Форумы / PostgreSQL [игнор отключен] [закрыт для гостей] / Планировщик не использует индекс
    #39486227
kalombo
Использую расширение Postgis. Есть две таблицы:
Код: plsql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
-- 14 тысяч записей
CREATE TABLE public.storagepricingapp_storagelocation
  id integer NOT NULL DEFAULT nextval('storagepricingapp_storagelocation_id_seq'::regclass),
  location geometry(Point,4326) NOT NULL,
  CONSTRAINT storagepricingapp_storagelocation_pkey PRIMARY KEY (id)
CREATE INDEX storagepricingapp_storagelocation_location_id
  ON public.storagepricingapp_storagelocation
  USING gist
  (location);
-- 30 миллионов записей
CREATE TABLE public.storagepricingapp_storageunit
  id integer NOT NULL DEFAULT nextval('storagepricingapp_storageunit_id_seq'::regclass),
  sizeid character varying(30) NOT NULL,
  dateupdated date NOT NULL,
  facility_id integer NOT NULL,
  datetimeadded timestamp with time zone NOT NULL,
  CONSTRAINT storagepricingapp_storageunit_pkey PRIMARY KEY (id),
  CONSTRAINT st_facility_id_f26e0175_fk_storagepricingapp_storagelocation_id FOREIGN KEY (facility_id)
      REFERENCES public.storagepricingapp_storagelocation (id) MATCH SIMPLE
      ON UPDATE NO ACTION ON DELETE NO ACTION DEFERRABLE INITIALLY DEFERRED
CREATE INDEX storagepricingapp_storageunit_e32a5395
  ON public.storagepricingapp_storageunit
  USING btree
  (facility_id);
Делаю запрос:
Код: plsql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
set enable_seqscan = on;
explain analyze
	SELECT "storagepricingapp_storageunit"."id"
FROM "storagepricingapp_storageunit"
	INNER JOIN "storagepricingapp_storagelocation"
		ON ("storagepricingapp_storageunit"."facility_id" = "storagepricingapp_storagelocation"."id")
WHERE ST_DistanceSphere("storagepricingapp_storagelocation"."location", ST_GeomFromEWKB('\x0101000020e6100000b04cf0ff963f5ac0ad4886eb90dc4340'::bytea)) <= 8046.72
"Hash Join  (cost=4942.68..1126775.50 rows=10162748 width=4) (actual time=55.645..42943.863 rows=118421 loops=1)"
"  Hash Cond: (storagepricingapp_storageunit.facility_id = storagepricingapp_storagelocation.id)"
"  ->  Seq Scan on storagepricingapp_storageunit  (cost=0.00..905874.43 rows=30488243 width=8) (actual time=8.818..31864.672 rows=30490125 loops=1)"
"  ->  Hash  (cost=4884.22..4884.22 rows=4677 width=4) (actual time=29.693..29.693 rows=31 loops=1)"
"        Buckets: 8192  Batches: 1  Memory Usage: 66kB"
"        ->  Seq Scan on storagepricingapp_storagelocation  (cost=0.00..4884.22 rows=4677 width=4) (actual time=0.801..29.661 rows=31 loops=1)"
"              Filter: (_st_distance(geography(location), '0101000020E6100000B04CF0FF963F5AC0AD4886EB90DC4340'::geography, '0'::double precision, false) <= '8046.72'::double precision)"
"              Rows Removed by Filter: 13988"
"Planning time: 0.382 ms"
"Execution time: 42950.661 ms"
Отключаю segscan:
Код: plsql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
set enable_seqscan = off;
explain analyze
"Nested Loop  (cost=58.65..16423015.28 rows=10162748 width=4) (actual time=81.540..15493.680 rows=118421 loops=1)"
"  ->  Index Scan using storagepricingapp_storagelocation_pkey on storagepricingapp_storagelocation  (cost=0.29..13925.21 rows=4677 width=4) (actual time=50.875..148.087 rows=31 loops=1)"
"  ->  Bitmap Heap Scan on storagepricingapp_storageunit  (cost=58.36..3474.21 rows=3425 width=8) (actual time=8.376..493.988 rows=3820 loops=31)"
"        Recheck Cond: (facility_id = storagepricingapp_storagelocation.id)"
"        Heap Blocks: exact=14184"
"        ->  Bitmap Index Scan on storagepricingapp_storageunit_e32a5395  (cost=0.00..57.51 rows=3425 width=0) (actual time=3.144..3.144 rows=3820 loops=31)"
"              Index Cond: (facility_id = storagepricingapp_storagelocation.id)"
"Planning time: 46.526 ms"
"Execution time: 15502.063 ms"
Как заставить планировщик использовать индекс?
    #39486290
qwwq
kalombo,
в зависимости от числа локаций в радиусе.
попробуйте навязать так, например:
Код: sql
1.
2.
3.
4.
5.
6.
7.
8.
9.
with L as (SELECT id as facility_id FROM storagepricingapp_storagelocation lo
WHERE ST_DistanceSphere(lo."location"
,ST_GeomFromEWKB('\x0101000020e6100000b04cf0ff963f5ac0ad4886eb90dc4340'::bytea)) <= 8046.72)
SELECT su."id"
FROM "storagepricingapp_storageunit" su
	INNER JOIN L
		USING(facility_id)
а лучше подумайте над тем, нельзя ли как--то гист индекс прикрутить: https://habrahabr.ru/post/228023/
    #39486657
kalombo
qwwqkalombo,
Код: sql
1.
2.
3.
4.
5.
6.
7.
8.
9.
SELECT su."id"
	INNER JOIN L
		USING(facility_id)
Не помогло....
qwwqа лучше подумайте над тем, нельзя ли как--то гист индекс прикрутить: https://habrahabr.ru/post/228023/
Я так понял, проблема не в индексе для location, а в том, что не используется индекс для facility_id. Я пробовал заставить планировщик использовать индекс путем использования St_DWithin и преобразования geometry в geography - не помогло. Здесь результаты http://dumpz.org/2622879/
1 - seqscan off, 2 - geometry и ST_DistanceSphere, 3 - geography и ST_DWithin
Но в любом случае за статью спасибо.
    #39486717
qwwq
kalomboНе помогло....
а план с WITH есть ? (можно на ANY( ARRAY(SELECT id..) переписать.
еще можно через ,
Код: sql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
SELECT  su."id"  FROM storagepricingapp_storagelocation lo
, LATERAL (SELECT su."id"
WHERE su.facility_id = lo.id
LIMIT 10000 -- тут нужна ручная оценка сверху
                    -- на максимальное число по записей su на локацию
) AS su
kalomboqwwqа лучше подумайте над тем, нельзя ли как--то гист индекс прикрутить: https://habrahabr.ru/post/228023/
если суметь загнать поиск локации на гист, планер мог бы четче оценить что искать нестед--лупом по фасилити дешевле. (оценить число локаций в радиусе более точно) . далее можно доп. фильтр более точным _St_DistanceSferoid наложить.
ещй костами можно поиграть. снизить рендом-кост с 4 до 2 например.
    #39486870
Alexius
kalombo,
проблема в том, что планировщик не может оценить корректно число строк, подходящих под условие
Код: sql
1.
и считает что под него попадает треть строк. если есть уверенность, что под это условие не будет попадать сильно много строк, то можно попробовать прибить nested loop с помощью lateral join или в варианте с with выше дописать limit 100-1000 (максимальное число строк, которое по идее будет под условие с ST_DistanceSphere подходить).
еще может получиться нужный план при добавлении order by "storagepricingapp_storageunit"."id". если база помещается в память или используются ssd диски, то можно уменьшить аккуратно random_page_cost.
