Ускорить запрос
Добрый день! На сервере порядка 10 баз данных,средний размер базы 10гб. Иногда на сервере поднимается iowait , доходит до 40% по zabbix В логах пг иногда появляется: temporary file: path "base/pgsql_tmp/pgsql_tmp27336.3", size 28202020 Вот запрос: select * from Transactions T, DebitTokens D, CreditTokens C where (T.ID = D.ID) and (T.ID = C.ID) and (((C_Agreement in (38558956, 38558956)) or (D_Agreement in (38558956, 38558956)))) План запроса QUERY PLAN --------------------------------------------------------------------------------------------------------------------------------------------------------- Gather (cost=31708.55..56241.31 rows=185 width=648) (actual time=569.994..637.500 rows=10 loops=1) Workers Planned: 3 Workers Launched: 3 -> Nested Loop (cost=30708.55..55222.81 rows=60 width=648) (actual time=580.163..595.466 rows=2 loops=4) -> Parallel Hash Join (cost=30708.12..55193.07 rows=64 width=568) (actual time=580.136..595.417 rows=2 loops=4) Hash Cond: (c.id = d.id) Join Filter: ((c.c_agreement = ANY ('{38558956,38558956}'::integer[])) OR (d.d_agreement = ANY ('{38558956,38558956}'::integer[]))) Rows Removed by Join Filter: 472558 -> Parallel Seq Scan on credittokens c (cost=0.00..22982.94 rows=572194 width=284) (actual time=0.012..47.908 rows=472560 loops=4) -> Parallel Hash (cost=23563.61..23563.61 rows=571561 width=284) (actual time=232.142..232.143 rows=472560 loops=4) Buckets: 2097152 Batches: 1 Memory Usage: 152448kB -> Parallel Seq Scan on debittokens d (cost=0.00..23563.61 rows=571561 width=284) (actual time=0.021..56.768 rows=472560 loops=4) -> Index Scan using pk_transactions on transactions t (cost=0.43..0.46 rows=1 width=80) (actual time=0.015..0.015 rows=1 loops=10) Index Cond: (id = d.id) Planning Time: 0.680 ms Execution Time: 637.666 ms (16 rows) Настройки сервера: max_connections = 1000 shared_buffers = 64GB effective_cache_size = 195072MB maintenance_work_mem = 2GB checkpoint_completion_target = 0.7 wal_buffers = 16MB default_statistics_target = 100 random_page_cost = 1.1 effective_io_concurrency = 200 work_mem = 256MB min_wal_size = 2GB max_wal_size = 8GB max_worker_processes = 24 max_parallel_workers_per_gather = 4 max_parallel_workers = 24 max_parallel_maintenance_workers = 4 checkpoint_timeout = 1h Возможно стоит поменять какие-то настройки пг? Пробовал играться с work_mem поднимая до 512мб - но ситуация не менялась ... |
| 09.03.2021, 14:40:11 |
Ускорить запрос
Strikie, postgresql крайне отрицательно относится к OR условиям в запросах... попробуйте переписать запрос например как Код: plsql 1. 2. 3. если у вас при этом есть все нужные под это индексы будет сильно быстрее и легче для базы. потом можно будет еще несколько оптимизировать запрос при необходимости. -- Maxim Boguk лучшая поддержка PostgreSQL: dataegret.ru ... |
| 09.03.2021, 15:14:56 |
Ускорить запрос
Maxim Boguk, благодарю за оперативность. Проверил на базе - запрос в 3 раза быстрее выполняется ... |
| 09.03.2021, 16:09:17 |
Ускорить запрос
Strikie Maxim Boguk, благодарю за оперативность. Проверил на базе - запрос в 3 раза быстрее выполняется как то маловата разница... индексы по полям C_Agreement и D_Agreement есть то в базе? я ожидал разницы в 1000 раз хотя бы... -- Maxim Boguk лучшая поддержка PostgreSQL: dataegret.ru ... |
| 09.03.2021, 16:15:08 |
Ускорить запрос
Не очень понятно, у Вас 10 баз, жалуетесь Вы на iowait который иногда случается, а грешите на запрос, который выполняется 600мс. ... |
| 09.03.2021, 16:35:26 |
Ускорить запрос
Guzya Не очень понятно, у Вас 10 баз, жалуетесь Вы на iowait который иногда случается, а грешите на запрос, который выполняется 600мс. если на каждой из 10 баз начнет кто то писать по 20-50mb временных файлов на запрос то iowait как раз и будет большим. особенно если дисковая система слабая (а для 10Gb баз она скорее всего слабая так как нет смысла хорошую ставить) -- Maxim Boguk лучшая поддержка PostgreSQL: dataegret.ru ... |
| 09.03.2021, 16:37:30 |
Ускорить запрос
Maxim Boguk Guzya Не очень понятно, у Вас 10 баз, жалуетесь Вы на iowait который иногда случается, а грешите на запрос, который выполняется 600мс. если на каждой из 10 баз начнет кто то писать по 20-50mb временных файлов на запрос то iowait как раз и будет большим. особенно если дисковая система слабая (а для 10Gb баз она скорее всего слабая так как нет смысла хорошую ставить) -- Maxim Boguk лучшая поддержка PostgreSQL: dataegret.ru Это я понимаю, но почему именно этот запрос? Т.е. : 10 баз одинаковые ? Вся нагрузка к этим базам состоит из этого запроса? Как определили, что временный файл создался именно этим запросом? На счет Maxim Boguk (а для 10Gb баз она скорее всего слабая так как нет смысла хорошую ставить) Судя по настройкам, на сервере ~200Гб оперативы. ... |
| 09.03.2021, 16:48:45 |
Ускорить запрос
Maxim Boguk, индексов не было. Добавил для теста и вот что получил: Это старый запрос: "Gather (cost=30891.98..54785.63 rows=204 width=648) (actual time=690.605..749.054 rows=10 loops=1)" " Workers Planned: 3" " Workers Launched: 3" " -> Nested Loop (cost=29891.98..53765.23 rows=66 width=648) (actual time=682.893..701.664 rows=2 loops=4)" " -> Parallel Hash Join (cost=29891.55..53734.74 rows=66 width=568) (actual time=682.819..701.582 rows=2 loops=4)" " Hash Cond: (d.id = c.id)" " Join Filter: ((c.c_agreement = ANY ('{38558956,38558956}'::integer[])) OR (d.d_agreement = ANY ('{38558956,38558956}'::integer[])))" " Rows Removed by Join Filter: 472560" " -> Parallel Seq Scan on debittokens d (cost=0.00..22242.58 rows=609758 width=284) (actual time=0.018..70.371 rows=472562 loops=4)" " -> Parallel Hash (cost=22269.58..22269.58 rows=609758 width=284) (actual time=280.334..280.336 rows=472562 loops=4)" " Buckets: 2097152 Batches: 1 Memory Usage: 152640kB" " -> Parallel Seq Scan on credittokens c (cost=0.00..22269.58 rows=609758 width=284) (actual time=0.019..76.657 rows=472562 loops=4)" " -> Index Scan using pk_transactions on transactions t (cost=0.43..0.46 rows=1 width=80) (actual time=0.026..0.026 rows=1 loops=10)" " Index Cond: (id = d.id)" "Planning Time: 0.874 ms" "Execution Time: 749.202 ms" Это новый: "HashAggregate (cost=791.09..793.13 rows=204 width=648) (actual time=0.293..0.309 rows=10 loops=1)" " Group Key: t.id, t.amount, t.quantity, t.balanstypecls, t.classno, t.credit, t.debet, t.description, t.docdetail, t.document, t.eicls, t.finsource, t.firstnum, t.opdate, t.orgtypecls, t.params, t.parentid, t.userid, d.id, d.d_agreement, d.d_bankaccount, d.d_basedoc, d.d_calcrange, d.d_clselement, d.d_clsprogram, d.d_custom, d.d_deficitsource, d.d_depart, d.d_directioncls, d.d_estateadmin, d.d_expensekind, d.d_facialaccount, d.d_factcls, d.d_fintypecls, d.d_fss, d.d_functionalea, d.d_fundsmovement, d.d_gosprogramcls, d.d_incomeadmin, d.d_incomecode, d.d_incomeprice, d.d_incometype, d.d_information, d.d_jointstock, d.d_mediatype, d.d_monthrange, d.d_nbo, d.d_nestingtype, d.d_nfa, d.d_nfagroup, d.d_objaccount, d.d_organization, d.d_paytype, d.d_person, d.d_place, d.d_protectiontype, d.d_realaccount, d.d_regioncls, d.d_rendering, d.d_stateoperation, d.d_stateoperation2016, d.d_stdohrash, d.d_subkesr, d.d_subsidycls, d.d_targetcodecls, d.d_targetea, d.d_targetea2016, d.d_tipsummy, d.d_tiptseny, d.d_usercategory, d.d_vehicle, d.d_nomerpartii, d.d_nomerserii, d.d_srokgodnosti, d.d_budallocationcls, d.d_contractcostscls, d.d_ndsopcode, d.d_kodba, d.d_kindofcosts, d.d_targetfunds, d.d_tselycode, d.d_clselement125, d.d_estateadmin125, d.d_oktmo, d.d_recipientmc, d.d_statusnfa, d.d_tselevajafunktsija, d.d_ndo, d.d_actdir, c.id, c.c_agreement, c.c_bankaccount, c.c_basedoc, c.c_calcrange, c.c_clselement, c.c_clsprogram, c.c_custom, c.c_deficitsource, c.c_depart, c.c_directioncls, c.c_estateadmin, c.c_expensekind, c.c_facialaccount, c.c_factcls, c.c_fintypecls, c.c_fss, c.c_functionalea, c.c_fundsmovement, c.c_gosprogramcls, c.c_incomeadmin, c.c_incomecode, c.c_incomeprice, c.c_incometype, c.c_information, c.c_jointstock, c.c_mediatype, c.c_monthrange, c.c_nbo, c.c_nestingtype, c.c_nfa, c.c_nfagroup, c.c_objaccount, c.c_organization, c.c_paytype, c.c_person, c.c_place, c.c_protectiontype, c.c_realaccount, c.c_regioncls, c.c_rendering, c.c_stateoperation, c.c_stateoperation2016, c.c_stdohrash, c.c_subkesr, c.c_subsidycls, c.c_targetcodecls, c.c_targetea, c.c_targetea2016, c.c_tipsummy, c.c_tiptseny, c.c_usercategory, c.c_vehicle, c.c_nomerpartii, c.c_nomerserii, c.c_srokgodnosti, c.c_budallocationcls, c.c_contractcostscls, c.c_ndsopcode, c.c_kodba, c.c_kindofcosts, c.c_targetfunds, c.c_tselycode, c.c_clselement125, c.c_estateadmin125, c.c_oktmo, c.c_recipientmc, c.c_statusnfa, c.c_tselevajafunktsija, c.c_ndo, c.c_actdir" " -> Append (cost=1.28..709.49 rows=204 width=648) (actual time=0.047..0.217 rows=20 loops=1)" " -> Nested Loop (cost=1.28..373.19 rows=108 width=648) (actual time=0.047..0.126 rows=10 loops=1)" " -> Nested Loop (cost=0.85..323.79 rows=108 width=364) (actual time=0.033..0.079 rows=10 loops=1)" " -> Index Scan using ix_credittokens_agreement on credittokens c (cost=0.43..39.23 rows=108 width=284) (actual time=0.020..0.031 rows=10 loops=1)" " Index Cond: (c_agreement = ANY ('{38558956,38558956}'::integer[]))" " -> Index Scan using pk_transactions on transactions t (cost=0.43..2.63 rows=1 width=80) (actual time=0.003..0.003 rows=1 loops=10)" " Index Cond: (id = c.id)" " -> Index Scan using pk_debittokens on debittokens d (cost=0.43..0.46 rows=1 width=284) (actual time=0.003..0.003 rows=1 loops=10)" " Index Cond: (id = t.id)" " -> Nested Loop (cost=1.28..333.24 rows=96 width=648) (actual time=0.041..0.088 rows=10 loops=1)" " -> Nested Loop (cost=0.85..289.33 rows=96 width=364) (actual time=0.031..0.054 rows=10 loops=1)" " -> Index Scan using ix_debittokens_agreement on debittokens d_1 (cost=0.43..35.41 rows=96 width=284) (actual time=0.026..0.029 rows=10 loops=1)" " Index Cond: (d_agreement = ANY ('{38558956,38558956}'::integer[]))" " -> Index Scan using pk_transactions on transactions t_1 (cost=0.43..2.65 rows=1 width=80) (actual time=0.001..0.001 rows=1 loops=10)" " Index Cond: (id = d_1.id)" " -> Index Scan using pk_credittokens on credittokens c_1 (cost=0.43..0.46 rows=1 width=284) (actual time=0.002..0.002 rows=1 loops=10)" " Index Cond: (id = t_1.id)" "Planning Time: 1.695 ms" "Execution Time: 0.583 ms" ... |
| 09.03.2021, 17:01:07 |
Ускорить запрос
Guzya, на сервере 256гб. А запрос отловил включением log_temp_files=1. ... |
| 09.03.2021, 17:03:40 |
Ускорить запрос
Strikie, как и ожидалось ускорение порядка 1000 раз. "Execution Time: 749.202 ms" vs "Execution Time: 0.583 ms" -- Maxim Boguk лучшая поддержка PostgreSQL: dataegret.ru ... |
| 09.03.2021, 17:19:13 |
start [/forum/topic.php?desktop=1&fid=53&tid=1994153]: |
201ms |
59ms |
| others: | 209ms |
| total: | 516ms |
