Updating the Images Directory When Upgrading from a Previous Release
SQL> @apxldimg.sql /tmp PL/SQL procedure successfully completed. old 1: create directory APEX_IMAGES as '&1/apex/images' new 1: create directory APEX_IMAGES as '/tmp/apex/images' Directory created. declare * ERROR at line 1: ORA-22288: file or LOB operation FILEOPEN failed No such file or directory ORA-06512: at "SYS.XMLTYPE", line 296 ORA-06512: at line 15 ... |
| 04.05.2009, 14:04 |
SQL> select * from v$version 2 ; BANNER -------------------------------------------------------------------------------- Oracle Database 11g Enterprise Edition Release 11.1.0.6.0 - 64bit Production PL/SQL Release 11.1.0.6.0 - Production CORE 11.1.0.6.0 Production TNS for Linux: Version 11.1.0.6.0 - Production NLSRTL Version 11.1.0.6.0 - Production ... |
| 04.05.2009, 14:06 |
Nutss wrote at 04.05.2009 15:04: > SQL> @apxldimg.sql /tmp > > PL/SQL procedure successfully completed. > > old 1: create directory APEX_IMAGES as '&1/apex/images' > new 1: create directory APEX_IMAGES as '/tmp/apex/images' > > Directory created. Команда "CREATE DIRECTORY" не создает физически директорию на диске, а лишь создает объект БД DIRECTORY. На диске есть такая директория как /tmp/apex/images? Posted via ActualForum NNTP Server 1.4 ... |
| 04.05.2009, 14:16 |
Denis Popov На диске есть такая директория как /tmp/apex/images? есть! ... |
| 04.05.2009, 14:22 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. ... |
| 04.05.2009, 14:25 |
start [/forum/topic.php?desktop=1&fid=50&tid=1877413]: |
38ms |
29ms |
| others: | 223ms |
| total: | 327ms |
