finding rownum from result
Dear Experts i have previously emulated Oracle like rownum in MySQL it works correctly before but at moment: Код: sql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. Output: how i can fix it that it shows exact rownum from 1 to end? You can check previous topic for table samples: http://www.sql.ru/forum/1047702/how-to-find-overall-point-of-each-team-from-result Thanks. ... |
| 23.09.2013, 16:39:12 |
Shahriyar.R, It is expected "unexpected" behaviour. Solution is rather simple -- move @row_num:=@row_num+1 and ORDER BY into yet another level of select: Код: sql 1. 2. 3. 4. 5. 6. 7. 8. Observations like this are numerous: moment of evaluation of @variables is not strictly defined except for simplest cases. Apparently GROUP BY and ORDER BY on the same level bring uncertainty here. Divide and conquer :-) ... |
| 23.09.2013, 17:42:20 |
javajdbc, Great forum , great people and ofcourse great experts! Thanks :) Works like a charm: Код: sql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. ... |
| 23.09.2013, 22:02:34 |
Also rewrite this for using without "set @@row_num=0" Код: sql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. ... |
| 23.09.2013, 22:27:36 |
start [/forum/topic.php?desktop=1&fid=47&tid=1835998]: |
142ms |
39ms |
| others: | 205ms |
| total: | 424ms |
