Установка mysql под linux
Скачал 4 и 3 версию под unix ...не получается запустить ..распаковывал без проблем..но не запускается mysql.server,также не могу там найти папку bin помогите с этим разобраться... ... |
| 19.08.2003, 17:32:00 |
Making all in MacOSX make: Entering directory `/mysql-4.0.12/support-files/MacOSX' make: Nothing to be done for `all'. make: Leaving directory `/mysql-4.0.12/support-files/MacOSX' make: Entering directory `/mysql-4.0.12/support-files' make: Nothing to be done for `all-am'. make: Leaving directory `/mysql-4.0.12/support-files' ... |
| 19.08.2003, 18:10:05 |
Ты попробовал, то что я тебе по аське спросил? mahoune ... |
| 20.08.2003, 10:02:03 |
man rpm ... |
| 20.08.2003, 10:28:31 |
[root@localhost support-files]# rpm -q mysql mysql-3.23.52-3 [root@localhost support-files]# rpm -e mysql error: Failed dependencies: libmysqlclient.so.10 is needed by (installed) libdbi-dbd-mysql-0.6.5-2 libmysqlclient.so.10 is needed by (installed) mod_auth_mysql-1.11-10 libmysqlclient.so.10 is needed by (installed) MyODBC-2.50.39-7 libmysqlclient.so.10 is needed by (installed) MySQL-python-0.9.1-4 libmysqlclient.so.10 is needed by (installed) mysql-server-3.23.52-3 libmysqlclient.so.10 is needed by (installed) perl-DBD-MySQL-2.1017-3 libmysqlclient.so.10 is needed by (installed) php-mysql-4.2.2-8.0.5 libmysqlclient.so.10 is needed by (installed) qt-MySQL-3.0.5-17 mysql = 3.23.52 is needed by (installed) mysql-devel-3.23.52-3 mysql is needed by (installed) MySQL-python-0.9.1-4 mysql = 3.23.52 is needed by (installed) mysql-server-3.23.52-3 mysql is needed by (installed) php-mysql-4.2.2-8.0.5 Вот что выдает ...как убрать эту зависимость ...я под Linux вторую неделю сижу,так что не судите строго !!!! ... |
| 20.08.2003, 11:16:40 |
start [/forum/topic.php?desktop=1&fid=47&tid=1855843]: |
44ms |
| others: | 189ms |
| total: | 279ms |
