MS SQL 2003. Новый удар по рынку от Microsoft?
Что я считаю очень важным в MS SQL 2003 (OLAP). - Улучшенный Real-Time. Его можно будет гораждо проще запустить поверх любой БД - Большиство Calculated Member переходят на сервер и попдают под кеширование. Надо ли говорить, что это убыстрит многие вычисления в разы. - Write-back из чистого маркетинга превращается в иструмент. Производительность становится на нормальном уровне. Ваши комментарии? Microsoft touts business intelligence for the masses http://www.infoworld.com/article/02/11/21/021121hnyukonbi_1.html Yukon will feature OLAP and data mining engines, a development workbench, and data extraction, transformation, and loading. Baker also spoke of an unrevealed feature dubbed "Act III," which is expected to be a followup to OLAP and data mining. The OLAP engine in Yukon will scale better, and calculations and analysis on the OLAP engine will be centralized to cut down on network traffic. Calculations will be cached as well. Write-back data performance will be improved tenfold, according to the company. http://www.eweek.com/article2/0,3959,302468,00.asp Microsoft plans to add to its next release of SQL Server, code-named Yukon, the ability to do OLAP (online analytical processing) and data mining on real-time streams of data. http://www.eweek.com/article2/0,3959,716625,00.asp Another trend I expect to see is a shift toward closer-to-real-time and more scalable data analytics, especially on the OLAP (online analytical processing) and data mining fronts. The volumes of data being collected and the push to speed business processes are requiring faster data analysis turnaround, and that implies a shift toward relational OLAP (which can be performed directly on source data in a relational database) and away from multidimensional OLAP (where data is copied and analyzed offline). http://www.microsoft.com/sql/evaluation/yukon.asp http://www.microsoft.com/sql/evaluation/bi/reportingservices.asp ... |
| 17.05.2003, 18:11:32 |
Ну во-первых, наверно, все-таки не 2003, а 2004. Во-вторых, чтобы судить наверняка, стоит дождаться хотя бы 1-й беты. В-третьих, серьезные проекты еще долго будут делаться на 2000, даже если SQL Server "Yukon" окажется в 100 раз класснее и будет сам за пивом для админа бегать. ... |
| 19.05.2003, 10:53:40 |
Они бы для начала нормальный клиент сделали. А то вот взял потестить MS Office 11 beta 2, думал мож в PivotTable или в Excel добавили чего нового. Фиг! Кнопки разрисовали по новому и всё. Как глючил Excel на Parent - Children измерениях, так и глючит. ... |
| 19.05.2003, 11:45:27 |
А что есть нормальный клиент? Что, например, на Ваш взгляд, является нормальным клиентом для реляционного SQL Server? По-моему, такая постановка вопроса вообще неправомочна. Нормальный клиент неявно предполагает конкретные бизнес-требования предприятия. Есть серверный движок, есть интерфейсы доступа - на здоровье пишите своего клиента, максимально отвечающего Вашей задаче, если готовые клиенты (от MS, от ProClarity, от Cognos, от BusinessObjects, от Panorama и т.д.) Вас не устраивают. ... |
| 19.05.2003, 12:32:48 |
Какие мнения? Ждём-с. Вроде как, на минувший январь обещали. В принципе, на словах, они работали над закрытием основных проблемных мест. Правда, боюсь, что решить до конца проблему вычисления "сложных" СМ, им пока не удалось. ... |
| 19.05.2003, 15:30:25 |
Деду Маздаю. Вот только не надо равнять клиенты реляционных БД и OLAP серверов. Они отличаются хотя бы тем что в полях мер кроме цифр вообще ничего не может быть, а это существенно вляет на подход к созданию клиента. Под нормальным клиентом я подразумеваю хотя бы простую "смотрелку", аля OWC PivotTable. Вот если бы в нём можно было бы хотя бы: 1. Сохранять дизайн при работе в Internet Explorer. 2. Разворачивать не только самые вложенные измерения, если их несколько на оси таблицы, а все, как это сделано в Excel. 3. Если бы поля от развёрнутых Level на осях таблицы удалялись бы хотя бы группой. Вот тогда бы это был нормальный клиент хотя бы для элементарного просмотра куба. Неужели так преступно желание иметь недорогой, но функциональный viewer для OLAP кубов? Все перечисленные Вами монстры - клиенты не всегда и нужны, а стоят они не малые деньги. И к стати, я попытался получить триал версию Panorama. Так от них ни ответа ни привета! ... |
| 20.05.2003, 07:48:10 |
2 GoodLeo: Я думаю, если бы появился такой недорогой, качественный OLAP-клиент с описанной Вами функциональностью, то многие специалисты по продуктам/технологиям Microsoft остались бы без работы... :) И к стати, я попытался получить триал версию Panorama. Так от них ни ответа ни привета! Думаю, самый дешевый и качественный для Вас вариант - это OLAP-клиент PowerPlay User (продукт компании Cognos, которой ранее принадлежал и продукт Panorama). Для того чтобы пользователи могли работать с кубами MS AS через этого клиента из удаленных филиалов, поставьте PPU на сервер в центральном офисе и дайте удаленный доступ через терминал. Со временем возможно Вы и кубы будете создавать с помощью PPU. Посмотреть интерфейс конечного пользователя и заказать триальную версию можно на сайте http://cognos.narod.ru ... |
| 20.05.2003, 09:38:19 |
start [/forum/topic.php?desktop=1&fid=49&tid=1873390]: |
44ms |
29ms |
| others: | 198ms |
| total: | 307ms |
