Perenos kubov mezhdu serverami
Vsem privet, est'-li sposoby programnogo perenosa kubov mezhdu serverami (MS AS) ? Naryl method Clone o clsCube, no eshe ne pousal. Eshe est' chto-nibud' ? 10x! ... |
| 25.02.2004, 18:20:40 |
А вам отдельно взятые кубы переносить надо или OLAP БД целиком? ... |
| 26.02.2004, 01:38:04 |
otdelno vzyatye ... |
| 26.02.2004, 18:44:18 |
Vam programmno ili v Analysis administratore? Esli pervoe, to vam na DSO "poemu" pisat nado. ... |
| 26.02.2004, 21:54:17 |
...tak ya i dumal :( vidimo pridetsya. Mozhet est' template kakoi-nibud' ? Ili script gotovyi ? ... |
| 26.02.2004, 23:32:11 |
Est resheniya 3-h firm po skriptovaniyu ob'ektov MS AS baz. V Yukone eto "out of box". ... |
| 27.02.2004, 00:35:17 |
hmmm..."resheniya" eti kak ya ponimayu platnye ? na kakoi-nibud' ishodnik raschityvat' ne prihoditsya ? ... |
| 27.02.2004, 08:43:25 |
Ya mezhdu serverami OLAP bazu celikom perenoshu. Pochemu vam nado perenosit kubi mezhdu serverami, a ne bazu? S bazoi eto namnogo prosche, da i za kubom esche boroda izmerenii tyanetsya. ... |
| 27.02.2004, 10:16:22 |
...da nelzya vsyu bazu perenosit'. Sushestvuet neskolko environmentov: test, dev,QA,prod. i t.d. razrabotka nachinaetsya s testa i potom hodit mezhdu environmentami. Ne mogu ya vzyat i vsyu bazu s testa nakatit' na QA naprimer ibo na teste naprimer lezhit vse skopom v tom chisle i razobrannye kuby, peredelyvaemye i upgreidayushiesya. To zhe samoe otnositsya k dimenshionam. Yasno chto za cubom "skarb" tyanutsya dolzhen - kto sporit. Ya pro eto i sprashivayu. Kak utyanut' kub so vsem prichitayushimsya barahlom na drugoi servak ? Esli est' sovety, a luchshe gotovyi code - budu ochen priznatelen. Thanks. ... |
| 27.02.2004, 18:35:28 |
Po moemu vam stoit prizadumatsya nad metodologicheskim obespecheniem processov razrabotki, chem pisat script, kotorii v suschestvuyuschem u vas poryadke budet skarb vilavlivat i potencialno voznikayusche konflicti razreshat. test -> dev -> QA -> prod. Esli ya pravilno ponimayu, to u vas v test BD lezhit "kucha mala", i problema sostoit tolko na etape test -> dev, t.k. QA i prod imeyut 100% repliki "dev", ibo ih delo kontrolirovat a ne menyat. (Rabotnik OTK stavit stamp "brak", a napilnik i molotok dlya nego "tabu") "test" u vas navernoe svoego roda poligon dazhe ne razrabotchika, a architektora - a la "nabroski na temu". Ya bi v etom sluchae ne polenilsya i proshel bi ruchkami po "dev" i vosproizvel to, chto po-vashemu mneniyu podlezhit perenosu iz test v dev, ibo to, chto po vashemu mneniyu dolzhno bit pereneseno iz "test" v "dev", vse ranvno dolzhno soprovozhdatsya dokumentaciei i t.p. Ili ya ne sovsem ponyal, kak vi prinimaete reshenie? "Kub XYZ - nado perenesti iz bazi ABC v bazu CDE"? a vsyakie dependency, ich razve ne nado analizirovat? Kak chast i naskolko gromozdki potrebnie vam operacii? ... |
| 27.02.2004, 20:55:09 |
Я хочу подтвердить правоту предыдущего сообщения. Как в текущей так и в следующей версии единицей управления является база данных. Все операции типа переноса, сохранения и восстановления организованны для базы данных. Так что лучше обеспечить работу так, чтобы база данных была чистой на всех этапах работы, а посторонние эксперименты проводились в базе данных специально для этого предназначенной. ... |
| 29.02.2004, 11:52:01 |
To Саша Бергер Радует, когда мнение о принципах использования интрумента (MS AS) совпадает с мнением разработчиками инстумента. ... |
| 29.02.2004, 14:20:16 |
Guys, spasibo za sovety - vse ponyatno. Zadacha v principe trivialna. Yasno chto dolzhna byt' opredelennaya politica - ona i est'. Prosto vot napisal ya kakuyu-to zadachu na teste, mne ee nado perenesti na dev, vot i zahotelos' etu operaciyu scriptnut'. Chtoby dat' chelu script - on ego zapustil i telemarket. ... |
| 04.03.2004, 18:24:37 |
start [/forum/topic.php?desktop=1&fid=49&tid=1872798]: |
234ms |
44ms |
| others: | 187ms |
| total: | 505ms |
