Runtime Repository OWB
OWB 10.1.4 OS Solaris 9 при установке репозитория выходит вот такая ошибка oracle.wh.util.DebugUtility: [getOCIorThinConnection]:connectInfo = (DESCRIPTION=(ADDRESS=(HOST=172.22.31.17)(PROTOCOL=tcp)(PORT=1521))(CONNECT_DATA=(SERVICE_NAME=dwh))) oracle.wh.util.DebugUtility: [getOCIorThinConnection]:userName = REP_OWNER oracle.wh.util.DebugUtility: [getOCIorThinConnection]: Asst: Trying with oci oracle.wh.util.DebugUtility: [getOCIorThinConnection]: Asst: using oci oracle.wh.util.DebugUtility: .....in parseSqlFile() oracle.wh.util.DebugUtility: the tbspace for data is VBXL_DATA oracle.wh.util.DebugUtility: the tbspace for indexes is VBXL_INDEX oracle.wh.util.DebugUtility: the tbspace for snapshot is USERS oracle.wh.util.DebugUtility: Script Name is ../../rtasst/wb_rt_deploy_pv.sql oracle.wh.util.DebugUtility: After processing SQLINDX token oracle.wh.util.DebugUtility: This is the -token name = SQLINDX; -token type = 5 oracle.wh.util.DebugUtility: Before processing SQLINDX Token oracle.wh.util.DebugUtility: User:REP_OWNER oracle.wh.util.DebugUtility: [getOCIorThinConnection]:connectInfo = (DESCRIPTION=(ADDRESS=(HOST=172.22.31.17)(PROTOCOL=tcp)(PORT=1521))(CONNECT_DATA=(SERVICE_NAME=dwh))) oracle.wh.util.DebugUtility: [getOCIorThinConnection]:userName = REP_OWNER oracle.wh.util.DebugUtility: [getOCIorThinConnection]: Asst: Trying with oci oracle.wh.util.DebugUtility: [getOCIorThinConnection]: Asst: using oci oracle.wh.util.DebugUtility: .....in parseSqlFile() oracle.wh.util.DebugUtility: the tbspace for data is VBXL_DATA oracle.wh.util.DebugUtility: the tbspace for indexes is VBXL_INDEX oracle.wh.util.DebugUtility: the tbspace for snapshot is USERS oracle.wh.util.DebugUtility: Script Name is ../../rtasst/wb_rt_execute_pv.sql oracle.wh.util.DebugUtility: After processing SQLINDX token oracle.wh.util.DebugUtility: This is the -token name = SQLINDX; -token type = 5 oracle.wh.util.DebugUtility: Before processing SQLINDX Token oracle.wh.util.DebugUtility: User:REP_OWNER oracle.wh.util.DebugUtility: [getOCIorThinConnection]:connectInfo = (DESCRIPTION=(ADDRESS=(HOST=172.22.31.17)(PROTOCOL=tcp)(PORT=1521))(CONNECT_DATA=(SERVICE_NAME=dwh))) oracle.wh.util.DebugUtility: [getOCIorThinConnection]:userName = REP_OWNER oracle.wh.util.DebugUtility: [getOCIorThinConnection]: Asst: Trying with oci oracle.wh.util.DebugUtility: [getOCIorThinConnection]: Asst: using oci oracle.wh.util.DebugUtility: .....in parseSqlFile() oracle.wh.util.DebugUtility: the tbspace for data is VBXL_DATA oracle.wh.util.DebugUtility: the tbspace for indexes is VBXL_INDEX oracle.wh.util.DebugUtility: the tbspace for snapshot is USERS oracle.wh.util.DebugUtility: Script Name is ../../rtasst/ocmrepcre.sql oracle.wh.util.DebugUtility: After processing SQLINDX token oracle.wh.util.DebugUtility: This is the -token name = SQL; -token type = 1 oracle.wh.util.DebugUtility: Before processing SQL Token oracle.wh.util.DebugUtility: [processSQLToken]: User = REP_OWNER oracle.wh.util.DebugUtility: [getOCIorThinConnection]:connectInfo = (DESCRIPTION=(ADDRESS=(HOST=172.22.31.17)(PROTOCOL=tcp)(PORT=1521))(CONNECT_DATA=(SERVICE_NAME=dwh))) oracle.wh.util.DebugUtility: [getOCIorThinConnection]:userName = REP_OWNER oracle.wh.util.DebugUtility: [getOCIorThinConnection]: Asst: Trying with oci oracle.wh.util.DebugUtility: [getOCIorThinConnection]: Asst: using oci oracle.wh.util.DebugUtility: =========== enter file: ../../rtasst/roles_object_rights.sql oracle.wh.util.DebugUtility: After processing SQL token oracle.wh.util.DebugUtility: This is the -token name = SPAWN; -token type = 4 oracle.wh.util.DebugUtility: Before processing SPAWN Token oracle.wh.util.DebugUtility: After processing SPAWN Token oracle.wh.util.DebugUtility: This is the -token name = SPAWN; -token type = 4 oracle.wh.util.DebugUtility: Before processing SPAWN Token oracle.wh.util.DebugUtility: [processSPAWN]: User = REP_OWNER oracle.wh.util.DebugUtility: [processSPAWN]: wholeLine =../unix/loadjava -thin -verbose -order -resolve -u %user/%password@(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=%host)(PORT=%port))(CONNECT_DATA=(SERVICE_NAME=%serviceName))) ../../lib/int/rtpserver.jar oracle.wh.util.DebugUtility: [processSPAWN]: A spawned program error. Exception = java.io.IOException: Not enough space oracle.wh.util.DebugUtility: [processSPAWN]: Get the error, stop processing... ... |
| 31.05.2006, 15:33 |
start [/forum/topic.php?desktop=1&fid=49&tid=1870055]: |
63ms |
42ms |
| others: | 245ms |
| total: | 407ms |
