.е. вас смутила дразница промеж групп-агрегат и хеш--агрегат ? а то что все данные в месячной табличке -- первым числом -- вас не смутило ? накидайте для теста еще 100500 во второе число, и сравните планы ещё раз -- авось и прояснеет. (а если лома -- прочитайте оценки в первой строке плана. помедитируйте над разницей нижних границ) . ... |
| 05.08.2015, 08:52 |
Artemiyпри наличии чек констрейта на таблице date = '2015-01-01'::dateArtemiyCheck constraints: "company_statistic_pages_by_months_15_03_date_check" CHECK (date >= '2015-03-01 00:00:00'::timestamp without time zone AND date < '2015-04-01 00:00:00'::timestamp without time zone)что там у тебя в наличии после неявного приведения типов... это науке неизвестно. Наука ещё пока не в курсе дела. Асса!!! ... |
| 05.08.2015, 09:24 |
Раз всем не понятно, что я хочу, значит плохо объясняю. Подготовлю данные и напишу нормальный пример. ... |
| 05.08.2015, 13:26 |
psql\d+ statistics.banner_total_by_months; Table "statistics.banner_total_by_months" Column | Type | Modifiers | Storage | Stats target | Descript ion -----------+---------+--------------------------------------------------------------------------------+---------+--------------+--------- ---- id | integer | not null default nextval('statistics.banner_total_by_months_id_seq'::regclass) | plain | | date | date | not null | plain | | banner_id | integer | not null | plain | | rubric_id | integer | not null | plain | | region_id | integer | not null | plain | | hits | integer | not null default 0 | plain | | views | integer | not null default 0 | plain | | Indexes: "banner_total_by_months_pkey" PRIMARY KEY, btree (id) "stat_b_t_m_date_banner_id_rubric_id_region_id" UNIQUE, btree (date, banner_id, rubric_id, region_id) Child tables: statistics.banner_total_by_months_p2015_01, statistics.banner_total_by_months_p2015_02, statistics.banner_total_by_months_p2015_03, statistics.banner_total_by_months_p2015_04, statistics.banner_total_by_months_p2015_05, statistics.banner_total_by_months_p2015_06, statistics.banner_total_by_months_p2015_07, statistics.banner_total_by_months_p2015_08, statistics.banner_total_by_months_p2015_09 \d+ statistics.banner_total_by_months_p2015_07;; Table "statistics.banner_total_by_months_p2015_07" Column | Type | Modifiers | Storage | Stats target | Descript ion -----------+---------+--------------------------------------------------------------------------------+---------+--------------+--------- ---- id | integer | not null default nextval('statistics.banner_total_by_months_id_seq'::regclass) | plain | | date | date | not null | plain | | banner_id | integer | not null | plain | | rubric_id | integer | not null | plain | | region_id | integer | not null | plain | | hits | integer | not null default 0 | plain | | views | integer | not null default 0 | plain | | Indexes: "banner_total_by_months_p2015_07_pkey" PRIMARY KEY, btree (id) "banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx6" UNIQUE, btree (date, banner_id, rubric_id, region_id) Check constraints: "banner_total_by_months_p2015_07_partition_check" CHECK (date = '2015-07-01'::date) Inherits: statistics.banner_total_by_months psqlEXPLAIN ANALYZE SELECT banner_id, date, sum(hits) AS hits, sum(views) AS views FROM statistics.banner_total_by_months WHERE (date >= '2015-01-01' AND date <= '2015-12-31') AND banner_id = (489) GROUP BY banner_id, date; HashAggregate (cost=233385.04..233389.31 rows=427 width=16) (actual time=1606.323..1606.327 rows=3 loops=1) Group Key: banner_total_by_months.banner_id, banner_total_by_months.date -> Append (cost=0.00..233354.07 rows=3097 width=16) (actual time=517.898..1605.974 rows=184 loops=1) -> Seq Scan on banner_total_by_months (cost=0.00..0.00 rows=1 width=16) (actual time=0.002..0.002 rows=0 loops=1) Filter: ((date >= '2015-01-01'::date) AND (date <= '2015-12-31'::date) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_regi_idx on banner_total_by_months_p2015_01 (cost=0 .15..4.25 rows=1 width=16) (actual time=0.006..0.006 rows=0 loops=1) Index Cond: ((date >= '2015-01-01'::date) AND (date <= '2015-12-31'::date) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx1 on banner_total_by_months_p2015_02 (cost=0 .15..4.25 rows=1 width=16) (actual time=0.002..0.002 rows=0 loops=1) Index Cond: ((date >= '2015-01-01'::date) AND (date <= '2015-12-31'::date) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx2 on banner_total_by_months_p2015_03 (cost=0 .15..4.25 rows=1 width=16) (actual time=0.002..0.002 rows=0 loops=1) Index Cond: ((date >= '2015-01-01'::date) AND (date <= '2015-12-31'::date) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx3 on banner_total_by_months_p2015_04 (cost=0 .42..4892.27 rows=155 width=16) (actual time=104.282..104.282 rows=0 loops=1) Index Cond: ((date >= '2015-01-01'::date) AND (date <= '2015-12-31'::date) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx4 on banner_total_by_months_p2015_05 (cost=0 .42..5213.08 rows=126 width=16) (actual time=46.024..46.024 rows=0 loops=1) Index Cond: ((date >= '2015-01-01'::date) AND (date <= '2015-12-31'::date) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx5 on banner_total_by_months_p2015_06 (cost=0 .43..36722.18 rows=650 width=16) (actual time=367.576..393.190 rows=1 loops=1) Index Cond: ((date >= '2015-01-01'::date) AND (date <= '2015-12-31'::date) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx6 on banner_total_by_months_p2015_07 (cost=0 .43..159583.77 rows=1808 width=16) (actual time=323.256..945.077 rows=139 loops=1) Index Cond: ((date >= '2015-01-01'::date) AND (date <= '2015-12-31'::date) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx7 on banner_total_by_months_p2015_08 (cost=0 .43..26925.77 rows=353 width=16) (actual time=51.211..117.297 rows=44 loops=1) Index Cond: ((date >= '2015-01-01'::date) AND (date <= '2015-12-31'::date) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx8 on banner_total_by_months_p2015_09 (cost=0 .15..4.25 rows=1 width=16) (actual time=0.016..0.016 rows=0 loops=1) Index Cond: ((date >= '2015-01-01'::date) AND (date <= '2015-12-31'::date) AND (banner_id = 489)) Planning time: 2.796 ms Execution time: 1606.561 ms (25 rows) VS psql EXPLAIN ANALYZE SELECT banner_id, date, sum(hits) AS hits, sum(views) AS views FROM statistics.banner_total_by_months WHERE (date in ('2015-01-01', '2015-02-01', '2015-03-01', '2015-04-01', '2015-05-01', '2015-06-01', '2015-07-01', '2015-08-01', '2015-09-01', '2015-10-01', '2015-11-01', '2015-12-01')) AND banner_id = (489) GROUP BY banner_id, date; HashAggregate (cost=2474.67..2479.17 rows=450 width=16) (actual time=31.492..31.494 rows=3 loops=1) Group Key: banner_total_by_months.banner_id, banner_total_by_months.date -> Append (cost=0.00..2449.36 rows=2531 width=16) (actual time=14.939..31.314 rows=184 loops=1) -> Seq Scan on banner_total_by_months (cost=0.00..0.00 rows=1 width=16) (actual time=0.002..0.002 rows=0 loops=1) Filter: ((banner_id = 489) AND (date = ANY ('{2015-01-01,2015-02-01,2015-03-01,2015-04-01,2015-05-01,2015-06-01,2015-07-01 ,2015-08-01,2015-09-01,2015-10-01,2015-11-01,2015-12-01}'::date[]))) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_regi_idx on banner_total_by_months_p2015_01 (cost=0 .16..5.97 rows=1 width=16) (actual time=0.014..0.014 rows=0 loops=1) Index Cond: ((date = ANY ('{2015-01-01,2015-02-01,2015-03-01,2015-04-01,2015-05-01,2015-06-01,2015-07-01,2015-08-01,2015-0 9-01,2015-10-01,2015-11-01,2015-12-01}'::date[])) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx1 on banner_total_by_months_p2015_02 (cost=0 .16..5.97 rows=1 width=16) (actual time=0.009..0.009 rows=0 loops=1) Index Cond: ((date = ANY ('{2015-01-01,2015-02-01,2015-03-01,2015-04-01,2015-05-01,2015-06-01,2015-07-01,2015-08-01,2015-0 9-01,2015-10-01,2015-11-01,2015-12-01}'::date[])) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx2 on banner_total_by_months_p2015_03 (cost=0 .16..5.97 rows=1 width=16) (actual time=0.008..0.008 rows=0 loops=1) Index Cond: ((date = ANY ('{2015-01-01,2015-02-01,2015-03-01,2015-04-01,2015-05-01,2015-06-01,2015-07-01,2015-08-01,2015-0 9-01,2015-10-01,2015-11-01,2015-12-01}'::date[])) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx3 on banner_total_by_months_p2015_04 (cost=0 .43..164.23 rows=155 width=16) (actual time=5.691..5.691 rows=0 loops=1) Index Cond: ((date = ANY ('{2015-01-01,2015-02-01,2015-03-01,2015-04-01,2015-05-01,2015-06-01,2015-07-01,2015-08-01,2015-0 9-01,2015-10-01,2015-11-01,2015-12-01}'::date[])) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx4 on banner_total_by_months_p2015_05 (cost=0 .43..141.70 rows=126 width=16) (actual time=0.067..0.067 rows=0 loops=1) Index Cond: ((date = ANY ('{2015-01-01,2015-02-01,2015-03-01,2015-04-01,2015-05-01,2015-06-01,2015-07-01,2015-08-01,2015-0 9-01,2015-10-01,2015-11-01,2015-12-01}'::date[])) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx5 on banner_total_by_months_p2015_06 (cost=0 .44..612.94 rows=650 width=16) (actual time=9.145..11.566 rows=1 loops=1) Index Cond: ((date = ANY ('{2015-01-01,2015-02-01,2015-03-01,2015-04-01,2015-05-01,2015-06-01,2015-07-01,2015-08-01,2015-0 9-01,2015-10-01,2015-11-01,2015-12-01}'::date[])) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx6 on banner_total_by_months_p2015_07 (cost=0 .44..1165.45 rows=1242 width=16) (actual time=2.975..13.245 rows=139 loops=1) Index Cond: ((date = ANY ('{2015-01-01,2015-02-01,2015-03-01,2015-04-01,2015-05-01,2015-06-01,2015-07-01,2015-08-01,2015-0 9-01,2015-10-01,2015-11-01,2015-12-01}'::date[])) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx7 on banner_total_by_months_p2015_08 (cost=0 .44..341.15 rows=353 width=16) (actual time=0.079..0.648 rows=44 loops=1) Index Cond: ((date = ANY ('{2015-01-01,2015-02-01,2015-03-01,2015-04-01,2015-05-01,2015-06-01,2015-07-01,2015-08-01,2015-0 9-01,2015-10-01,2015-11-01,2015-12-01}'::date[])) AND (banner_id = 489)) -> Index Scan using banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx8 on banner_total_by_months_p2015_09 (cost=0 .16..5.97 rows=1 width=16) (actual time=0.012..0.012 rows=0 loops=1) Index Cond: ((date = ANY ('{2015-01-01,2015-02-01,2015-03-01,2015-04-01,2015-05-01,2015-06-01,2015-07-01,2015-08-01,2015-0 9-01,2015-10-01,2015-11-01,2015-12-01}'::date[])) AND (banner_id = 489)) Planning time: 1.942 ms Execution time: 31.746 ms вопросы: - чем по выполняемой работе, запрос 1 отличается от запроса 2 ? - почему Pg сам не оптимизирует запрос 1 до 2 при наличии чек констрейтов на партициях, которые говорят что в таблице данные только за одну дату? тоже самое происходит при запросе к конкретной партиции по простому условию, запрос = '2015-07-01'::date сильно отличается от >= '2015-07-01'::date, хотя результат один и при наличии чек констрейта я ожидаю, что оптимизатор упростит выражение до =. Я как понимаю он не умеет такую оптимизацию делать. Но чем реально по работе запрос 1 отличается от запроса 2? ... |
| 05.08.2015, 19:55 |
Artemiy Код: psql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. Код: psql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. VS Код: psql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. вопросы: - чем по выполняемой работе, запрос 1 отличается от запроса 2 ? - почему Pg сам не оптимизирует запрос 1 до 2 при наличии чек констрейтов на партициях, которые говорят что в таблице данные только за одну дату? тоже самое происходит при запросе к конкретной партиции по простому условию, запрос = '2015-07-01'::date сильно отличается от >= '2015-07-01'::date, хотя результат один и при наличии чек констрейта я ожидаю, что оптимизатор упростит выражение до =. Я как понимаю он не умеет такую оптимизацию делать. Но чем реально по работе запрос 1 отличается от запроса 2? 1. поправил. 2. приведите буфферсы, для ясности. 3. очевидно, что вам надо поменять date и banner в индексе местами для 1-го запроса. Или явно перечислить гребенку дней. Что и сделано во 2-м. (обход алфавитных указателей по первым буквам вам рассказывать не надо ?) "модератору" айяйяй -- диагноз был поставлен верно. больной упоротствует, что ограничение должно приниматься во внимание где-то , кроме выбора партиции. ... |
| 05.08.2015, 20:58 |
Artemiy, Как вам уже написали планировщик использует check ТОЛЬКО для выбора подходящих партиций. Дальше про любые check он забывает и начинает использовать те условия которые вы написали в запросе к каждой из подобранных партиций. На всякий случай приведите примеры explain (analyze, costs, buffers, timing) для обоих версий запроса. Возможно у вас играю роль эффекты кеширования а не условий запроса. PS: короткий тест если первую (медленную) версию запроса выполнить несколько раз подряд то 2й и далее разы быстрее не становятся? -- Maxim Boguk www.postgresql-consulting.ru ... |
| 05.08.2015, 21:36 |
чуть порезал условия, выполнил несколько раз, выбрал самый быстрый вариант. Код: sql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. взят самый медленный результат, быстрый 2 мс Код: sql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. ... |
| 06.08.2015, 06:33 |
Artemiy, Planning time: 126.434 ms а вот это очень интересно. можно показать план (точнее интересно время планирования) этого запроса с set enable_mergejoin = off ? ... |
| 06.08.2015, 08:06 |
Artemiy, В общем отличие судя по всему в механизмах обхода индекса (a,b) для условий a= and b= (ваш быстрый вариант) и a>=С1 and a<=С2 and b= (ваш медленный вариант) При том что реально попадают под условия одни и теже строки. Я бы порекомендовал попробовать исходя из: "banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx6" UNIQUE, btree (date, banner_id, rubric_id, region_id) при наличии: Check constraints: "banner_total_by_months_p2015_07_partition_check" CHECK (date = '2015-07-01'::date) Убрать константное поле date из UNIQUE и сделать вместо "banner_total_by_months_p2015__date_banner_id_rubric_id_reg_idx6" UNIQUE, btree (date, banner_id, rubric_id, region_id) другой индекс "banner_total_by_months_p2015__banner_id_rubric_id_reg_idx6" UNIQUE, btree (banner_id, rubric_id, region_id) (он будет компактнее и скорее всего решит ваши вопросы с производительностью для обоих версий запроса). -- Maxim Boguk www.postgresql-consulting.ru ... |
| 06.08.2015, 08:16 |
Maxim BogukArtemiy, В общем отличие судя по всему в механизмах обхода индекса (a,b) для условий a= and b= (ваш быстрый вариант) и a>=С1 and a<=С2 and b= (ваш медленный вариант) При том что реально попадают под условия одни и теже строки. <> похоже да похоже, та же болезнь, что и при подсчете дистинкта по сильно вырожденному значению при точном наборе префикса читается Buffers: shared hit=185 read=312 страниц [индекса + фильтрата] а при точном знании только второго Buffers: shared hit=173 read=49116 (фильтрата у нас столько же -- значит индекса читается больше) {да, памяти у ТС мало на сервере, или же кеш очень быстро вытесняют} -- при таком раскладе вообще удивительно, что index scan, а не full scan выбран. (был бы hits в хвосте индекса -- была бы надежда на IOS, а тут -- приходится дублировать все отфильтрованные чтения). Или все же какая-то оптимизация там есть, но все равно читается много лишнего из индексов. ... |
| 06.08.2015, 08:39 |
Спасибо всем добавили доп индекс по баннер_ид, регион_ид пока, будем смотреть. Основной индекс не меняли по некоторым причинам: констрейт изменить затруднительно их создает partman (библ. для партиционирования), сложно менять уникальный индекс на куче партиций, может позже сделаю. я понимаю что этот индекс избыточен. по поводу: set enable_mergejoin = off попробовал, но видимо после первого выполнения запроса все закешировалось и все быстро было и планинг и выполнение, ничего нового в плане не увидел. план сохранил. если сильно надо могу еще попробовать. ... |
| 06.08.2015, 19:10 |
AlexiusArtemiy, Planning time: 126.434 ms а вот это очень интересно. можно показать план (точнее интересно время планирования) этого запроса с set enable_mergejoin = off ? издержики большого количества партиций ... |
| 07.08.2015, 14:55 |
start [/forum/topic.php?desktop=1&fid=53&tid=1997835]: |
61ms |
42ms |
| others: | 249ms |
| total: | 390ms |
