Преобразование числа в строку
Дано Declare v varchar(255), X DOUBLE Как преобразовать Х в V Set V=Cast (x as varchar) не работает ... |
| 12.12.2014, 10:28:48 |
Set V=Cast (x as char) ... |
| 12.12.2014, 10:35:11 |
http://dev.mysql.com/doc/refman/5.6/en/cast-functions.html#function_cast The type for the result can be one of the following values: ◾ BINARY[(N)] ◾ CHAR[(N)] ◾ DATE ◾ DATETIME ◾ DECIMAL[(M[,D])] ◾ SIGNED [INTEGER] ◾ TIME ◾ UNSIGNED [INTEGER] ... |
| 12.12.2014, 11:23:34 |
start [/forum/topic.php?desktop=1&fid=47&tid=1833809]: |
44ms |
23ms |
| others: | 197ms |
| total: | 302ms |
