Не создаются базы данных.
Вот код. В чем тут ошибка Microsoft Windows [Version 6.1.7601] (c) Корпорац?я Майкрософт (Microsoft Corporation), 2009. Ус? права захищено. C:\Users\Lyudmila>path %path%;C:\WebServers\usr\local\mysql-5.5\bin; C:\Users\Lyudmila>mysql -u root; Welcome to the MySQL monitor. Commands end with ; or \g. Your MySQL connection id is 3 Server version: 5.5.25 MySQL Community Server (GPL) Copyright (c) 2000, 2011, Oracle and/or its affiliates. All rights reserved. Oracle is a registered trademark of Oracle Corporation and/or its affiliates. Other names may be trademarks of their respective owners. Type 'help;' or '\h' for help. Type '\c' to clear the current input statement. mysql> show databases; +--------------------+ | Database | +--------------------+ | information_schema | +--------------------+ 1 row in set (0.00 sec) mysql> use information_schema; Database changed mysql> show tables; +---------------------------------------+ | Tables_in_information_schema | +---------------------------------------+ | CHARACTER_SETS | | COLLATIONS | | COLLATION_CHARACTER_SET_APPLICABILITY | | COLUMNS | | COLUMN_PRIVILEGES | | ENGINES | | EVENTS | | FILES | | GLOBAL_STATUS | | GLOBAL_VARIABLES | | KEY_COLUMN_USAGE | | PARAMETERS | | PARTITIONS | | PLUGINS | | PROCESSLIST | | PROFILING | | REFERENTIAL_CONSTRAINTS | | ROUTINES | | SCHEMATA | | SCHEMA_PRIVILEGES | | SESSION_STATUS | | SESSION_VARIABLES | | STATISTICS | | TABLES | | TABLESPACES | | TABLE_CONSTRAINTS | | TABLE_PRIVILEGES | | TRIGGERS | | USER_PRIVILEGES | | VIEWS | | INNODB_CMP_RESET | | INNODB_TRX | | INNODB_CMPMEM_RESET | | INNODB_LOCK_WAITS | | INNODB_CMPMEM | | INNODB_CMP | | INNODB_LOCKS | +---------------------------------------+ 37 rows in set (0.00 sec) mysql> create database tovar; ERROR 1044 (42000): Access denied for user ''@'localhost' to database 'tovar' mysql> ... |
| 03.07.2014, 13:03:10 |
соединение под рутом делай ... |
| 03.07.2014, 13:04:59 |
bochkov, тоесь? я просто новичек в этом деле? ... |
| 03.07.2014, 13:27:54 |
start [/forum/topic.php?desktop=1&fid=47&tid=1834567]: |
94ms |
37ms |
| others: | 225ms |
| total: | 400ms |
