Не создаётся хр. процедура
Добрый день, форумчане проблема следующего характера. Пытался добавить в mysql хранимую процедурку нечего не получилось. Таблицы и вьюхи нет проблем , а вот процедуры никак. Даже /*Ответ MySQL: #1558 - Column count of mysql.proc is wrong. Expected 20, found 16. Created with MySQL 50095, now running 50538. Please use mysql_upgrade to fix this erro*/ Сделал [root@mail ~]# mysql_upgrade Looking for 'mysql' as: mysql Looking for 'mysqlcheck' as: mysqlcheck FATAL ERROR: Upgrade failed Начал капать далее. В логе при перерестарте выпадают следующие ошибки: 141201 14:10:23 [Note] /usr/libexec/mysqld: Normal shutdown 141201 14:10:24 InnoDB: Starting shutdown... 141201 14:10:25 InnoDB: Shutdown completed; log sequence number 121047238 141201 14:10:25 [Note] /usr/libexec/mysqld: Shutdown complete 141201 14:10:26 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended 141201 14:10:27 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql 141201 14:10:27 [Note] Plugin 'FEDERATED' is disabled. /usr/libexec/mysqld: Table 'mysql.plugin' doesn't exist 141201 14:10:27 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it. 141201 14:10:27 InnoDB: The InnoDB memory heap is disabled 141201 14:10:27 InnoDB: Mutexes and rw_locks use InnoDB's own implementation 141201 14:10:27 InnoDB: Compressed tables use zlib 1.2.3 141201 14:10:27 InnoDB: Using Linux native AIO 141201 14:10:27 InnoDB: Initializing buffer pool, size = 128.0M 141201 14:10:27 InnoDB: Completed initialization of buffer pool 141201 14:10:27 InnoDB: highest supported file format is Barracuda. 141201 14:10:30 InnoDB: Waiting for the background threads to start 141201 14:10:31 InnoDB: 5.5.38 started; log sequence number 121047238 141201 14:10:31 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306 141201 14:10:31 [Note] - '0.0.0.0' resolves to '0.0.0.0'; 141201 14:10:31 [Note] Server socket created on IP: '0.0.0.0'. 141201 14:10:31 [ERROR] Missing system table mysql.proxies_priv; please run mysql_upgrade to create it 141201 14:10:31 [ERROR] Can't open and lock privilege tables: Table 'mysql.servers' doesn't exist 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_current' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_history' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_history_long' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'setup_consumers' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'setup_instruments' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'setup_timers' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'performance_timers' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'threads' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_summary_by_thread_by_event_name' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_summary_by_instance' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_summary_global_by_event_name' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'file_summary_by_event_name' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'file_summary_by_instance' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'mutex_instances' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'rwlock_instances' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'cond_instances' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'file_instances' has the wrong structure 141201 14:10:31 [ERROR] Column count of mysql.db is wrong. Expected 22, found 20. Created with MySQL 50095, now running 50538. Please use mysql_upgrade to fix this error. 141201 14:10:31 [ERROR] mysql.user has no `Event_priv` column at position 29 141201 14:10:31 [ERROR] Cannot open mysql.event 141201 14:10:31 [ERROR] Event Scheduler: An error occurred when initializing system tables. Disabling the Event Scheduler. 141201 14:10:31 [Note] /usr/libexec/mysqld: ready for connections. Version: '5.5.38' socket: '/var/lib/mysql/mysql.sock' port: 3306 MySQL Community Server (GPL) by Remi Подскажите что делать и куда копать. И что это может быть. В MySQl не силён. Всегда работал с MSSQL ... |
| 01.12.2014, 15:22:44 |
stingggaДобрый день, форумчане проблема следующего характера. Пытался добавить в mysql хранимую процедурку нечего не получилось. Таблицы и вьюхи нет проблем , а вот процедуры никак. Даже /*Ответ MySQL: #1558 - Column count of mysql.proc is wrong. Expected 20, found 16. Created with MySQL 50095, now running 50538. Please use mysql_upgrade to fix this erro*/ Сделал [root@mail ~]# mysql_upgrade Looking for 'mysql' as: mysql Looking for 'mysqlcheck' as: mysqlcheck FATAL ERROR: Upgrade failed Начал капать далее. В логе при перерестарте выпадают следующие ошибки: 141201 14:10:23 [Note] /usr/libexec/mysqld: Normal shutdown 141201 14:10:24 InnoDB: Starting shutdown... 141201 14:10:25 InnoDB: Shutdown completed; log sequence number 121047238 141201 14:10:25 [Note] /usr/libexec/mysqld: Shutdown complete 141201 14:10:26 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended 141201 14:10:27 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql 141201 14:10:27 [Note] Plugin 'FEDERATED' is disabled. /usr/libexec/mysqld: Table 'mysql.plugin' doesn't exist 141201 14:10:27 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it. 141201 14:10:27 InnoDB: The InnoDB memory heap is disabled 141201 14:10:27 InnoDB: Mutexes and rw_locks use InnoDB's own implementation 141201 14:10:27 InnoDB: Compressed tables use zlib 1.2.3 141201 14:10:27 InnoDB: Using Linux native AIO 141201 14:10:27 InnoDB: Initializing buffer pool, size = 128.0M 141201 14:10:27 InnoDB: Completed initialization of buffer pool 141201 14:10:27 InnoDB: highest supported file format is Barracuda. 141201 14:10:30 InnoDB: Waiting for the background threads to start 141201 14:10:31 InnoDB: 5.5.38 started; log sequence number 121047238 141201 14:10:31 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306 141201 14:10:31 [Note] - '0.0.0.0' resolves to '0.0.0.0'; 141201 14:10:31 [Note] Server socket created on IP: '0.0.0.0'. 141201 14:10:31 [ERROR] Missing system table mysql.proxies_priv; please run mysql_upgrade to create it 141201 14:10:31 [ERROR] Can't open and lock privilege tables: Table 'mysql.servers' doesn't exist 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_current' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_history' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_history_long' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'setup_consumers' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'setup_instruments' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'setup_timers' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'performance_timers' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'threads' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_summary_by_thread_by_event_name' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_summary_by_instance' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_summary_global_by_event_name' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'file_summary_by_event_name' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'file_summary_by_instance' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'mutex_instances' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'rwlock_instances' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'cond_instances' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'file_instances' has the wrong structure 141201 14:10:31 [ERROR] Column count of mysql.db is wrong. Expected 22, found 20. Created with MySQL 50095, now running 50538. Please use mysql_upgrade to fix this error. 141201 14:10:31 [ERROR] mysql.user has no `Event_priv` column at position 29 141201 14:10:31 [ERROR] Cannot open mysql.event 141201 14:10:31 [ERROR] Event Scheduler: An error occurred when initializing system tables. Disabling the Event Scheduler. 141201 14:10:31 [Note] /usr/libexec/mysqld: ready for connections. Version: '5.5.38' socket: '/var/lib/mysql/mysql.sock' port: 3306 MySQL Community Server (GPL) by Remi Подскажите что делать и куда копать. И что это может быть. В MySQl не силён. Всегда работал с MSSQL плин... вот всегда хочеться ответить. если mssql овтетит - что поле count в sys.sys_table плохое. куда бы копал? ... |
| 01.12.2014, 15:38:13 |
дабы избежать холивара - подскажу. перевёл бы сначала сообщение про ошибку, потом бы в бил в гугл номер ошибки, и сразу бы нашол. база системная не от той версии мускла которая запущена. ... |
| 01.12.2014, 15:41:15 |
alex564657498765453дабы избежать холивара - подскажу. перевёл бы сначала сообщение про ошибку, потом бы в бил в гугл номер ошибки, и сразу бы нашол. база системная не от той версии мускла которая запущена. Спасибо. И как быть. Да я обновлял mysql. Сейчас 5.5.38 на centos5.5 Прошу прощениея за глупые вопросы . И как далее быть ? Как приатачить нужную? Ведь там же хранятся все данные по другим БД. И почему я могу создавать БД таблици и т.д. Ведь по идеи оно не должно и этого давать сделать :( ... |
| 01.12.2014, 15:49:43 |
stinggga, насколько знаю я, если база с таблицами майисам, то подключить её на скл сервер - просто скопировать папку базы в нужное место если иннодб, вот тут дела обстоят сложнее. у меня получилось но по форуму помню что с этим были проблемы. ... |
| 01.12.2014, 18:17:40 |
alex564657498765453stinggga, насколько знаю я, если база с таблицами майисам, то подключить её на скл сервер - просто скопировать папку базы в нужное место если иннодб, вот тут дела обстоят сложнее. у меня получилось но по форуму помню что с этим были проблемы. БД information_schema или mysql ? ... |
| 01.12.2014, 19:19:53 |
stingggaИ как далее быть ?Я бы предложил выгрузить дамп (без системных схем), переустановить начисто нужную версию MySQL и загрузить дамп обратно. ... |
| 01.12.2014, 19:24:18 |
stingggaalex564657498765453stinggga, насколько знаю я, если база с таблицами майисам, то подключить её на скл сервер - просто скопировать папку базы в нужное место если иннодб, вот тут дела обстоят сложнее. у меня получилось но по форуму помню что с этим были проблемы. БД information_schema или mysql ? ни то ни другое. свою базу. системные не трогать!!! ... |
| 01.12.2014, 23:46:04 |
alex564657498765453stingggaпропущено... БД information_schema или mysql ? ни то ни другое. свою базу. системные не трогать!!! А так у меня просто отсутствует бд performance_schema ?! ... |
| 02.12.2014, 10:33:28 |
stingggaalex564657498765453пропущено... ни то ни другое. свою базу. системные не трогать!!! А так у меня просто отсутствует бд performance_schema ?! И вставить то процедуру не могу не в какую БД. ... |
| 02.12.2014, 10:42:12 |
stingggastingggaпропущено... А так у меня просто отсутствует бд performance_schema ?! И вставить то процедуру не могу не в какую БД. Хотел бы подрезуюмировать. С ваших слов мне нужно в мои несистемные БД ( в их папки) добавить недостоющие таблицы или перезаписать ? Прошу прощения, я пока не понял. Заранее извеняюсь за ,возможно , глупые вопросы. Это мой первый опыт в настройке и работе с мускл Но лог пишит что плохая структура 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_current' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_history' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_history_long' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'setup_consumers' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'setup_instruments' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'setup_timers' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'performance_timers' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'threads' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_summary_by_thread_by_event_name' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_summary_by_instance' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'events_waits_summary_global_by_event_name' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'file_summary_by_event_name' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'file_summary_by_instance' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'mutex_instances' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'rwlock_instances' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'cond_instances' has the wrong structure 141201 14:10:31 [ERROR] Native table 'performance_schema'.'file_instances' has the wrong structure ... |
| 02.12.2014, 11:05:46 |
stingggaИ как далее быть ? Как приатачить нужную? Ведь там же хранятся все данные по другим БД. И почему я могу создавать БД таблици и т.д. Ведь по идеи оно не должно и этого давать сделать :( Поставь MySQL заново и делов. ... |
| 02.12.2014, 12:34:44 |
MasterZivstingggaИ как далее быть ? Как приатачить нужную? Ведь там же хранятся все данные по другим БД. И почему я могу создавать БД таблици и т.д. Ведь по идеи оно не должно и этого давать сделать :( Поставь MySQL заново и делов.Я это уже предлагал, но, видимо, так неинтересно :) ... |
| 02.12.2014, 12:38:21 |
miksoftMasterZivпропущено... Поставь MySQL заново и делов.Я это уже предлагал, но, видимо, так неинтересно :) Есть один ньюанс почему я не хочу пока переставлять. Путаюсь найти другие варианты :) Так понимаю что нет ?! ... |
| 02.12.2014, 13:54:44 |
stingggaПутаюсь найти другие варианты :) Так понимаю что нет ?!Да может и есть. Нужно детально разбираться, почему mysql_upgrade выдает ошибку. В т.ч. посмотреть внутрь его (это скрипт) и аккуратно соотносить его запуск с логами. Возможно, ему не хватает какой-нибудь банальщины типа запуска с указанием root-а. Но в сумме, имхо, это дольше, чем переустановить. ... |
| 02.12.2014, 14:12:18 |
miksoftstingggaПутаюсь найти другие варианты :) Так понимаю что нет ?!Да может и есть. Нужно детально разбираться, почему mysql_upgrade выдает ошибку. В т.ч. посмотреть внутрь его (это скрипт) и аккуратно соотносить его запуск с логами. Возможно, ему не хватает какой-нибудь банальщины типа запуска с указанием root-а. Но в сумме, имхо, это дольше, чем переустановить. Просто в /usr/sbin/mysqld ничего не пишет при mysql_upgrade. Только при рестарте ошибки. Только в консоле пишет что fatal_error. И понять сложно. ... |
| 02.12.2014, 16:48:40 |
stinggga, Спасибо всем за помощь. Заработал mysql_upgrade. Тема закрыта ... |
| 02.12.2014, 16:53:11 |
start [/forum/topic.php?desktop=1&fid=47&tid=1833857]: |
27ms |
47ms |
| others: | 209ms |
| total: | 323ms |
