Ошибка при ресторе
ERROR 1418 (HY000) at line 77435: This function has none of DETERMINISTIC, NO SQL, or READS SQL DATA in its declaration and binary logging is enabled (you *might* want to use the less safe log_bin_trust_function_creators variable) log_bin_trust_function_creators = 1 Что с этим можно сделать? ... |
| 06.06.2015, 14:16:43 |
Ошибка при ресторе
Gallemar, прочитайте док: stored-programs-logging "When you create a stored function, you must declare either that it is deterministic or that it does not modify data. Otherwise, it may be unsafe for data recovery or replication." ... |
| 08.06.2015, 12:50:50 |
start [/forum/topic.php?desktop=1&fid=47&tid=1833086]: |
60ms |
34ms |
| others: | 193ms |
| total: | 328ms |
