hot standby не стартует
Привет. Производил плановый фейловер. 1. Остановил мастер 2. standby promote 3. На мастере создал recovery.conf standby_mode = 'on' primary_conninfo = 'user=postgres host=10.10.10.1 port=5432' primary_slot_name = 'standby_slot' recovery_target_timeline = 'latest' в конфиге hot_standby = on Стартую постгрес, и он уходит в бесконечное ожидание старта... в логах: 2019-10-18 12:06:07 MSK 3392 LOG: database system is shut down 2019-10-18 12:09:35 MSK 21875 LOG: database system was shut down at 2019-10-18 12:06:02 MSK 2019-10-18 12:09:35 MSK 21875 LOG: entering standby mode 2019-10-18 12:09:35 MSK 21875 LOG: invalid record length at 290/70000098: wanted 24, got 0 2019-10-18 12:09:35 MSK 21883 LOG: fetching timeline history file for timeline 2 from primary server 2019-10-18 12:09:36 MSK 21883 LOG: started streaming WAL from primary at 290/70000000 on timeline 1 2019-10-18 12:09:36 MSK 21883 LOG: replication terminated by primary server 2019-10-18 12:09:36 MSK 21883 DETAIL: End of WAL reached on timeline 1 at 290/70000098. 2019-10-18 12:09:36 MSK 21875 LOG: new target timeline is 2 2019-10-18 12:09:36 MSK 21883 LOG: restarted WAL streaming at 290/70000000 on timeline 2 2019-10-18 12:09:38 MSK monuser 10.10.10.10 postgres 21901 FATAL: the database system is starting up 2019-10-18 12:09:39 MSK 21875 LOG: redo starts at 290/70000098 2019-10-18 12:09:54 MSK monuser 10.10.10.10 user 21976 FATAL: the database system is starting up .. .. ждал в течение часа, сделал ей повторный рестарт, без изменений. 2019-10-18 13:16:06 MSK 21842 LOG: received fast shutdown request 2019-10-18 13:16:06 MSK 21883 FATAL: terminating walreceiver process due to administrator command 2019-10-18 13:16:07 MSK monuser 10.10.10.10 user 9750 FATAL: the database system is shutting down 2019-10-18 13:16:08 MSK 21881 LOG: recovery restart point at 290/739D02B0 2019-10-18 13:16:08 MSK 21881 DETAIL: last completed transaction was at log time 2019-10-18 13:16:05.264617+03 2019-10-18 13:16:08 MSK 21881 LOG: shutting down 2019-10-18 13:16:08 MSK 21842 LOG: database system is shut down 2019-10-18 13:16:19 MSK 9808 LOG: database system was shut down in recovery at 2019-10-18 13:16:08 MSK 2019-10-18 13:16:19 MSK 9808 LOG: entering standby mode 2019-10-18 13:16:19 MSK 9808 LOG: redo starts at 290/739D02B0 2019-10-18 13:16:19 MSK monuser 10.10.10.10 user 9811 FATAL: the database system is starting up 2019-10-18 13:16:20 MSK 9808 LOG: invalid resource manager ID 183 at 290/7CE01F78 2019-10-18 13:16:20 MSK 9812 LOG: started streaming WAL from primary at 290/7C000000 on timeline 2 2019-10-18 13:16:20 MSK monuser 10.10.10.10 user 9815 FATAL: the database system is starting up 2019-10-18 13:16:22 MSK monuser 10.10.10.10 user 9819 FATAL: the database system is starting up Далее, попробовал убрать из конфига hot_standby. Без hot_standby сервис успешно запустился, однако хочется доступа на реплику. Возвращаю параметр - опять бесконечный: FATAL: the database system is starting up Пришлось перезаливать реплику из бэкапа :( Что это и как с этим бороться? PostgreSQL 10.6 on x86_64-redhat-linux-gnu, compiled by gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-16), 64-bit ... |
| 18.10.2019, 16:29 |
start [/forum/topic.php?desktop=1&fid=53&tid=1994996]: |
65ms |
| others: | 241ms |
| total: | 371ms |
