Ошибка в ReportingServis
Подскажите что за ошибка такая при выводе бланка отчета... The version of the report server database is either in a format that is not valid, or it cannot be read. The found version is 'Unknown'. The expected version is 'C.0.8.40'. To continue, update the version of the report server database and verify access rights. (rsInvalidReportServerDatabase) Get Online Help ... |
| 15.03.2006, 19:13 |
start [/forum/topic.php?desktop=1&fid=49&tid=1870439]: |
48ms |
| others: | 226ms |
| total: | 347ms |
