Помогите "склеить"
Есть это: SELECT wallMessage.message, wallMessage.author, COUNT(DISTINCT wallComments.id) as sumComments, wallMessage.id, user.name, SUM(DISTINCT `likeWall`.`likeStats`) as likes, user.surname, wallMessage.author, wallMessage.`date`, wallMessage.pulse FROM wallMessage JOIN myFriends ON wallMessage.author = (IF(myFriends.idInput <> 1, myFriends.idOutgoing, myFriends.idInput and myFriends.status = 1)) left JOIN user on user.id = wallMessage.author left JOIN likeWall on likeWall.postID = wallMessage.id left JOIN wallComments on wallComments.postID = wallMessage.id WHERE wallMessage.author <> 1 group by `message` Order by `wallMessage`.`date` DESC Нужно заменить это: IF(myFriends.idInput <> 1, myFriends.idOutgoing, myFriends.idInput and myFriends.status = 1) На это: SELECT idOutgoing AS idFriendFROM `myFriends` WHERE idInput=1 AND STATUS = 1 UNION SELECT idInput AS idFriend FROM `myFriends` WHERE idOutgoing=1 AND STATUS = 1 Как правильно "склеить"? ... |
| 25.08.2014, 23:16:40 |
start [/forum/topic.php?desktop=1&fid=47&tid=1834319]: |
133ms |
| others: | 237ms |
| total: | 429ms |
