DESCTOP компьютер работает быстрее сервера
Приветствую Вас, уважаемые! Столкнулись с такой проблемой – DESCTOP компьютер работает быстрее сервера. В нашей организации в данный момент под СУБД используется комп с процессором I7, 16 Гб ОЗУ, ОС –AstraLinux. Операционка стоит на HDD, база на SSD, причем pg_xlog на отдельном SSD диске. Сама база размером 120-150 Гигов. Postgresql версии 9.3.4 Настройки Postgresql следующие: listen_addresses = '*' # what IP address(es) to listen on; port = 5432 # (change requires restart) max_connections = 400 # (change requires restart) unix_socket_directories = '/var/run/postgresql' # comma-separated list of directories shared_buffers = 4096MB # min 128kB temp_buffers = 32MB # min 800kB work_mem = 64MB # min 64kB maintenance_work_mem = 2048MB # min 1MB max_stack_depth = 2MB # min 100kB effective_io_concurrency = 1 # 1-1000; 0 disables prefetching wal_level = minimal # minimal, archive, or hot_standby fsync = on # turns forced synchronization on or off synchronous_commit = on # synchronization level; checkpoint_segments = 64 # in logfile segments, min 1, 16MB each checkpoint_timeout = 50min # range 30s-1h checkpoint_completion_target = 0.9 # checkpoint target duration, 0.0 - 1.0 checkpoint_warning = 59s # 0 disables effective_cache_size = 10240MB constraint_exclusion = partition # on, off, or partition log_destination = 'syslog' # Valid values are combinations of log_timezone = 'W-SU' autovacuum = off # Enable autovacuum subprocess? 'on' bytea_output = 'escape' # hex, escape datestyle = 'iso, dmy' timezone = 'W-SU' lc_messages = 'en_US.UTF-8' # locale for system error message lc_monetary = 'ru_RU.UTF-8' # locale for monetary formatting lc_numeric = 'ru_RU.UTF-8' # locale for number formatting lc_time = 'ru_RU.UTF-8' # locale for time formatting default_text_search_config = 'pg_catalog.russian' max_locks_per_transaction = 150 # min 10 online_analyze.threshold = 50 online_analyze.scale_factor = 0.1 online_analyze.enable = off online_analyze.verbose = off online_analyze.min_interval = 10000 online_analyze.table_type = 'temporary' plantuner.fix_empty_table = true В дальнейшем предполагается большой рост базы поэтому был куплен следующий сервер: system x 3850X6, два процессора Xeon E7-4860 2.60Ghz по 12 ядер в каждом, ОЗУ 256 Гб, Операционка стоит на SSD, база временно лежит на двух SSD в RAID0. В дальнейшем база будет лежать на СХД. Настройки Postgresql следующие: listen_addresses = '*' # what IP address(es) to listen on; # comma-separated list of addresses; # defaults to 'localhost'; use '*' for all # (change requires restart) port = 5432 # (change requires restart) max_connections = 400 # (change requires restart) shared_buffers = 32GB # min 128kB temp_buffers = 1GB # min 800kB work_mem = 500MB # min 64kB maintenance_work_mem = 64MB # min 1MB max_stack_depth = 7680kB # min 100kB effective_io_concurrency = 1000 # 1-1000; 0 disables prefetching wal_level = minimal # minimal, archive, or hot_standby fsync = on # turns forced synchronization on or off synchronous_commit = on # synchronization level; checkpoint_segments = 32 # in logfile segments, min 1, 16MB each checkpoint_timeout = 50min # range 30s-1h checkpoint_completion_target = 0.9 # checkpoint target duration, 0.0 - 1.0 checkpoint_warning = 59s # 0 disables constraint_exclusion = partition # on, off, or partition log_destination = 'stderr' # Valid values are combinations of logging_collector = on # Enable capturing of stderr and csvlog log_connections = off log_disconnections = off log_statement = 'all' # none, ddl, mod, all log_timezone = 'W-SU' autovacuum = off # Enable autovacuum subprocess? 'on' bytea_output = 'escape' # hex, escape datestyle = 'iso, dmy' timezone = 'W-SU' lc_messages = 'en_US.UTF-8' # locale for system error message lc_monetary = 'ru_RU.UTF-8' # locale for monetary formatting lc_numeric = 'ru_RU.UTF-8' # locale for number formatting lc_time = 'ru_RU.UTF-8' # locale for time formatting max_locks_per_transaction = 150 # min 10 online_analyze.threshold = 50 online_analyze.scale_factor = 0.1 online_analyze.enable = off online_analyze.verbose = off online_analyze.min_interval = 10000 online_analyze.table_type = 'temporary' plantuner.fix_empty_table = true Для теста на новый сервер pg_dump’ом перенесли базу на новый сервер, позупаскали запросы. И тут ждало огромное разочарование – новый дорогой сервер оказался медленнее DESCTOP компьютера. И чем тяжелее запрос тем разница больше. Для подтвержения вывод pgbench: 1. DESCTOP pgbench pgbench starting vacuum...end. transaction type: TPC-B (sort of) scaling factor: 1000 query mode: simple number of clients: 1 number of threads: 1 number of transactions per client: 10 number of transactions actually processed: 10/10 tps = 710.126402 (including connections establishing) tps = 797.193878 (excluding connections establishing) postgres@C3ZB1A7A1:/root$ pgbench pgbench starting vacuum...end. transaction type: TPC-B (sort of) scaling factor: 1000 query mode: simple number of clients: 1 number of threads: 1 number of transactions per client: 10 number of transactions actually processed: 10/10 tps = 632.991518 (including connections establishing) tps = 710.580544 (excluding connections establishing) select count(*) from pgbench_accounts Первый запуск - 14.000 мс Второй запуск - 12.653 мс 2. Server pgbench pgbench starting vacuum...end. transaction type: TPC-B (sort of) scaling factor: 1000 query mode: simple number of clients: 1 number of threads: 1 number of transactions per client: 10 number of transactions actually processed: 10/10 tps = 495.245642 (including connections establishing) tps = 582.072177 (excluding connections establishing) postgres@C3UH8A1A2:/root$ pgbench pgbench starting vacuum...end. transaction type: TPC-B (sort of) scaling factor: 1000 query mode: simple number of clients: 1 number of threads: 1 number of transactions per client: 10 number of transactions actually processed: 10/10 tps = 459.748977 (including connections establishing) tps = 560.695262 (excluding connections establishing) select count(*) from pgbench_accounts Первый запуск - 11.713 Второй запуск 11.343 Я в «тихом» шоке. Уважаемые знатоки, подскажите в чем может быть проблема? ... |
| 07.12.2015, 08:50 |
очередной "яфшоки" когда же вы все кончитесь ... |
| 07.12.2015, 09:00 |
mgurnitskiy, А вы смотрели, почему система тормозит? vmstat? iostat? Навскидку — у “старого” сервера у вас 4096Мб + 400*64Мб = 29696Мб (shared_beffers + max_connections*work_mem). В наличии у вас только 16Гб из заявленных 30. Если кол-во сессий более 200 — система будет свапиться. Думаю также и на новом железе. Чтобы дальше разбираться с вашим разочарованием, покажите `EXPLAIN (analyze, buffers)` запросов, которые тормозят. ... |
| 07.12.2015, 09:53 |
комп с процессором I7 Xeon E7-4860 2.60Ghz Есть большое подозрения, что у I7 банально тактовая частота выше. Вот и вся разгадка. Как это обычно и бывает. IMHO & AFAIK ... |
| 07.12.2015, 10:18 |
mgurnitskiy, А какой смысл 24 ядерный сервер тестировать в 1 поток? Скорость работы 1 ядра у серверных процессоров уже давно абы не медленнее чем у обычных персоналочных. -- Maxim Boguk www.postgresql-consulting.ru ... |
| 07.12.2015, 11:09 |
mgurnitskiy, авторautovacuum = off # Enable autovacuum subprocess? 'on' ждем еще шокирующих постов. ... |
| 07.12.2015, 12:01 |
Еще раз, добрый день! Постараюсь ответить все. Значит: autovacuum в значении off, потому что "vacuum alalyze" выполняется по cron 4 раза в сутки. "А какой смысл 24 ядерный сервер тестировать в 1 поток? Скорость работы 1 ядра у серверных процессоров уже давно абы не медленнее чем у обычных персоналочных. " А если много сессий только делают Insert, и только одна сессия Select (для отображения). Или расскажите как один select разбить на несколько потоков? На I7 тактовая частота 3,2 Ггц, а у E7 2,6Ггц. Но в Е7 кэши всех уровней больше чем в I7 -не ужели это ни какой роли не играет? Так же хочу выложить план запроса. Для DESCTOP Result (cost=1.20..51679.28 rows=628467 width=56) InitPlan 1 (returns $0) -> Seq Scan on dic_colors dic (cost=0.00..1.20 rows=1 width=8) Filter: (colors_id = 2) -> Append (cost=0.00..42251.08 rows=628467 width=56) -> Seq Scan on ck_o_f4zrikc (cost=0.00..0.00 rows=1 width=56) Filter: ((reg_time > '2015-11-29 00:00:00'::timestamp without time zone) AND (reg_time < '2015-11-29 09:00:00'::timestamp without time zone) AND (zagzfu_npoz = 1) AND (zagzfu_tipz = 71)) -> Index Scan using ck_o_f4zrikc_reg_time_idx20151129 on ck_o_f4zrikc20151129 (cost=0.43..42251.08 rows=628466 width=56) Index Cond: ((reg_time > '2015-11-29 00:00:00'::timestamp without time zone) AND (reg_time < '2015-11-29 09:00:00'::timestamp without time zone)) Filter: ((zagzfu_npoz = 1) AND (zagzfu_tipz = 71)) Для SERVER Result (cost=1.20..52158.60 rows=626550 width=56) InitPlan 1 (returns $0) -> Seq Scan on dic_colors dic (cost=0.00..1.20 rows=1 width=8) Filter: (colors_id = 2) -> Append (cost=0.00..42759.15 rows=626550 width=56) -> Seq Scan on ck_o_f4zrikc (cost=0.00..0.00 rows=1 width=56) Filter: ((reg_time > '2015-11-29 00:00:00'::timestamp without time zone) AND (reg_time < '2015-11-29 09:00:00'::timestamp without time zone) AND (zagzfu_npoz = 1) AND (zagzfu_tipz = 71)) -> Index Scan using ck_o_f4zrikc_reg_time_idx20151129 on ck_o_f4zrikc20151129 (cost=0.43..42759.15 rows=626549 width=56) Index Cond: ((reg_time > '2015-11-29 00:00:00'::timestamp without time zone) AND (reg_time < '2015-11-29 09:00:00'::timestamp without time zone)) Filter: ((zagzfu_npoz = 1) AND (zagzfu_tipz = 71)) Не ужели ни кто не подскажет как разогнать производительность на сервере? ... |
| 07.12.2015, 14:31 |
mgurnitskiyНе ужели ни кто не подскажет как разогнать производительность на сервере? Поставить проц с аналогичной тактовой частотой. У вас с базой будет работать 1 пользователь? Почему вы тестируете 1 потоком? ... |
| 07.12.2015, 14:45 |
mgurnitskiyТак же хочу выложить план запроса. Требуется вывод именно `EXPLAIN (analyze, buffers)`, а не просто `EXPLAIN`. P.S. И да, des k top... ... |
| 07.12.2015, 14:48 |
Вывод EXPLAIN (analyze, buffers) DESKTOP Result (cost=1.20..51679.28 rows=628467 width=56) (actual time=0.036..794.360 rows=622476 loops=1) Buffers: shared hit=21157 InitPlan 1 (returns $0) -> Seq Scan on dic_colors dic (cost=0.00..1.20 rows=1 width=8) (actual time=0.003..0.005 rows=1 loops=1) Filter: (colors_id = 2) Rows Removed by Filter: 15 Buffers: shared hit=1 -> Append (cost=0.00..42251.08 rows=628467 width=56) (actual time=0.025..434.213 rows=622476 loops=1) Buffers: shared hit=21156 -> Seq Scan on ck_o_f4zrikc (cost=0.00..0.00 rows=1 width=56) (actual time=0.000..0.000 rows=0 loops=1) Filter: ((reg_time > '2015-11-29 00:00:00'::timestamp without time zone) AND (reg_time < '2015-11-29 09:00:00'::timestamp without time zone) AND (zagzfu_npoz = 1) AND (zagzfu_tipz = 71)) -> Index Scan using ck_o_f4zrikc_reg_time_idx20151129 on ck_o_f4zrikc20151129 (cost=0.43..42251.08 rows=628466 width=56) (actual time=0.024..381.214 rows=622476 loops=1) Index Cond: ((reg_time > '2015-11-29 00:00:00'::timestamp without time zone) AND (reg_time < '2015-11-29 09:00:00'::timestamp without time zone)) Filter: ((zagzfu_npoz = 1) AND (zagzfu_tipz = 71)) Buffers: shared hit=21156 Total runtime: 823.191 ms SERVER Result (cost=1.20..52158.60 rows=626550 width=56) (actual time=0.029..630.430 rows=622476 loops=1) Buffers: shared hit=21784 InitPlan 1 (returns $0) -> Seq Scan on dic_colors dic (cost=0.00..1.20 rows=1 width=8) (actual time=0.003..0.004 rows=1 loops=1) Filter: (colors_id = 2) Rows Removed by Filter: 15 Buffers: shared hit=1 -> Append (cost=0.00..42759.15 rows=626550 width=56) (actual time=0.019..338.309 rows=622476 loops=1) Buffers: shared hit=21783 -> Seq Scan on ck_o_f4zrikc (cost=0.00..0.00 rows=1 width=56) (actual time=0.001..0.001 rows=0 loops=1) Filter: ((reg_time > '2015-11-29 00:00:00'::timestamp without time zone) AND (reg_time < '2015-11-29 09:00:00'::timestamp without time zone) AND (zagzfu_npoz = 1) AND (zagzfu_tipz = 71)) -> Index Scan using ck_o_f4zrikc_reg_time_idx20151129 on ck_o_f4zrikc20151129 (cost=0.43..42759.15 rows=626549 width=56) (actual time=0.017..289.333 rows=622476 loops=1) Index Cond: ((reg_time > '2015-11-29 00:00:00'::timestamp without time zone) AND (reg_time < '2015-11-29 09:00:00'::timestamp without time zone)) Filter: ((zagzfu_npoz = 1) AND (zagzfu_tipz = 71)) Buffers: shared hit=21783 Total runtime: 654.531 ms Получается, что цена отличается на порядок, а производительность на копейку. Задача для сервера такая: много оборудования заносит данные в базу (т.е. INSERT) и только одно рабочее место (максимум два) будет отображать информацию из базы (тяжелые Select'ы). Поэтому нам очень важно что бы тот поток который будет на select работал быстро. ... |
| 07.12.2015, 15:16 |
mgurnitskiyЗадача для сервера такая: много оборудования заносит данные в базу (т.е. INSERT) и только одно рабочее место (максимум два) будет отображать информацию из базы (тяжелые Select'ы). Поэтому нам очень важно что бы тот поток который будет на select работал быстро.одно рабочее место может читать в несколько смычков в разных потоках клиентского приложения, или в несколько асинхронных запросов -- в одном. обещают помочь вашему горю (параллелить запросы из коробки).как скоро -- неясно. Пока это можно делать руками. Всё для этого есть. но девайс нужен прямой и растущий из нужного места -- хенджоба много. и требует аккуратности. перед тем, как покупать железяку, мозг бы себе купить не забывали ... |
| 07.12.2015, 15:40 |
start [/forum/search_topic.php?author=vun&author_mode=last_posts&do_search=1]: |
155ms |
28ms |
| others: | 782ms |
| total: | 1016ms |
