Cognos 10.2.2 winx64 AD
В домене отключили TLS1.0 Конфигратор на тесте выдает ['AD'] [ ERROR ] CAM-AAA-0146 The namespace 'AD' is not available. [ ERROR ] CAM-AAA-0064 The function 'Configure' failed. [ ERROR ] CAM-AAA-0043 The LDAP directory server 'имя.имя.ru':'636' is not running. [ ERROR ] ADSI Error HRESULT Returns: ERROR_DS_SERVER_DOWN ADSI Error: Не найду как победить ... |
| 19.04.2018, 13:01:32 |
Нашел упоминание, не знаю то или не то и не понятно в какие переменные-ветку засунуть. https://www.ibm.com/support/knowledgecenter/en/SSLTBW_2.1.0/com.ibm.zos.v2r1.glpa200/tivstls.htm TLS V1.1 and TLS V1.2 protocol levels are controlled by the z/OS System SSL defaults and environment variables. By default, these two protocols are disabled. To enable TLS V1.1 protocol, you must set the environment variable GSK_PROTOCOL_TLSV1_1 to "ON". Similarly, to enable TLS V1.2 protocol, you must set the environment variable GSK_PROTOCOL_TLSV1_2 to "ON". ... |
| 19.04.2018, 14:59:15 |
up [img] https://preview.ibb.co/eQBRPH/tls10.jpg [/img] ... |
| 14.05.2018, 09:59:51 |
start [/forum/topic.php?desktop=1&fid=49&tid=1857889]: |
1141ms |
26ms |
| others: | 187ms |
| total: | 1384ms |
