Calc cell 's of client does not called . Pomogite !!!!!!
Pomogite pozaluista !!!!! ( u menya net russkogo fonta - please read English text) I have some cube with calc cell with very long Calculation Subcube and Calculation condition In this "client" cube i create "our" calc cell that implied to whole measure and do not have Calculation Subcube and Calculation condition,Calculation value of it is some function of " our " dll. The problem is : After i add "our" calc cell , previous existed calc cells of client does not called !!!! Pomogite zapustit ich !!! Kakie prichini etomu mogut bit? May be the reasons them 0."our" calc cell used "our" "external" library instead that client cells are not 1.cause "my" calc cell has the most wide scope instead "client" calc cell has some specific scope ( Calc Subcube and Calc Value ) 2.I also was tried to change SOLVE_ORDER of "my" to be -1,-7000,-8000 and this not help 3.i changed also pass number ela@hyperroll.com ... |
| 05.01.2003, 11:08 |
Solve Order у обоих вычислений одинаковый? ... |
| 05.01.2003, 12:46 |
Ded Mazai ,Spacibo za otklik. Solve_order = 0 , Pass=1 at both calc cells. Order of calc cells as i see at gui is 1-st placed "client" calc cell , after it "my" calc cell . Details: dim1 and dim2 are dims of the cube "client" calc cell is defined on 2 base points, here are unique names at dim1 it [dim1].[par11].[par12].[par13].[child1] at dim2 it [dim2].[par21].[par22].[par23].[child2] About "my" (2-nd) calc cell: it defined on whole measure and call some function of "my" dll on each point The fact them are : If "my" calc cell disabled and "client" calc cell enabled then i see results of "client" calc cell at [child1] , at [par13] , at [par12] and so on ... i see results at all parents If "my" calc cell enabled and "client" enabled also then i see results of "client" calc cell only at [child1] and not at it parents , the same for other dim Why ? Thanks in advance to anybody . Zdu otveta.Alla. ... |
| 05.01.2003, 18:11 |
Алла, давайте по порядку. 1. Что такое client calc cells и чем они отличаются от серверных calc cells? Насколько я понимаю, речь идет о двух областях вычисляемых ячеек в кубе. Если я прав, назовем одну Ваша, другую - чужая. 2. Что выбрано в качестве Members Set при определении subcube для чужого измерения? Base point я понимаю как single member. Тогда почему, когда ваше вычисление задисейблено, чужое работает не только по base points, но и по их родителям? 3. Какое вычисление по логике должно выполняться первым: Ваше или чужое? ... |
| 05.01.2003, 18:50 |
Ded Mazai and everyone, please disregard this publication , i published another one. under "client" calc cell i means calc cell that was existed at msolap db that i get from client under "our" calc cell i means calc cell that i add to client cube after all its prev existed "client" calc cells... I simplified my problem and refresh my questions , please read my later publication under the title "Calc cells!!!Pomogite" ... |
| 06.01.2003, 18:16 |
start [/forum/topic.php?desktop=1&fid=49&tid=1873615]: |
53ms |
48ms |
| others: | 231ms |
| total: | 385ms |
