Crystal Report in Oracle Forms 6i
прошу помочь кто -либо подружил их?! вот в дельфи посредством VCL а в crystal reports ставил фичу oracle ,а сейчаc пока через ODBC. просто теперь всало необходимость вызвать с формс 6 этот отчёт ...даже непонятно как его вызвать расширение rpt?! прошу не пинать сильно ?! спасибо! нашёл единственное,но у меня не получается может кто имел дело , подскажите плиз.... ------------------------ STEPS TO display the Crystal Report in Oracle Forms 6i: **NOTE: This assumes that you already have Crystal Reports installed on your machine. 1. Create a new form. 2. Create a control block, name it 'CONTROL'. 3. Create a CONTENT canvas, name it 'REPCAN'. 4. Create an ActiveX control on the canvas, name it 'CrystalReport1'. 5. Create an Image item and name it 'REP'. (Make sure that image item overlaps the ActiveX control completely; this image item is only used to get the item handle. Enlarge this object such a way that it will fit the window; the report gets displayed in this item so the item size should be adeqately large. 6. Right click on the ActiveX control item and select "Insert Object" from the menu. 7. From the list select "Crystal Report Control". 8. Select the Program->Import OLE Library Interface Menu in the form. 9. Select Crystal.CrystalReport from the List. (This will list two methods and one Event. The two methods are CrystalCtrl and IRowCursor, the event is CrystalReprotEvent). 10. Select all three and click on the OK button to accept. (This will create the PL/SQL wrapper program units). 11. In the "When-New-Form-Instance" trigger of the form, put the following code. DECLARE charWinHandle VARCHAR2(50); numWinHandle NUMBER; BEGIN Set_Application_Property(Cursor_Style,'BUSY'); charWinHandle := Get_Item_Property('Control.Rep',Window_Handle); numWinHandle := To_Number(charWinHandle); :Item('Control.CrystalReport1').OCX.Crystal.CrystalReport.WindowParentHandle := numWinHandle; :Item('Control.CrystalReport1').OCX.Crystal.CrystalReport.WindowState := 2; :Item('CONTROL.CRYSTALREPORT1').OCX.Crystal.CrystalReport.Connect := 'DSN=;UID=' || Get_Application_Property(UserName) || ';pwd=' || Get_Application_Property(password) || ';dsq=;'; Crystal_CrystalCtrl.ReportFileName( :Item('Control.CrystalReport1').interface, 'C:\Sample_Rep.Rpt' ); Set_Window_Property( Forms_Mdi_Window, Window_State,Maximize ); Set_Window_Property( 'MAIN', Window_State, Maximize ); :reptitle := 'Report Preview Window'; numWinHandle := Crystal_CrystalCtrl.PrintReport( :Item('Control.CrystalReport1').interface ); Set_Application_Property(Cursor_Style,'DEFAULT'); END; **NOTE: Change the report name and path according to your required file name and path in the "Crystal_CrystalCtrl.ReportFileName" method call. Also, the connection string shown assumes that you will use the current USER and PASSWORD for the Form. 12. To make the above Form generic so that you can run any Crystal report from it, then create a parameter for the report name and pass it to the Form using CALL_FORM from any other Form. Then just replace the file name with the passed parameter. 13. Run the Form. ... |
| 14.10.2006, 13:02 |
start [/forum/topic.php?desktop=1&fid=51&tid=1879299]: |
130ms |
31ms |
| others: | 262ms |
| total: | 463ms |
