Ошибка при старте сервера heap_delete_redo: invalid lp
В логах пишет, объясните что значит? PANIC: heap_delete_redo: invalid lp CONTEXT: xlog redo delete: rel 1663/170492837/218105214; tid 74/63 LOG: startup process (PID 11156) was terminated by signal 6: Aborted ... |
| 19.08.2015, 13:22 |
esteem2010В логах пишет, объясните что значит? PANIC: heap_delete_redo: invalid lp CONTEXT: xlog redo delete: rel 1663/170492837/218105214; tid 74/63 LOG: startup process (PID 11156) was terminated by signal 6: Aborted база побита на уровне файлов. Рекомендация - восстановления базы из backup начисто. Как вы это смогли получить? -- Maxim Boguk www.postgresql-consulting.ru ... |
| 19.08.2015, 13:26 |
Maxim Bogukesteem2010В логах пишет, объясните что значит? PANIC: heap_delete_redo: invalid lp CONTEXT: xlog redo delete: rel 1663/170492837/218105214; tid 74/63 LOG: startup process (PID 11156) was terminated by signal 6: Aborted база побита на уровне файлов. Рекомендация - восстановления базы из backup начисто. Как вы это смогли получить? -- Maxim Boguk www.postgresql-consulting.ru LOG: database system was interrupted while in recovery at log time 2015-08-19 01:35:07 MSK HINT: If this has occurred more than once some data might be corrupted and you might need to choose an earlier recovery target. LOG: entering standby mode LOG: restored log file "000000010000128C00000017" from archive LOG: restored log file "000000010000128C00000016" from archive LOG: redo starts at 128C/16F929E0 LOG: restored log file "000000010000128C00000017" from archive LOG: restored log file "000000010000128C00000018" from archive LOG: consistent recovery state reached at 128C/18AB8730 LOG: database system is ready to accept read only connections LOG: restored log file "000000010000128C00000019" from archive PANIC: heap_delete_redo: invalid lp CONTEXT: xlog redo delete: rel 1663/170492837/218105214; tid 74/63 LOG: startup process (PID 11156) was terminated by signal 6: Aborted LOG: terminating any other active server processes Полный лог. Основной работает, а этот сервер является репликой и произошел сбой питания более час, ИБП не выдержали.( ... |
| 19.08.2015, 13:54 |
Видно отвалился первый примонтированный диск ( LOG: database system was interrupted while in recovery at log time 2015-08-19 01:35:07 MSK HINT: If this has occurred more than once some data might be corrupted and you might need to choose an earlier recovery target. LOG: could not open tablespace directory "pg_tblspc/1784050/PG_9.0_201008051": Нет такого файла или каталога LOG: entering standby mode LOG: redo starts at 128C/16F929E0 FATAL: could not create directory "pg_tblspc/1784050/PG_9.0_201008051": Отказано в доступе CONTEXT: xlog redo vacuum: rel 1784050/1784616/218441046; blk 340, lastBlockVacuumed 339 LOG: startup process (PID 1930) exited with exit code 1 LOG: terminating any other active server processes LOG: database system was interrupted while in recovery at log time 2015-08-19 01:35:07 MSK HINT: If this has occurred more than once some data might be corrupted and you might need to choose an earlier recovery target. LOG: entering standby mode LOG: redo starts at 128C/16F929E0 LOG: consistent recovery state reached at 128C/18AB8660 LOG: invalid record length at 128C/18AB8660 LOG: database system is ready to accept read only connections LOG: streaming replication successfully connected to primary LOG: invalid record length at 128C/18AB8660 FATAL: terminating walreceiver process due to administrator command LOG: invalid record length at 128C/18AB8660 LOG: invalid record length at 128C/18AB8660 LOG: invalid record length at 128C/18AB8660 LOG: invalid record length at 128C/18AB8660 LOG: invalid record length at 128C/18AB8660 LOG: invalid record length at 128C/18AB8660 LOG: invalid record length at 128C/18AB8660 ... |
| 19.08.2015, 14:07 |
start [/forum/topic.php?desktop=1&fid=53&tid=1997812]: |
159ms |
23ms |
| others: | 194ms |
| total: | 404ms |
