Можно-ли оптимизировать запрос
Добрый день! Есть запрос: select SQL_CACHE match(event_index) AGAINST ('test' IN BOOLEAN MODE) as relevant, event_index like '%test%' as likesearch ,event.*,area.*,cat.* from eventinx_search search,eventinx_event event, eventinx_areas area, eventinx_categories cat where area.area_id=event.event_area and cat.cat_id=event.event_category and search.event_id=event.event_id having likesearch or relevant>0 order by area_id,cat_id,event_date Можно ли его оптимизировать, если учесть что на поле event_index стоит fulltext.... Small Devil ... |
| 16.05.2005, 17:29 |
А EXPLAIN select SQL_CACHE match(event_index) AGAINST ('test' IN BOOLEAN MODE) as relevant, event_index like '%test%' as likesearch ,event.*,area.*,cat.* from eventinx_search search,eventinx_event event, eventinx_areas area, eventinx_categories cat where area.area_id=event.event_area and cat.cat_id=event.event_category and search.event_id=event.event_id having likesearch or relevant>0 order by area_id,cat_id,event_date что говорит? ... |
| 01.06.2005, 07:53 |
start [/forum/topic.php?desktop=1&fid=47&tid=1853997]: |
241ms |
42ms |
| others: | 233ms |
| total: | 577ms |
