MYSQL запрос
Здравствуйте, пытаюсь выполнить запрос вылетает ошибка, как исправить? CREATE TABLE `userpref` ( `id` int(8) unsigned NOT NULL auto_increment, `username` varchar(128) NOT NULL default '', `preference` varchar(64) NOT NULL default '', `value` varchar(128) default NULL, `descript` varchar(128) default NULL, `added` datetime NOT NULL default '2003-01-01 00:00:00', `added_by` varchar(128) NOT NULL default '', `modified` timestamp(14), UNIQUE KEY `id` (`id`), KEY `type` (`preference`), KEY `added_by` (`added_by`), KEY `preference` (`preference`), KEY `username` (`username`) ) TYPE=MyISAM; ERROR 1064 (42000) at line 1: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(14), UNIQUE KEY `id` (`id`), UNIQUE KEY `id` (`id`), KEY `type` (`preference' at line 9 Спасибо! ... |
| 13.10.2013, 18:24:05 |
MYSQL запрос
Нет такого типа, как timestamp(14) ... |
| 13.10.2013, 18:37:07 |
start [/forum/topic.php?desktop=1&fid=47&tid=1835888]: |
50ms |
40ms |
| others: | 241ms |
| total: | 375ms |
