По поводу стороны исполнения calculated member
Вот копия ответа уважаемого господина Джорджа Споффорда (George Spofford) It depends. Mostly, they will get calculated on the client side. However, depending on settings including the Large Level settings and Execution Location, they can sometimes be executed on the server as well. As far as we can tell, if a calculated member is involved in evaluating which members of a "large level" form the axis of a query, then that calculated member can be evaluated at the server. There are some things you can do which force the calculated member to evaluate at the client tier, like use an external function that isn't registered at the server. НЕУЖТО calculated member чтоб 100% выполнялись нужно использовать свои внешние функции??? ... |
| 02.04.2003, 12:45:18 |
А какая разница, где вычисляется calculated member? ... |
| 02.04.2003, 12:52:16 |
start [/forum/topic.php?desktop=1&fid=49&tid=1873466]: |
165ms |
| others: | 267ms |
| total: | 487ms |
