Вложенный запрос
Помогите переделать 4 запроса на 1 вложенный. $result = mysql_query("SELECT p2jyb_jshopping_orders.order_date, p2jyb_jshopping_order_item.product_name, SUM( p2jyb_jshopping_order_item.product_quantity * p2jyb_jshopping_orders.order_subtotal ) AS q FROM p2jyb_jshopping_orders, p2jyb_jshopping_order_item WHERE ( p2jyb_jshopping_orders.order_id = p2jyb_jshopping_order_item.order_id ) AND ( MONTH( p2jyb_jshopping_orders.order_date ) <=3 ) GROUP BY product_name ORDER BY product_name DESC "); $result1 = mysql_query("SELECT p2jyb_jshopping_orders.order_date, p2jyb_jshopping_order_item.product_name, SUM( p2jyb_jshopping_order_item.product_quantity * p2jyb_jshopping_orders.order_subtotal ) AS q1 FROM p2jyb_jshopping_orders, p2jyb_jshopping_order_item WHERE ( p2jyb_jshopping_orders.order_id = p2jyb_jshopping_order_item.order_id ) AND ( MONTH( p2jyb_jshopping_orders.order_date ) >3 ) AND ( MONTH( p2jyb_jshopping_orders.order_date ) <=6 ) GROUP BY product_name ORDER BY product_name DESC "); $result2 = mysql_query("SELECT p2jyb_jshopping_orders.order_date, p2jyb_jshopping_order_item.product_name, SUM( p2jyb_jshopping_order_item.product_quantity * p2jyb_jshopping_orders.order_subtotal ) AS q2 FROM p2jyb_jshopping_orders, p2jyb_jshopping_order_item WHERE ( p2jyb_jshopping_orders.order_id = p2jyb_jshopping_order_item.order_id ) AND ( MONTH( p2jyb_jshopping_orders.order_date ) >6 ) AND ( MONTH( p2jyb_jshopping_orders.order_date ) <=9 ) GROUP BY product_name ORDER BY product_name DESC "); $result3 = mysql_query("SELECT p2jyb_jshopping_orders.order_date, p2jyb_jshopping_order_item.product_name, SUM( p2jyb_jshopping_order_item.product_quantity * p2jyb_jshopping_orders.order_subtotal ) AS q3 FROM p2jyb_jshopping_orders, p2jyb_jshopping_order_item WHERE ( p2jyb_jshopping_orders.order_id = p2jyb_jshopping_order_item.order_id ) AND ( MONTH( p2jyb_jshopping_orders.order_date ) >9 ) AND (MONTH( p2jyb_jshopping_orders.order_date ) <=12) GROUP BY product_name ORDER BY product_name DESC "); Запрос собирает данные для xyz анализа ... |
| 07.04.2014, 15:16:23 |
Вложенный запрос
xyz-analiz, трудно читать ваш пост. Если не трудно, оставьте только СКЛ и отформатируйте его. ... |
| 07.04.2014, 18:55:10 |
Вложенный запрос
javajdbc, SELECT p2jyb_jshopping_orders.order_date, p2jyb_jshopping_order_item.product_name, SUM( p2jyb_jshopping_order_item.product_quantity * p2jyb_jshopping_orders.order_subtotal ) AS q FROM p2jyb_jshopping_orders, p2jyb_jshopping_order_item WHERE ( p2jyb_jshopping_orders.order_id = p2jyb_jshopping_order_item.order_id ) AND ( MONTH( p2jyb_jshopping_orders.order_date ) <=3 ) GROUP BY product_name ORDER BY product_name DESC; SELECT p2jyb_jshopping_orders.order_date, p2jyb_jshopping_order_item.product_name, SUM( p2jyb_jshopping_order_item.product_quantity * p2jyb_jshopping_orders.order_subtotal ) AS q1 FROM p2jyb_jshopping_orders, p2jyb_jshopping_order_item WHERE ( p2jyb_jshopping_orders.order_id = p2jyb_jshopping_order_item.order_id ) AND ( MONTH( p2jyb_jshopping_orders.order_date ) >3 ) AND ( MONTH( p2jyb_jshopping_orders.order_date ) <=6 ) GROUP BY product_name ORDER BY product_name DESC; SELECT p2jyb_jshopping_orders.order_date, p2jyb_jshopping_order_item.product_name, SUM( p2jyb_jshopping_order_item.product_quantity * p2jyb_jshopping_orders.order_subtotal ) AS q2 FROM p2jyb_jshopping_orders, p2jyb_jshopping_order_item WHERE ( p2jyb_jshopping_orders.order_id = p2jyb_jshopping_order_item.order_id ) AND ( MONTH( p2jyb_jshopping_orders.order_date ) >6 ) AND ( MONTH( p2jyb_jshopping_orders.order_date ) <=9 ) GROUP BY product_name ORDER BY product_name DESC; SELECT p2jyb_jshopping_orders.order_date, p2jyb_jshopping_order_item.product_name, SUM( p2jyb_jshopping_order_item.product_quantity * p2jyb_jshopping_orders.order_subtotal ) AS q3 FROM p2jyb_jshopping_orders, p2jyb_jshopping_order_item WHERE ( p2jyb_jshopping_orders.order_id = p2jyb_jshopping_order_item.order_id ) AND ( MONTH( p2jyb_jshopping_orders.order_date ) >9 ) AND (MONTH( p2jyb_jshopping_orders.order_date ) <=12) GROUP BY product_name ORDER BY product_name DESC ; ... |
| 08.04.2014, 02:43:43 |
Вложенный запрос
xyz-analiz, Код: sql 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. ... |
| 08.04.2014, 05:17:10 |
Вложенный запрос
tanglir, #1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'soi.product_name ,SUM(case when MONTH( so.order_date ) <=3 then soi.product' at line 2 ... |
| 08.04.2014, 05:53:26 |
Вложенный запрос
если уж вы лишнюю запятую не в состоянии убрать, тогда может ну его нафиг, этот эскуэль? ... |
| 08.04.2014, 05:58:43 |
start [/forum/topic.php?desktop=1&fid=47&tid=1835015]: |
42ms |
32ms |
| others: | 186ms |
| total: | 295ms |
