Подсчет количества строк по группировкам
Скажите, пжл, как подсчитать количества строк по группировкам rn? SELECT row_number() over (partition by q.Invno_OC order by q.Invno_OC) rn, q.* from( select L.Invno_OC, L.Invno, B.name, B.AUTHOR, L.DatePost, L.Invno_OC partia, L.DateSpis from libr_invent L, libr_books B where L.del='N' and B.del='N' and L.id=B.id(+) and L.DateSpis is not NULL and L.DatePost between to_date(:p60_DatePost1) and to_date(:p60_DatePost2) order by L.Invno_OC) q Моя попытка в сообщении ниже. ... |
| 10.02.2011, 15:37 |
SELECT count(*), --q2.* from( q2.Invno_OC, q2.Invno, q2.name, q2.AUTHOR, q2.DatePost, q2.Invno_OC partia, q2.DateSpis from( SELECT row_number() over (partition by q.Invno_OC order by q.Invno_OC) rn, --q.* from( q.Invno_OC, q.Invno, q.name, q.AUTHOR, q.DatePost, q.Invno_OC partia, q.DateSpis from( select L.Invno_OC, L.Invno, B.name, B.AUTHOR, L.DatePost, L.Invno_OC partia, L.DateSpis from libr_invent L, libr_books B where L.del='N' and B.del='N' and L.id=B.id(+) and L.DateSpis is not NULL and L.DatePost between to_date('30.01.2003') and to_date('16.05.2003') order by L.Invno_OC) q ) q2 GROUP BY q2.Invno_OC, q2.Invno, q2.name, q2.AUTHOR, q2.DatePost, q2.Invno_OC, q2.DateSpis ... |
| 10.02.2011, 15:37 |
| 10.02.2011, 15:38 |
в третьем сообщении то же самое ... |
| 10.02.2011, 15:38 |
Сама сделала. ... |
| 10.02.2011, 16:27 |
start [/forum/topic.php?desktop=1&fid=50&tid=1876643]: |
151ms |
36ms |
| others: | 208ms |
| total: | 434ms |
