Не удалось запустить intidb:1!
Добрый день! В чем может быть ошибка сервера при установке postgres с нуля, права все полные? performing post-bootstrap initialization ... child process exited with exit code 1 The files belonging to this database system will be owned by user "СИСТЕМА". This user must also own the server process. The database cluster will be initialized with locale "Russian_Russia.1251". The default text search configuration will be set to "russian". Data page checksums are disabled. fixing permissions on existing directory C:/Program Files/PostgreSQL/12.4-1.1C/data ... ok creating subdirectories ... ok selecting dynamic shared memory implementation ... windows selecting default max_connections ... 100 selecting default shared_buffers ... 128MB selecting default time zone ... Europe/Moscow creating configuration files ... ok running bootstrap script ... ok performing post-bootstrap initialization ... child process exited with exit code 1 initdb: removing contents of data directory "C:/Program Files/PostgreSQL/12.4-1.1C/data" ... |
| 20.11.2020, 23:44:07 |
AnriB, антивируса нет?? ... |
| 21.11.2020, 22:19:59 |
grgdvo, нет ... |
| 22.11.2020, 21:40:57 |
AnriB, а вот в окошке у вас пишут, см. inidb.log что там в логах?? ... |
| 23.11.2020, 00:27:15 |
AnriB grgdvo, нет права на директорию? ... |
| 23.11.2020, 00:28:18 |
В файле , то что написано выше ) Да права полные - полные The files belonging to this database system will be owned by user "СИСТЕМА". This user must also own the server process. The database cluster will be initialized with locale "Russian_Russia.1251". The default text search configuration will be set to "russian". Data page checksums are disabled. fixing permissions on existing directory C:/Program Files/PostgreSQL/12.4-1.1C/data ... ok creating subdirectories ... ok selecting dynamic shared memory implementation ... windows selecting default max_connections ... 100 selecting default shared_buffers ... 128MB selecting default time zone ... Europe/Moscow creating configuration files ... ok running bootstrap script ... ok performing post-bootstrap initialization ... child process exited with exit code 1 initdb: removing contents of data directory "C:/Program Files/PostgreSQL/12.4-1.1C/data" Хм , сейчас поставил 10 версию postgres , всё встало без ошибок , а 12 не поставилась ... |
| 23.11.2020, 00:34:53 |
start [/forum/topic.php?desktop=1&fid=53&tid=1994362]: |
190ms |
48ms |
| others: | 225ms |
| total: | 510ms |
