Установка apex 20.2
после установки apex 20.2 устанавливал по инструкции @apexins apex apex temp /i/ @apxchpwd.sql @apex_rest_config.sql >>all Passworda are >>admin_123 --select username,account_status from dba_users where username like 'APEX%' ALTER USER APEX_LISTENER ACCOUNT UNLOCK identified by admin_123; ALTER USER APEX_PUBLIC_USER ACCOUNT UNLOCK identified by admin_123; ALTER USER APEX_REST_PUBLIC_USER ACCOUNT UNLOCK identified by admin_123; ALTER USER APEX_INSTANCE_ADMIN_USER ACCOUNT UNLOCK identified by admin_123; ALTER USER APEX_200200 ACCOUNT UNLOCK identified by admin_123; --select username,account_status from dba_users where username like 'ORDS%' ALTER USER ORDS_METADATA ACCOUNT UNLOCK identified by admin_123; ALTER USER ORDS_PUBLIC_USER ACCOUNT UNLOCK identified by admin_123; ALTER USER ORDSYS ACCOUNT UNLOCK identified by admin_123; ------------------------------------------------------------------ For Oracle Database version 12c or later run the below script: BEGIN DBMS_NETWORK_ACL_ADMIN.APPEND_HOST_ACE( host => '*', ace => xs$ace_type(privilege_list => xs$name_list('connect'), principal_name => 'APEX_200200', principal_type => xs_acl.ptype_db)); END; / BEGIN DBMS_NETWORK_ACL_ADMIN.APPEND_HOST_ACE( host => 'localhost', ace => xs$ace_type(privilege_list => xs$name_list('connect'), principal_name => 'APEX_200200', principal_type => xs_acl.ptype_db)); END; / EXEC DBMS_XDB.sethttpport(0); --download jdk https://www.oracle.com/java/technologies/javase-downloads.html --Download Ords file as you required or support your apex versions.... https://www.oracle.com/database/technologies/appdev/rest-data-services-v192-downloads.html #unzip ords file copy images folder from apex directory and past to ords folder. go to cmd and enter ords directory example CD D:\Oracle\ords java -jar ords.war------------Apex 20.2 Installation Guide line---------- Create Tablespace apex logging datafile 'D:\Oracle\oradata\LIVE\APEX.DBF' size 1024m autoextend on next 64m maxsize 5G extent management local; @apexins apex apex temp /i/ @apxchpwd.sql @apex_rest_config.sql >>all Passworda are >>admin_123 --select username,account_status from dba_users where username like 'APEX%' ALTER USER APEX_LISTENER ACCOUNT UNLOCK identified by admin_123; ALTER USER APEX_PUBLIC_USER ACCOUNT UNLOCK identified by admin_123; ALTER USER APEX_REST_PUBLIC_USER ACCOUNT UNLOCK identified by admin_123; ALTER USER APEX_INSTANCE_ADMIN_USER ACCOUNT UNLOCK identified by admin_123; ALTER USER APEX_200200 ACCOUNT UNLOCK identified by admin_123; --select username,account_status from dba_users where username like 'ORDS%' ALTER USER ORDS_METADATA ACCOUNT UNLOCK identified by admin_123; ALTER USER ORDS_PUBLIC_USER ACCOUNT UNLOCK identified by admin_123; ALTER USER ORDSYS ACCOUNT UNLOCK identified by admin_123; ------------------------------------------------------------------ For Oracle Database version 12c or later run the below script: BEGIN DBMS_NETWORK_ACL_ADMIN.APPEND_HOST_ACE( host => '*', ace => xs$ace_type(privilege_list => xs$name_list('connect'), principal_name => 'APEX_200200', principal_type => xs_acl.ptype_db)); END; / BEGIN DBMS_NETWORK_ACL_ADMIN.APPEND_HOST_ACE( host => 'localhost', ace => xs$ace_type(privilege_list => xs$name_list('connect'), principal_name => 'APEX_200200', principal_type => xs_acl.ptype_db)); END; / There is a problem with your environment because the Application Express files are not up-to-date! The files for version 19.2.0.00.18 have been loaded, but 20.2.0.00.20 is expected. Please verify that you have copied the images directory to your application server as instructed in the Installation Guide. с 20.1 таких проблем не было, был файл @apxldimg.sql но 20.2 так кого файла нет инструкция для 20.1 EXEC DBMS_XDB.SETHTTPPORT(0); SYSTEM_DRIVE:\ sqlplus /nolog SQL> CONNECT SYS as SYSDBA Enter password: SYS_password @apexins SYSAUX SYSAUX TEMP /i/ @apxchpwd @apxldimg.sql C:\algoritm\apex EXEC DBMS_XDB.SETHTTPPORT(8080); ALTER USER anonymous ACCOUNT UNLOCK; ALTER USER anonymous IDENTIFIED BY ANONYMOUS; exec dbms_xdb.setListenerLocalAccess (l_access => FALSE); @apex_epg_config.sql C:\algoritm\apex ... |
| 05.11.2020, 10:58 |
Установка apex 20.2
ilyuha111, 1. По инструкции для APEX 20.1 видно, что в качестве Web Listener-а используется EPG (EXEC DBMS_XDB.SETHTTPPORT(8080); @apex_epg_config.sql C:\algoritm\apex). А в APEX 20.2 уже нет EPG, а только ORDS. 2. Какая-то у тебя инструкция "левая" для APEX 20.2 - вроде все правильно, но какие-то задвоения действий. так что отсылаю тебя курить мануалы: 1. APEX 20.2 Installation Guide 2. ORDS 20.3 Installation Configuration and Development Guide Всё устанавливается, все работает. ... |
| 05.11.2020, 12:12 |
Установка apex 20.2
ilyuha111, Судя о инструкции надо запустить apex_epg_config.sql он теперь и epg конфигурит и картинки грузит. А вообще лучше избавиться от epg, уж очень он тормозной. ... |
| 05.11.2020, 16:12 |
Установка apex 20.2
жаль что легкой жизни теперь не будет уставоил ORDS скопировал папку images в C:\ords-20.3.0.301.1819\images запустил "C:\Program Files\Java\jdk-15.0.1\bin\java.EXE" -jar ords.war standalone при входе в апекс таже проблема что то я не так сделал ... |
| 05.11.2020, 17:11 |
Установка apex 20.2
C:\algoritm\ords-20.3.0.301.1819\ords\standalone Thu Nov 05 16:18:03 MSK 2020 jetty.port=8080 standalone.context.path=/ords standalone.doc.root=C\:\\ords-20.3.0.301.1819\\ords\\standalone\\doc_root standalone.scheme.do.not.prompt=true standalone.static.context.path=/i standalone.static.path=C\:\\ords-20.3.0.301.1819\\images ... |
| 05.11.2020, 17:44 |
Установка apex 20.2
ilyuha111 C:\algoritm\ords-20.3.0.301.1819\ords\standalone Thu Nov 05 16:18:03 MSK 2020 jetty.port=8080 standalone.context.path=/ords standalone.doc.root=C\:\\ords-20.3.0.301.1819\\ords\\standalone\\doc_root standalone.scheme.do.not.prompt=true standalone.static.context.path=/i standalone.static.path=C\:\\ords-20.3.0.301.1819\\images DBMS_XDB.SETHTTPPORT(0); -- ? ... |
| 05.11.2020, 18:28 |
Установка apex 20.2
ilyuha111 Тогда ХЗ - что у тебя там было и что потом натворил (по ошибке видно, что по крайней мере с 19.2 обновлялся). Если база тестовая и не важны существующие приложения, то деинсталируй apex, удали все соответствующие APEX и ORDS схемы в базе, удали и создай заново тейблспейсы, если использовались для APEX, и поставь снова на "чистую" базу APEX и сконфигурируй ORDS, только по документации, а не по той "задвоенной" инструкции, что у тебя. Либо создай 2-ой чистый экземпляр БД и поставь в него. ПС. А на будущее советую иметь базу с APEX на виртуалке и там экспериментировать с установкой новых версий, чтобы не было сюрпризов - если дома. Если на предприятии, то устанавливать в тестовой среде на клоне промышленной базы. И использовать документацию от Oracle, а не "выжимки" из инета - на чтение и понимание в 1й раз уходит 1-2 дня, дальше на новых версиях не более пару часов. ... |
| 05.11.2020, 20:06 |
start [/forum/search_topic.php?author=Maxim+Goyan&author_mode=last_posts&do_search=1]: |
157ms |
58ms |
| others: | 755ms |
| total: | 1041ms |
