Oracle BI Publisher: Query timed out
Проблема с выгрузкой отчёта из BI через BI Publisher с помощью scheduler`а, данные выгружаются из Oracle Essbase. Возникает ошибка "Query timed out". Подскажите где настроить этот timeout выполнения запроса. Лог BI Publisher: [041910_033943109][][STATEMENT] ToplinkDataHandler.getOutput() : called [041910_033943109][][STATEMENT] Default read connection pool max:0, min:0, total :0, available:0 [041910_033943109][][STATEMENT] ToplinkDataHandler.queryOutput() : query timeout =15000 [041910_033943109][][STATEMENT] ToplinkDataHandler.queryOutput() : calling execu teQuery(). 2010-04-19 15:39:43.109 WARNING url mismatchjdbc:hyperion:db2://localhost:50000;Data baseName=DB 2010-04-19 15:39:43.109 WARNING url mismatchjdbc:hyperion:db2://localhost:50000;Data baseName=DB [041910_033943265][][STATEMENT] ToplinkDataHandler.queryOutput() : finished call ing executeQuery(). [041910_033943265][][STATEMENT] ToplinkDataHandler.queryOutput() : output list s ize = 1 [041910_033943265][][STATEMENT] ToplinkDataHandler.terminateSession() : releasin g the session. [041910_033944718][][STATEMENT] ToplinkDataHandler.getOutput() : called [041910_033944734][][STATEMENT] Default read connection pool max:0, min:0, total :0, available:0 [041910_033944734][][STATEMENT] ToplinkDataHandler.queryOutput() : query timeout =15000 [041910_033944734][][STATEMENT] ToplinkDataHandler.queryOutput() : calling execu teQuery(). 2010-04-19 15:39:44.734 WARNING url mismatchjdbc:hyperion:db2://localhost:50000;Data baseName=DB 2010-04-19 15:39:44.734 WARNING url mismatchjdbc:hyperion:db2://localhost:50000;Data baseName=DB [041910_033944890][][STATEMENT] ToplinkDataHandler.queryOutput() : finished call ing executeQuery(). [041910_033944906][][STATEMENT] ToplinkDataHandler.queryOutput() : output list s ize = 1 [041910_033944906][][STATEMENT] ToplinkDataHandler.terminateSession() : releasin g the session. [041910_034021859][][STATEMENT] saw xml view service v4 - time out: 0 [041910_034021875][][EXCEPTION] AxisFault faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server faultSubcode: faultString: Query timed out. faultActor: faultNode: faultDetail: {com.siebel.analytics.web/soap/error/v1}Error: <sawsoape:Code>CMLRDOID</sawsoape:Code> <sawsoape:Message>Query timed out.</sawsoape:Message> <sawsoape:File>./project/webconnect/querycache.cpp</sawsoape:File> <sawsoape:Line>1701</sawsoape:Line> <sawsoape:LogSources> <sawsoape:LogSource>saw.soap.xmlviewservice</sawsoape:LogSource> <sawsoape:LogSource>saw.SOAP</sawsoape:LogSource> <sawsoape:LogSource>saw.httpserver.request.soaprequest</sawsoape:LogSour ce> <sawsoape:LogSource>saw.rpc.server.responder</sawsoape:LogSource> <sawsoape:LogSource>saw.rpc.server</sawsoape:LogSource> <sawsoape:LogSource>saw.rpc.server.handleConnection</sawsoape:LogSource> <sawsoape:LogSource>saw.rpc.server.dispatch</sawsoape:LogSource> <sawsoape:LogSource>saw.threadPool</sawsoape:LogSource> <sawsoape:LogSource>saw.threadPool</sawsoape:LogSource> <sawsoape:LogSource>saw.threads</sawsoape:LogSource> </sawsoape:LogSources> Query timed out. at org.apache.axis.message.SOAPFaultBuilder.createFault(SOAPFaultBuilder .java:222) at org.apache.axis.message.SOAPFaultBuilder.endElement(SOAPFaultBuilder. java:129) at org.apache.axis.encoding.DeserializationContext.endElement(Deserializ ationContext.java:1087) at oracle.xml.parser.v2.NonValidatingParser.parseElement(NonValidatingPa rser.java:1318) at oracle.xml.parser.v2.NonValidatingParser.parseRootElement(NonValidati ngParser.java:336) at oracle.xml.parser.v2.NonValidatingParser.parseDocument(NonValidatingP arser.java:303) at oracle.xml.parser.v2.XMLParser.parse(XMLParser.java:206) at oracle.xml.jaxp.JXSAXParser.parse(JXSAXParser.java:292) at org.apache.axis.encoding.DeserializationContext.parse(Deserialization Context.java:227) at org.apache.axis.SOAPPart.getAsSOAPEnvelope(SOAPPart.java:696) at org.apache.axis.Message.getSOAPEnvelope(Message.java:435) at org.apache.axis.handlers.soap.MustUnderstandChecker.invoke(MustUnders tandChecker.java:62) at org.apache.axis.client.AxisClient.invoke(AxisClient.java:206) at org.apache.axis.client.Call.invokeEngine(Call.java:2784) at org.apache.axis.client.Call.invoke(Call.java:2767) at org.apache.axis.client.Call.invoke(Call.java:2443) at org.apache.axis.client.Call.invoke(Call.java:2366) at org.apache.axis.client.Call.invoke(Call.java:1812) at oracle.apps.xdo.service.report.saw.soap.v4.XmlViewServiceStub.getResu lts(XmlViewServiceStub.java:1559) at oracle.apps.xdo.service.report.saw.wrapper.v4.SawXmlViewServiceImpl.g etResults(SawXmlViewServiceImpl.java:61) at oracle.apps.xdo.service.report.saw.SawXMLUtil.getSAWReportXMLData(Saw XMLUtil.java:572) at oracle.apps.xdo.service.report.saw.SawXMLUtil.getSAWReportXMLData(Saw XMLUtil.java:543) at oracle.apps.xdo.servlet.data.server.SawServiceCall.getXMLForSawReport (SawServiceCall.java:132) at oracle.apps.xdo.servlet.data.server.SawServiceCall.doFetch(SawService Call.java:89) at oracle.apps.xdo.servlet.data.server.AbstractDataCall.execute(Abstract DataCall.java:63) at oracle.apps.xdo.servlet.data.bind.SawServiceBoundValue11.getValue(Saw ServiceBoundValue11.java:156) at oracle.apps.xdo.servlet.ReportContextImplV11.getReportXMLData(ReportC ontextImplV11.java:412) at oracle.apps.xdo.servlet.CoreProcessor.process(CoreProcessor.java:231) at oracle.apps.xdo.servlet.CoreProcessor.generateDocument(CoreProcessor. java:82) at oracle.apps.xdo.servlet.ReportImpl.renderReportXML(ReportImpl.java:27 4) at oracle.apps.xdo.servlet.scheduler.XDOJob.runBurstingReport(XDOJob.jav a:1878) at oracle.apps.xdo.servlet.scheduler.XDOJob.execute(XDOJob.java:358) at org.quartz.core.JobRunShell.run(JobRunShell.java:195) at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.j ava:520) [041910_034021937][oracle.apps.xdo.servlet.scheduler.XDOJob][EXCEPTION] [ID:401] Unexpected exception occurred while running the job. oracle.apps.xdo.servlet.scheduler.ProcessingException: Query timed out. at oracle.apps.xdo.servlet.scheduler.XDOJob.runBurstingReport(XDOJob.jav a:2116) at oracle.apps.xdo.servlet.scheduler.XDOJob.execute(XDOJob.java:358) at org.quartz.core.JobRunShell.run(JobRunShell.java:195) at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.j ava:520) Caused by: Query timed out. at oracle.apps.xdo.servlet.ReportException.fillInStackTrace(ReportExcept ion.java:124) at oracle.apps.xdo.servlet.data.DataException.fillInStackTrace(DataExcep tion.java:127) at java.lang.Throwable.<init>(Throwable.java:181) at java.lang.Exception.<init>(Exception.java:29) at oracle.apps.xdo.servlet.ReportException.<init>(ReportException.java:4 0) at oracle.apps.xdo.servlet.data.DataException.<init>(DataException.java: 44) at oracle.apps.xdo.servlet.data.server.SawServiceCall.doFetch(SawService Call.java:102) at oracle.apps.xdo.servlet.data.server.AbstractDataCall.execute(Abstract DataCall.java:63) at oracle.apps.xdo.servlet.data.bind.SawServiceBoundValue11.getValue(Saw ServiceBoundValue11.java:156) at oracle.apps.xdo.servlet.ReportContextImplV11.getReportXMLData(ReportC ontextImplV11.java:412) at oracle.apps.xdo.servlet.CoreProcessor.process(CoreProcessor.java:231) at oracle.apps.xdo.servlet.CoreProcessor.generateDocument(CoreProcessor. java:82) at oracle.apps.xdo.servlet.ReportImpl.renderReportXML(ReportImpl.java:27 4) at oracle.apps.xdo.servlet.scheduler.XDOJob.runBurstingReport(XDOJob.jav a:1878) ... 3 more ... |
| 20.04.2010, 11:59:02 |
| 20.04.2010, 13:17:45 |
Jack Carver, Спасибо большое Помогло побороть текущую проблему, теперь боремся с следующей ... |
| 21.04.2010, 16:27:44 |
Jack Carver, Столкнулась с описанной Вами в посте проблемой. Но теперь при добавлении соответствующих строк в instanceconfig.xml сервер отказывается подниматься. Может быть эти настройки куда-то переехали в 12ой версии? Настройка в свойствах модели данных также не помогла ... |
| 24.10.2017, 13:12:33 |
start [/forum/topic.php?desktop=1&fid=49&tid=1858059]: |
190ms |
25ms |
| others: | 194ms |
| total: | 434ms |
