ПОМОГИТЕ в чем ошибка!!!!
у меня есть запрос с использованием PERL: $sth=$dbh->prepare("SELECT DATE_FORMAT(guest.date,'%d-%m-%Y | %H:%i:%s') as d, guest.name as name, guest.text as text, guest.email as email, guest.id as id, answer.text as t_answer FROM guest LEFT JOIN answer ON guest.id=answer.id ORDER BY guest.id DESC LIMIT ?,?"); $sth->execute( $start,$page_size); у меня на компьЮТЕРЕ ВСЁ ВЫПОЛНЯЕТСЯ КОРЕКТНО И ПРАВИЛЬНО, а вот на сервере выдает ошибку: DBD::mysql::st execute failed: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near ''0','6'' at line 2 at guest.pl line 300 line 300-это само выражение SELECT. ... |
| 03.05.2004, 00:32:07 |
start [/forum/topic.php?desktop=1&fid=47&tid=1855190]: |
57ms |
30ms |
| others: | 209ms |
| total: | 344ms |
