Вышел Apex 4.1. Early Adopter 1
Больше всего порадовало: Tabular Forms Tabular Forms now support all validation types . Depending on the validation type you can use bind variable syntax, substitution syntax or you just specify the tabular form column name. The validation is executed for each submitted row of the tabular form. Processes can now be defined for Tabular Forms as well, which allows you to easily process the submitted rows of a tabular form without having to deal with the apex_application.g_f01 - apex_application.g_f50 arrays . Depending on the process type you can use bind variable syntax, substitution syntax or just specify the tabular form column name . The condition handling of Validations and Process have also been enhanced to better work with Tabular Forms. The new attribute "Execution Scope" allows to define for which rows the validation/process should be executed. The condition can now refer to tabular form columns if the new attribute "Execute Condition" is set to "For Each Row". Validation and Processes which are assigned to a Tabular Form can also use the built-in Tabular Form column names "APEX$ROW_NUM", "APEX$ROW_STATUS" and "APEX$ROW_SELECTOR" in the validation, process or condition to refer the row number, row status (C=created, U=updated, D=deleted) and row selector checkbox (X=checked, null when not checked) of the currently processed tabular form row. Впрочем, нужно будет опробовать, жуть наболела обработка по номерам столбцов, хочется по именам столбцов обрабатывать. ... |
| 10.05.2011, 20:05 |
Up! EA2 на подходе: http://joelkallman.blogspot.com/2011/06/application-express-41-early-adopter-2.html On or after this Friday, 10-JUN-2011, the current Application Express instance on http://tryapexnow.com will be terminated and a new one will be created. Nothing will be migrated. If there is any information you would like to save from your workspace, I encourage you to export it before Friday, 10-JUN-2011. ... |
| 06.06.2011, 18:14 |
Хорошая возможность, кстати, что-нибудь туда написать и попросить исправить (на английском). Они на очень многие запросы отвечают и реально кое-что исправляют (по опыту с Apex 4.0. Early Adopter еще, на все мои 3-4 запроса ответили, в 4.1 еще не регался правда) Позже зарегуюсь, попрошу text area resizable кое-где сделать, напрягает очень (если еще не поправили). ... |
| 07.06.2011, 17:41 |
start [/forum/topic.php?desktop=1&fid=50&tid=1876502]: |
71ms |
28ms |
| others: | 249ms |
| total: | 392ms |
