как вытащить данные из innodb?
что-то случилось с базой почты dbmail поломалась табличка dbmail_messageblks CREATE TABLE `dbmail_messageblks` ( `messageblk_idnr` BIGINT(21) NOT NULL AUTO_INCREMENT, `physmessage_id` BIGINT(21) NOT NULL DEFAULT '0', `messageblk` LONGBLOB NOT NULL, `blocksize` BIGINT(21) NOT NULL DEFAULT '0', `is_header` TINYINT(1) NOT NULL DEFAULT '0', PRIMARY KEY (`messageblk_idnr`), INDEX `physmessage_id_index` (`physmessage_id`), INDEX `physmessage_id_is_header_index` (`physmessage_id`, `is_header`) ) COLLATE='utf8_general_ci' ENGINE=InnoDB AUTO_INCREMENT=0 PARTITION BY RANGE (messageblk_idnr) (PARTITION p0 VALUES LESS THAN (1500000) ENGINE = InnoDB, PARTITION p1 VALUES LESS THAN (3000000) ENGINE = InnoDB, PARTITION p3 VALUES LESS THAN (4500000) ENGINE = InnoDB, PARTITION p4 VALUES LESS THAN (6000000) ENGINE = InnoDB, PARTITION p5 VALUES LESS THAN (7500000) ENGINE = InnoDB, PARTITION p8 VALUES LESS THAN (12000000) ENGINE = InnoDB, PARTITION p9 VALUES LESS THAN (13500000) ENGINE = InnoDB, PARTITION p10 VALUES LESS THAN (15000000) ENGINE = InnoDB, PARTITION p11 VALUES LESS THAN (16500000) ENGINE = InnoDB, PARTITION p12 VALUES LESS THAN (18000000) ENGINE = InnoDB, PARTITION p13 VALUES LESS THAN (19500000) ENGINE = InnoDB, PARTITION p14 VALUES LESS THAN (21000000) ENGINE = InnoDB, PARTITION p15 VALUES LESS THAN (22500000) ENGINE = InnoDB, PARTITION p16 VALUES LESS THAN (24000000) ENGINE = InnoDB, PARTITION p17 VALUES LESS THAN (25500000) ENGINE = InnoDB, PARTITION p18 VALUES LESS THAN (27000000) ENGINE = InnoDB, PARTITION p19 VALUES LESS THAN (28500000) ENGINE = InnoDB, PARTITION p20 VALUES LESS THAN (30000000) ENGINE = InnoDB, PARTITION p21 VALUES LESS THAN (40000000) ENGINE = InnoDB, PARTITION p22 VALUES LESS THAN (50000000) ENGINE = InnoDB) ; в логах: 150806 10:31:29 InnoDB: Error: page 341 log sequence number 0 2964567 InnoDB: is in the future! Current system log sequence number 0 8716. InnoDB: Your database may be corrupt or you may have copied the InnoDB InnoDB: tablespace but not the InnoDB log files. See InnoDB: http://dev.mysql.com/doc/refman/5.1/en/forcing-innodb-recovery.html InnoDB: for more information. и 150806 10:31:30 InnoDB: Error: trying to open a table, but could not InnoDB: open the tablespace file './test/dbmail_messageblks#P#p0.ibd'! InnoDB: Have you moved InnoDB .ibd files around without using the InnoDB: commands DISCARD TABLESPACE and IMPORT TABLESPACE? InnoDB: It is also possible that this is a temporary table #sql..., InnoDB: and MySQL removed the .ibd file for this. InnoDB: Please refer to InnoDB: http://dev.mysql.com/doc/refman/5.1/en/innodb-troubleshooting-datadict.html InnoDB: for how to resolve the issue. в табличке старые партиции удалялись (освобождалось место) возможно какие-то партиции были удалены неправильно остались файлы начиная с 8-го объём оставшихся данных примерно 1 Тб innodb_force_recovery = 6 и другие значения не помогают мускулю увидеть эту табличку пробовал создавать в другой базе такую табличку и подсовывать файлики, не помогает подскажите в какую сторону копать, каким бубном постучать, нужно вытащить данные из повреждённой таблицы ... |
| 07.08.2015, 13:39:18 |
DimkinZ, у тебя повреждена база данных. данные уже не вытащить, восстанови из последнего бэкапа. ... |
| 07.08.2015, 14:16:57 |
авторпробовал создавать в другой базе такую табличку и подсовывать файлики, не помогает Уверены, что аккуратно это сделали и приведен первоначальный вариант ошибки, а не то, к чему привели ваши попытки ? Да тут скорее второй вариант из намека mysql : авторor you may have copied the InnoDB Конечно, данные вытащить можно, но трудоемкость весьма высока. Из бекапа намного проще. ... |
| 08.08.2015, 10:35:09 |
start [/forum/topic.php?desktop=1&fid=47&tid=1832839]: |
44ms |
| others: | 195ms |
| total: | 286ms |
